Question about Xante Ilumina Digital Color Press Printer
XANTE PRINTER #502 WASTE TONER BOX SENSOR PROBLEMS????
XANTE PRINTER #502 I REPLACE NEW WASTE BOX. BUT ALL WAYS REPEAT SHOW ON SCREEN REPLACE THE WASTE BOX. *THIS IS SENSOR PROBLEMS???? CAN YOU HELP!!!!!!!!!!!
funkyagain
  • 24 Answers
SOURCE: Toner refill kits
No, they are different. I would recommend either of these two sites for Xante toner refill kits as they have done a great job for me:
www.lasertekservices.com
www.tonerrefillstore.com
Posted on Apr 30, 2010
SOURCE: what is the price of xante 502?
13000$
Posted on Apr 26, 2011
richardthelh
  • 3 Answers
SOURCE: Unable to get Xante printer to work
The other option is to use the web page of the xante to print, I do this using mac os 10.4, since it stopped working in the printer menu. Xante support is poor at the very least and sucks at its best.
Posted on May 10, 2012
SOURCE: Good day
Most of the times the color background is a drum issue. The bigger the temperature, the more you will see this effect. There is a setting in the printer's menu, it's call BG Setting. Print the configuration menu to find it.It reduces or increases the background toning. Try this.
Posted on Nov 02, 2013
SOURCE: problem
what kind of paper do you use? do you see this effect in light paper also? Most of the times the color background is a drum issue. The bigger the temperature, the more you will see this effect. There is a setting in the printer's menu, it's call BG Setting. Print the configuration menu to find it.It reduces or increases the background toning. Try this.
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Nov 14, 2014 | Xante Ilumina 502 GS Digital Color Press...
What happens if you pull paper jam the wrong way
You may break any of the plastic switches actuators, which could cause a problem and your printer would not work until you replace that part that is broken. Depending on what area of the printer you broke the problem will be shown on your printer pannel.
Nov 12, 2014 | Xante Ilumina 502 GS Digital Color Press...
I've replaced the toner cartridge and waste toner bottle, but the display still says 'toner low' and 'waste toner near full'. It refuses to print, even with the old cartridges.
Then you mite want to clean the sensor that monitor the waster toner box pull out the waste toner box and look for the area that show clear plastic then look for those area of the machine and blow the old toner from those areas waste toner mite have gotten on the sensor saw they can not see the clear plastic and think that the waste toner cart is still full.
Sep 09, 2014 | Konica Minolta Magicolor 5670EN Color...
I have a xante 502 it has streaking on the top side of printing I printed each color and streaking is on each color with black the worst what part do I replace?
if you are familiar with ilumina menu search for the ID Test Pattern. Print test using 11 x 17 page.
On the copy you will see which of the drums need to replace, if the copy has vertical or horizontal lines on it the drum which ever color shows it has to be replace.
Jun 19, 2014 | Xante Ilumina® 502 Laser Printer
How i can fix this problem 929:fatal error .
Waste Toner Transfer Motor Lock Error
Check Waste Toner Unit Operation
Replace the Waste Toner Motor
May 16, 2014 | Xante Ilumina Digital Color Press Printer
Xante fatal error 929
Feb 11, 2014 | Xante Ilumina Digital Color Press Printer
Waste toner near full
there is a white gear whre you install the waste toner box, that is connected to the box. see if it's broken - yoy will see the spring that is inside the gear
Sep 20, 2013 | Xante Ilumina Digital Color Press Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
Hi Sir. I got a problem of my Toshiba e studio 3510c printer, when I swich on the button, the screen shows there is a sentence said ;'disposal of the used tonner', should I replace the wasted...
It said exactly what? If it mentioned waste toner, emptying that tray (Toshiba has nice zero-waste-to-landfill toner recycling program) should have pretty much cleared things up; it appears that the sensor for that still sees lumps of toner..or something...coming up close to the paper path. Check it out carefully and replace the tray.
Sep 10, 2011 | Office Equipment & Supplies
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
