Question about Dell Latitude D600 Notebook
Installing new lcd screen delllattituded600 - Dell Latitude D600 Notebook
I can't hear nothing
Posted on May 08, 2009
    Scholar:
  • 82 Answers
Http://support.ap.dell.com/support/edocs/systems/latd600/sm/display.htm#1001090
Remove and replace LCD screen
That is so easy task
remove the tv cover . Then unplug the sockets from the tv boards
then take the screen with frame outside. And remove the feame carefully. By a suitable tool or rigid card so you don't leave wear sigbs at the screen frame
the frame is installed on thr screen by clips.so carefully at the places of the clips the frame will be removed
now install the new lcd sceen at the frame. Press the frame at the clips places untill you hear the sound that it fit on the screen
and install the new screen sockets at same places where the old were installed
important note. Sign tge sockets before installing the new screen. Put number for same socket on the screen and thr tv board. At tge male and tge female plug
May 07, 2015 | Video Cameras
I cracked the screen on my inspiron M5010 so I got a new one and installed it. After installation, the new screen has lines of all colors across the screen. I ran diagnostics and it gave me error code...
I would have the old Video Cable (LCD cable), AND the new Video Cable; checked with a multimeter set to OHM's (1K), for Continuity.
An inexpensive multimeter is about $5 to $12 bucks.
Suggest, take both Video Cables down to the nearest small computer repair shop, and have the resident tech check it for Continuity.
Should only be a couple of bucks.
"But it's a new LCD cable"
So?
New LCD cable checks fine, the problem is;
A) You are not getting the LCD screen side of the LCD Cable, plugged in correctly.
It may seem like it is.
Motherboard side connector isn't the usual male plug connector.
Looks simple to connect, but also in the same instance looks like it may be a problem child to connect.
The LCD screen side connector of the LCD Cable, can be tricky to get plugged in correctly.
It can be loose enough at that connection, that it will not make full contact; and your little peepers will not see it.
(Also needs to be re-taped after connecting to LCD screen)
2) LCD screen replacement could be the wrong one, or is a faulty unit.
3) http://www.ebay.com/itm/New-Dell-Inspiron-N5010-M5010-15R-LCD-video-flex-cable-4K7TX-04K7TX-50-4HH01-101-/400479996437?pt=LH_DefaultDomain_0&hash=item5d3e77ca15
With this LCD Cable it looks as though it may be easy, to Not get the motherboard side of the LCD Cable; plugged in tightly, and correctly.
Post back in a Comment, or Reply; at the end of this solution.
Regards,
joecoolvette
[If you can't get through using the above methods, then post your reply as a Solution.
FixYa has undergone a site change, and it seems certain functions are not working correctly.
After you post as a Solution, Fixya staff can clean it up.....
(They can put is as a Comment or Reply ]
May 07, 2013 | Computers & Internet
How to dismantle lcd of Neo Basic B3362n
A replacement screen maybe available from this WEB site.
www.lcdparts.net
The screen is removed by undoing the hinge screws, careful unclip the video connector from the motherboard.
Keep the screws together as you remove them so you will know which screws are needed to install when you fi the new LCD screen
Undo the screws that hold the bezel that surround the LCD screen, then remove the bezel (it may be also held in place with double sided tape).
When the bezel is removed the LCD screen is secured to the hinge assembly by more screws around the edge of the LCD screen.
When you install the new LCD screen, reverse the order you took in removing the LCD screen.
These WEB sites may assist you in repairing the LCD etc.
Nov 30, 2012 | Computers & Internet
Change sceen
www.lcdparts.net
Replacing Display hinges
http://www.laptopparts101.com/display-screen-hinges/
Laptop repair info
http://www.laptoprepair101.com/
Feb 11, 2012 | Computers & Internet
MY SON BIT UP THE SCREEN ON MY L46WD22 46in LCD
Sorry,the LCD screen panel are limited produce by the tv industries.No where else u able to buy the LCD screen panel,but the tv industries themself.It limited produced and it about 90% of the tv.They will sell the LCD screen panel to u,but they charge u the same as a new tv and labors installing it might even cost more than a new one.Not worth repairing when it involving the LCD screen panel.Sorry ur tv not worth as a whole tv anymore only as salvage electronic's boards parts now.
May 29, 2010 | RCA L42WD22 42 in. LCD Television
Needs a new screen, where do i take it in Minnesota thanks, Jeanne
LCD Screen panel is broken or damage,the tv not worth repairing,because the tvs Corporations produce these LCD Screen panels,are very limited in production of these LCD Screen panels.No where else u will able to buy a LCD screen panel,except the the tvs corporations themselves,yes they well sell the LCD Screen panel to u,but it well cost the same as a new tv.Might even cost more after labors of the installation of the LCD screen panel.Sorry the tv is not worth as a whole tv anymore,now only can be salvage for the electronic's boards for board parts that it.
May 24, 2010 | Vizio GV42L 42 in. LCD Television
42 inch lcd tv.its a rca. the screen is damaged. picture tube is out. how much will it cost?
The cost of a new screen is proportional too the retail value of the tv. When the screen is cracked its overwhelmingly expensive to purchase, then an additional cost to install it. You may want to look into selling that tv for parts. Other than that, you may as well buy a new tv compared to the cost of a new LCD screen.......
Nov 13, 2009 | RCA L42FHD37 42 in. LCD HDTV
JUST REPLEACED LCD R52 AND THE SCREEN IS BLACK
You replaced the broken LCD screen in your laptop with a new screen but it’s not working.
Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
You did some research and purchased a compatible screen, installed it into the laptop, turned it on and… The new screen is not working!!! What could be wrong?
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCDs have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no backlight.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the backlight inside the old screen lights up, apparently the new screen has defective backlight lamp and has to be replaced.
Oct 14, 2009 | IBM ThinkPad R52 Notebook
Dell Inspiron 1526 LCD inverter unable to turn on lamp error message in diagnostics. PC boots up to login user screen and then goes black with the exception of the mouse prompt. It is visible moving...
Go on ebay and buy a new inverter for less than $10. Go on youtube to see how to replace the dell inspiron 1526 lcd inverter or the dell inspiron 1526 lcd screen. I put the lcd screen on because sometimes the problem might be your screen. If things don't work after installing the new inverter board, then buy a new lcd screen off ebay. The inverter board and screen are easy to install. Just go on youtube.com to find a video that walks you through it. The inverter sits at the bottom of the lcd screen. Some are screwed on, some are welded onto the screen, some are held by a small piece of tape. Even if you have to pry the old one off, just put the new on on held by a small piece of tape.
10results for Dell Inspiron 1526 inverter board
Dec 17, 2017 | Dell Inspiron 6400 Notebook
Can I install an LCD screen ?
TRY IT IT SHOULD BE THE SAME CONNECTION IT NEVER HURTS TO TRY ULL GET ONE PLAYING
Jun 27, 2009 | Insignia Pilot MP3 Player
Dell Latitude D600 Notebook Logo
41 people viewed this question
Alun Cox
