Question about Whirlpool WFE361LV Electric Range
How to replace stovetop elements on whirlpool wfe361lvb
I have a whirlpool electric stovetop and oven! The top works fine but the bottom heat wont adjust and stays at 350!! Any suggestions?
is it that it does not maintain the exact temperature or doesn't it heat up at all? If you have exposed elements, try swapping the elements between the top and the bottom. If the bottom still does not work, it could be the thermostat. Can you give more info on model number and brand. That will get you better answers.
Regard
Jan 02, 2015 | Kitchen Ranges
Stovetop heating elements turn off and on intermittently. They don't stay on.
The heating elements on an electric stovetop are controlled be a control called a reohstat. The reohstat regulates the temperature to the elements and as such they do cycle on and off during use. If you turned the control to low and the element stayed on all the time it would get too hot and burn what you're cooking.
Feb 06, 2011 | Kitchen Ranges
Stove top or oven does not work however, clock
check your 220v outlet, you could have 110v and not the needed 220v to operate the elements. If you only have 110v at the outlet the one side of the double breaker is bad
Apr 28, 2010 | Whirlpool RF364 Electric Kitchen Range
How to replace an element on a electric free standing flattop
If it a coil type element, all you need to do is identify where the leads from the coil go into the socket underneath the lid of the stovetop. You'll be able to see it from the top. Once you have identified that spot, lift the burner opposite of the leads just enough to clear the pan, and pull away from the socket.
Best regards, --W/D--
Jul 28, 2009 | Whirlpool Kitchen Ranges
Crooked stovetop burners
This happens when purchasing pans/bowls from home depot ect..., there are so many different shapes and models you never get the right ones. Order new bowls online with your model number located behind oven door to get the correct size and the elements should be fine.
Phil
Apr 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool Electric Stovetop Repair Issue
no replacement only option or use as is shouldn't cause and problems
Nov 26, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
nothing you can do short of replacing top, which depending on age may be a cost prohibitve option
Nov 26, 2008 | Kitchen Ranges
Whirlpool WFE361LV Electric Range Logo
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
