Question about Vacuums
Nilfisk extreme 150 engine stops
Engine suddenly stopped working, even with all lights on. Middle light stays on and flashing
2 Suggested Answers
EwingElect
  • 276 Answers
SOURCE: I have just purchased a
If you're just purchased it I suggest you need to check where your local Warranty Agent is and take it there for a service. Since this model has an electronic switch (do the lights flash on and the middle one stays green when powered on at the power point?) you may need to get that checked out.
BTW there is a motor protect fuse that shuts the motor off if it overheats. Once the motor cools down it should have been fine. Check for blockages in the hose as sometimes things get stuck in the handle.
Posted on Feb 24, 2009
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
Lights on front of unit stopped working and a little while later the whole unit stopped working while in the middle of vacuuming
Take it to a qualified repair facility. Even as there isnt to much to a vacum let the tech check it out. Could be a faulty switch or controls. I dont think its a serviceable by homeowner problem.
Dec 20, 2013 | Kenmore Vacuums
Change front wheel on x300
The front wheel on a Nilfisk Extreme 300 is changed by removing the 3 screws inside the bag chamber. From memory they are a torx screw driver size 15 or 20. Basically remove the bag and take out the 3 screws in the middle of the chamber - the wheel will fall off once you lift the machine up. If you need to buy a replacement wheel you can find one here.
Nov 10, 2013 | Nilfisk 11730410 Micro Filter Polyester,...
Nilfisk Extreme 300 does not always respond to the remote trigger on the handle
The Nilfisk X300 has a battery in the handle piece it would be worth simply replacing the battery. If that does not solve it you may need a new Nilfisk X300 Handle. It is possible that it is the receiver i teh machine but to be honest these are a pretty hard machine to work on and the circuit boards are all interconnected, this is a repair for an experienced player.
Sep 03, 2011 | Nilfisk Vacuums
How do you change the dust bag on the Nilfisk King 505?
Press the middle rectangular Nilfisk button in the top centre of the machine. The front cover will fold down. There is a greay retaining bracket which clips forward off the top of the old bag. Fold that forward, replace the bag, clip the holder back on, and then close the lid.
May 20, 2010 | Vacuums
My Nilfisk vacuum cleaner overheating and stopping
Its probably clogged..
Remove the hose,, straghten it out so you can look into it..
Could be clogged where the hose connects inside the unit..
Jul 26, 2009 | Vacuums
Not working,need assistance from anybody or cheap parts.thanks
sounds like the trigger switch is stuck.try to spray a little wd40 up into the switch and work it ,maybe it will free up.if not the switch is probably bad
Apr 29, 2009 | Vacuums
I have just purchased a new Nilfisk vaccuum cleaner 150 extreme and used it for 5 minutes and switched it offf. When I tried to restart the machine it would not start. I cannotg et it to restart-how to i...
Jan 31, 2009 | Vacuums
My filters? need cleaning
most likely the hose is blocked, drop a coin down it to confirm. You are best to replace the filters, they are not very expensive; though they are not likely to be the cause of your nilfisk over heating
Sep 26, 2008 | Nilfisk Family Vac Bagged Canister Vacuum
Motor and Lights stopped suddenly after vacuuming the stairs.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19809&thid=745467
Motor and Lights stopped suddenly after vacuuming...
Posted by Brigham81 on Jul 05, 2008
I was vacuuming the stairs, and all of a sudden the light went out and the motor stopped. Is it possible to overheat it, or blow a fuse? Thanks, Brigham
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Oreck XL2200 Bagged Upright Vacuum. It sounds to me that when the lights go out and it stops working that the motor is bad that you would have to replace the motor. It is still cheaper to replace the motor than to purchase a new vacuum. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 05, 2008 | Oreck XL2200 Bagged Upright Vacuum
Vacuums Logo
24 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
