Question about Coleman Powermate Powermate 5000W Generator
Surging 5000w Coleman Generator
It does fine when you first crank it. Once it warms up it surges back and fourth. I took the carb apart and it looked ok. Put it back together same problem. The only time it does not surge is when it has a full load on it. Any help would be appreciated thanks.
  • 27 Answers
I had a Colman that only surged when it had a large load on it. ConsumerReports.org says that some Coleman generators just can't hold a constant voltage. Hondas are expensive but very good,.
Posted on May 08, 2009
    New Friend:
Re. Coleman Powermate 5000 Watt Generator (surging)
Apparently, no one has a solution for this. I have been fighting this "piece" of equipment since the day I bought it. At first I had to spray gas into it to even get it started. After a new carburator, valve job, spark plug, new head head gasket, and new governor spring, it now starts after a couple pulls but still surges terribley. I am at my witts end and refuse to put more money into it. It's only good enough to run a couple of lights, just can't trust it to run and or ruin a refridgerator. Sadly disappointed in this so called generator.
DT, South Dakota
Posted on Jun 24, 2013
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Hr 42 stuck slide.
Sounds like you still have some kind of fastener in there. Be careful. It also sounds like the slide is exposed and perhaps what ever it is covering can't be fully seen. I would try to google an exploded view. If you can't find one see if you can buy a new carburetor kit. if you have taken it all apart you should replace all the gaskets and "O"rings anyway, even if the carb was never installed. Are you using carburetor cleaner? if you are you may have caused some of the O rings to swell. A new carburetor kit will come with a detailed exploded view. If there is something holding it, you will be able to see it.
Best of luck
Ray
Apr 28, 2014 | 2000 Harley Davidson FLSTC Heritage...
Does anyone have a solution to the surging problem?
Is it surging under load or not? Surging is generally fuel related and can be a multitude of reasons, most likely in the carb if it has sat. It can also be binding or sticking governor arm, make sure it is free to move, and you have the correct weight oil and level in it.
Jun 24, 2013 | Coleman Powermate Powermate 5000W...
I have a super pocket bike x 7 110cc kick start and electric start my carb was leaking bad from the overflow i took the carb apart and cleaned it jets to and put it all back together overflow dose not leak...
hey Steve, you put the carb back together incorrectly somewhere.. take it to a qualified professional, let him check it and reassemble it... it wil be fine after doing this... --Check the air filter.. make sure its clean...
Jul 26, 2017 | Motorcycles
Harley wont start and has fuel running out of the exhaust and Carb
Hi Ken, you need to overhaul your carburetor, for more information about your question please visit the website below. Good luck and have nice day.
Harley Davidson CV Carburator rebuild and float adjustment ep 18 eng Roma...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Mar 18, 2012 | 2002 Harley Davidson FLSTC - FLSTCI...
Have a 08 sportsman 500 HO. Can get gas to fuel pump but not to carb. Cleaned carb wtih carb cleaner, put back together and it fired for a second.( leftover carb cleaner I'm sure) Tried to start...
I was just working on an 08. They have a vacuum operated fuel pump. All of the dealers I spoke with said that a fuel pump going bad is uncommon. I would check to see if the vacuum line is craked. When you take the inlet gas line from the carb and turn it over, you should get a pulsating flow of fuel. Again, check vacuum hose first then assume the fuel pump.
Jan 27, 2011 | Polaris ATV
Coleman Powermate 5000w generator sputters
you dont say if diesel / petrol.
if petrol check the choke mechanisim.
if diesel injector may need cleaning or re setting
Mar 17, 2010 | Coleman Powermate Powermate 5000W...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
Coleman Powermate Powermate 5000W Generator Logo
1,051 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
