Question about Hitachi C8FSHE 8-1/2-Inch Sliding Compound Miter Saw with Laser Marker
Wiring diagram for Hitachi switch c8fb2 - Hitachi C8FSHE 8-1/2-Inch Sliding Compound Miter Saw with Laser Marker
How do I replace the linear ball bearing on a c8fb2 Hitachi miter saw
Its not too difficult:
1) There are 2 retainer pins located on the rear slide support (#4 on breakdown) - carefully drive these out with a punch - be careful to support the bracket so you don't break it.
2) remove the rear support and slide the saw head and arms out of the bearing.
3) Remove the 2 covers (front and rear) over the bearing
4) loosen the allen head set screw on the housing that holds the bearing in place
5) using a large socket and a plastic hammer - gently tap out the old bearing.
Reverse process to replace.
Do not use grease or oil on the bearing or slides - use a pure, clear silicone spray that dries completely - grease & oil attract & hold dirt and debris and will cause bearing failure.
Hitachi C8FB2 8 1 2 Twin Rail Sliding Compound Miter Saw Parts
Feb 14, 2015 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
My hitachi c8fb2 saw won't turn off
It sounds like your switch has a short circuit. It is quite unusual for this to happen and due to the nature of the fault I would highly advise not using the saw until it is sorted. If you are uneasy about working on the electrical parts of this you can find your nearest service agent on their website. Hitachi service page, put ypur postcode in the box on the top right.
Apr 14, 2013 | Hitachi Power Tools 8-1/2" SLIDE COMPOUND...
How do i remove (and replace) the carbon brushes on a hitachi c8fb2 moter saw? I removed the brush caps and can pull on the springs but not moving. DO i just pull harder? I'm afraid to break it in there.
After removing the black brush caps, take compressed air and blow any debris out. Next take a pair of needle nose pliers and gently pull the brush,,, ( you can use a moderate force). If it does not pull out you may need to remove the black vent cover adjacent and use a tiny screwdriver between the brush and the armature, as there may be a slight burr on the brush. Good Luck.
Dec 21, 2010 | Hitachi 8-1/2" Sliding Compound Miter Saw...
I need wiring diagram for EC-12 preasure switch email address: mresnak@hotmail.com THANX
Just hook the black (gnd) wire to one screw and the white (signal) wire to the other. You should crimp ring connectors on the end of the wires for a good connection. The red (+5v) wire is unused.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/hitachi/EC12
Aug 12, 2010 | Hitachi Air Tools & Compressors
I need Hitachi RUA-30AT3S wiring diagram. This is a self contained air conditioner. Rats damaged all wires while it was in store. I have no clue about re-wiring.
FSM Forums • View topic - Hitachi Air Conditioner ManualsHitachi Air Conditioner Manuals - looking for Operations & Maintenance Manuals, ... RUA 30AT3S (Package 30 Tons) RUA10AT3S (Package 10 tons) ...
www.manual-directory.com/forum/viewtopic.php?f=10&t=2453...0 Hi, although your unit is a 2 1/2 ton, you will be able to get a manual showing you the correct wiring diagram using the model number you supplied. It shows your model above. This is the only way to get a diagram for this unit. Please keep me posted on the out come or if you need more help.
Sincerely,
Shastalaker7
Apr 03, 2010 | Heating & Cooling
I have a Hitachi C8FB2 compound miter saw that the electrical break has stopped working on. The bushings are still good but I see and hear a electrical arc were the bushings touch the shaft. What can I do...
there is always going to be some sparking between the BRUSHES and the commutator. if it is excessive and loud or is really heating up the housing, there could be a crack in one of the brushes, the brush might be chipped or unevenly worn, or the brush holder itself may be burned cracked, or otherwise need to be replaced. they may LOOK okay but need to be pulled out to really know for sure sometimes. there is a small set screw in the housing that holds the brushholder in place.
while this could be the problem with the electric brake, it is more likely that there is a wiring connection loose, broken or burned inside the motor housing. it could be the switch but i dont believe the brake circuit runs through the switch on this model.
Dec 13, 2009 | Hitachi C8FSHE 8-1/2-Inch Sliding Compound...
I need a wiring diagram for my hitachi plasma 42 inch tv
you can get this from the factory website at Hitachi.com
Dec 02, 2009 | Hitachi 43FDX01B TV
Need wiring diagram for the box on the outside of the motor.
white from cord to B. grey from stator to A. blue from brush holder and red from switch to C!
Mar 25, 2009 | Hitachi C10FSB 10" Sliding Dual Compound...
Hitachi c10fr table saw wiring diagram
Here is a hand drawn diagram
Please rate this a fixya
Feb 13, 2009 | Hitachi 10", Table Saw with Stand,...
Hitachi C8FSHE 8-1/2-Inch Sliding Compound Miter Saw with Laser Marker Logo
113 people viewed this question
Top Hitachi Saws Experts
John Trevino
JOHN LAPIER
Are you a Hitachi Saw Expert? Answer questions, earn points and help others
