Question about Cerwin Vega Audio Players & Recorders
CV28S SUBWOOFER POPPING HUMMING
CERWIN VEGA CV28S SUBWOOFER POPPING HUMMING IT HAS DONE THIS SINCE I BOUGHT IT AND HAD IT REPLACED NEW 3 TIMES. I AM PULLING MY HAIR OUT IN FRUSTRATION. PLEAS CAN YOU HELP?
SOURCE: Buzzing Cerwin Vega LS-12 Subwoofer
If it's not interference or a ground problem it might be a bad amp. I have the same sub and not only did I have the buzzing, but also a noticable "whacking" sound instead of smooth bass. I found an online seller who at the time just happened to have obtained some surplus Cerwin Vega amps that fit perfectly. Paid $60 shipped. Problem solved.
Posted on Feb 23, 2008
SOURCE: Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Posted on Mar 05, 2008
SOURCE: Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Posted on Dec 08, 2008
jsinex2421
  • 62 Answers
SOURCE: cerwin vega ht-10d subwoofer won't work in yamaha reciever
Actually, I had the same problem with my JBL PB10. It was the cable. I had to buy a one direction shielded rca cable. If you put it in backwards it will not work. The cable was around 75.00. But it was well worth it. The first cable I tried was a cheap sony brand sub rca cable. I ended up buying the AR(Acoustic Research) 15ft. directional subwoofer RCA cable from Best Buy. Make sure you have your receiver set to the proper setting too. If you have it hooked to main, set it to main. If you have it hooked to the L.F.E.(RCA cable) set it on L.F.E.. Some have the option to set to both. If it is a non powered sub a RCA cable will not work. You will have to run your main speaker cables to the sub first, then from the sub to the speakers. It then "piggybacks" the Low Frequency signals from the receiver.
Posted on Jan 08, 2009
SOURCE: subwoofer goes to sleep
It is not getting a strong enough signal.... when you have the sub setting on the receiver to low the sub likes to go into sleep mode..... try turning the sub signal up on the receiver and the sub amp down to get the desired level.
Posted on Feb 27, 2009
Bad plate amp
http://www.parts-express.com/cat/subwoofer-plate-amplifiers/332 Subwoofer Plate Amplifiers
Feb 18, 2014 | Cerwin Vega LW12 Subwoofer
I own a CERWIN-VEGA V-12S 12" Front Firing V
You may have only messed up the crossover circuit. Try changing the crossover frequency and see if hte behavior changes. If so, then the parts cost should be minimal. If the behaviorr remains the same, there will need to be more investigation done internally. This is not a problem that is likely to be easily resolved remotely. Can you update this with your location? I may be able to provide a recommendation for a service shop.
Dan
Jan 05, 2011 | Cerwin Vega V-10S Subwoofer
Cerwin-Vega 12'', no power
It should have a small fuse on the board between the transformer and the board. Check that first. If it is good see if the transformer is putting out any voltage. Two easy fixes that can be done in house...
Jan 01, 2010 | Cerwin Vega LW12 Subwoofer
Humming noise about 3 years old . Just one day hummmmmmmmmm.
It is a problem with output level-defect probably,output IC or output transistors,capacitors etc..
Nov 25, 2009 | Cerwin Vega HTS15A Subwoofer
I have a blown LW12 Cerwin Vega Speaker. Can
You have several ranges of options.
1) Contact Cerwin-Vega customer service: http://www.cerwin-vega.com/
2) Do a google search on "cerwin vega speaker replacement". You will find companies both that offer repair or repair kits (e.g., www.simplyspeakers.com) or sell replacements. Contact them - they have the expertise to tell you which of their products are most suitable for your model.
Nov 01, 2009 | Cerwin Vega LW12 Subwoofer
Cutting on and off
Same thing is happening to my Cerwin Vega 18" sub. Can't find solution at all. Guess I will have to buy a new sub.
Jun 19, 2008 | Cerwin Vega LW12 Subwoofer
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
53 people viewed this question
Top Cerwin Vega Audio Players & Recorders Experts
 Grubhead
Grubhead
Joe Lamb
Joe Lamb
Vito Vacirca Jr.
Are you a Cerwin Vega Audio Player and Recorder Expert? Answer questions, earn points and help others
