Question about Jenn-Air Kitchen Ranges
Remove door from Jenn AIr range S160 - Jenn-Air Kitchen Ranges
VANMAN69
  • 23 Answers
SOURCE: F1-1 error on Jenn-Air Range
if it is the stove that is in the picture the fault codes are in the door under the oven door.
Posted on Jun 02, 2007
aborcass
  • 2651 Answers
SOURCE: Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Posted on Mar 14, 2008
SOURCE: Jenn-Air S160
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
SOURCE: replace digital display for Jenn-Air range
Obviously, safety first. This being an electrical fix, unplug or otherwise disconnect the power to the appliance.
A philips screwdriver and 1/4" nut driver(or socket) are all that's needed.
First, there are 8 fasteners on the underside of the control panel. Only the 4 nearest the oven openning need to be removed from here.
Next, remove the burner knobs for the stovetop(simply pull straight off; if stuck, wrap a folded wash cloth behind the knob to gain extra leverage). Then remove the 4 screws that were behind the knobs.
At this point the panel should be loose and pulling out the bottom of the control panel will allow it to clear the knob shafts. Be careful not to pull too far, as the wires to the control board are rather delicate.
Posted on Feb 27, 2010
SOURCE: I have a Jenn Air S160 stove and the burners
Try switching the grill to the other side if it works the ceramic burner is bad replace the ceramic burner. burners and grill coils unplug when you pull them out. The left one pulls out from the front the right one pulls put from the rear. you can enterchange the burners on either side.
Posted on Dec 16, 2010
I can not remove my jenn air s160 door to replace it
Can only be removed after panels removed first.
Sep 20, 2017 | Ovens
My folks recently purchased a house with a Jenn-Air S160 electric grill-range/oven. The left hand side electric burner cartridge's back burner superheats on the low setting. I've switched the burner...
Sounds like the problem is in the control assy. especially if you switched the burnners and the problem remained. Go to the jenn-air website and see if they have a parts breakdown for your unit.
Record the model number of the unit before you search, you will need that info.
Apr 16, 2011 | Microwave Ovens
How do you take the door apart so that you can clean the glass? We have taken out the 3 screws, but it will not come apart.
i just replaced the glass on a jenn air slide in, remove screw on each side, inside the door, near the hinge, lift door off hinges, remove 3 screws on bottom of door. Trim holding glass should now come off. Remember, hinges are spring loaded.
Dec 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
I have a Jenn Air S160 stove and the burners stopped working. Is there a reset button? The grill does work on one side but the burners do not. Thanks, Pam
Oct 07, 2010 | Jenn-Air Kitchen Ranges
TRYING TO FIND SELF CLEANING DIRECTIONS FOR MY JENN AIR S160
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Aug 31, 2010 | Jenn-Air Kitchen Ranges
We accidentally locked our Jenn Air Slide In and cannot unlock it using other recommended means (pressing oven buttons, disconnect power). Thoughts on how to physically disable lock and/or remove door?
I used a long screwdriver between top of door and top of range. Used a flashlight to see the latch, then pushed the catch out of the way. Probably not the most appropriate way, but it worked!!
Jan 23, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air sce30600 - replace door lock switch
Hi Don, the part you need is 71001129 and is #13 in the attached breakdown. Hope this helps you get it apart.
Nov 08, 2009 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-Air s160 exhaust fan squeals when the stove top is on
The only repair is to replace the fan motor.
Aug 25, 2009 | Jenn-Air Ovens
Jenn-Air S160
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Sep 06, 2008 | Kitchen Ranges
Oven door back on
My Jenn-Air oven door also comes off to clean. To remove the door you just open it slightly (to the first position) and lift the door up. To replace it just pull the hinge out about the same angle (about 15 degrees) and slide the door in place on the hinge levers and close the door.
Apr 29, 2008 | Jenn-Air JGS8750 Gas Kitchen Range
Kitchen Ranges Logo
35 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
