Question about Refrigerators
GE Refrigerator external fan - air flow?
I have GE TBX16JAZ refrigerator. In what direction is refrigerator external fan (located at the rear bottom) supposed to blow air? Right now fan is pulling hot air out and not blowing cold air towards the fins. Is this the direction the air is suppose to flow?
Shouldn’t fan work differently and blow cold air towards compressor and fins?
At thermostat position 3 – refrigerator turns on every 17-18 minutes and runs about the same time 18 minutes. Is this normal?
Thank you.
Jason
  • Refrigerators Master
  • 1,150 Answers
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
Posted on May 09, 2009
Fridge too warm
It is likely to be either the circulation fan in the freezer or the defrost element. The cold air is blown from the freezer into the fridge if the fan doesn't work then no cold in fridge( actually I think there are 2 fans in these, 1 horizontal 1 vertical) otherwise it could be a defrost problem, if the element doesn't work the rear fills up with ice and the air cant flow. Both are behind the rear panel of the freezer
Jul 08, 2013 | GE Energy Star PDS22SIS Stainless Steel...
I have a GE Profile PDS22MCR bottom freezer. The freezer is getting colder and the fridge is getting warmer....... What could this be?
your damper assy isn't opening to allow cold air from the freezer up into the refrigerator,its located on the rear wall in the refrigerator compartment,you need to make sure theres a fan running in the freezer,then if so you should feel cold air blowing up in the refrigerator compartment,remove this panel and see if its shut,if no air is felt then the damper door is either broken or jammed shut or if its o.k.,then your control board in the rear of the unit could be defective not letting power to the damper door or even on of your thermistors in the side walls of the refrigerator that monitor temps in the refrigerator and freezer could be defective
Sep 28, 2012 | GE PDS22MCR Bottom Freezer Refrigerator
GE model 25 - 6 years old - Top part of fridge and freezer not cooling. compressor seems to be working fine. Bottom part of freezer is very cold and bottom part of fridge is freezing everything. Appears to...
It sounds like the damper assembly might have failed or be stuck open. The damper is mounted in the left side upper rear corner of the refrigerator section. The damper controls the amount of cold air that comes into the refrigerator section from the freezer.
If you want to repair the refrigerator yourself you should disconnect the power to the refrigerator and remove the 2 screws holding the damper cover to the center wall. Sometimes you can spray the damper with WD40 and free it up.
Jan 30, 2011 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not working ,refrigerator warm
The problem is most likely either the defrost timer, and/or the defrost heater element(s) are faulty. The problem is that the defrost heater elements are not functioning properly and the evaporator core is actually freezing up and blocking the air flow through the evaporator core and also freezing up the thermal sensor, and when that happens there is no longer enough cold air being circulated through the refrigerator (that is actually how the unit operates and air must be able to flow through the evaporator core and then be circulated throughout the refrigerator to properly function) and as a result the refrigerator stops functioning and food can even thaw out in the freezer although the freezer seems to be iced up. (Usually at the rear wall where the evaporator core is located)
(Air flow through the evaporator core and cold air circulation and re-circulation through the refrigerator is performed by the air circulation fan and it also must be functioning)
Be sure to only use a blow dryer (with a towel on the bottom of the freezer) to thaw out the evaporator core and do not use any hard or sharp objects or the evaporator core can be damaged. The defrost timer can be located inside of the refrigerator itself, (see lower image) or it can be mounted outside usually either behind the air intake cowl or kick panel at the front base of the refrigerator, or most likely located behind the service panel on the rear of the refrigerator, and usually if the defrost timer is turning then it is most likely working, however the defrost timer can move very slowly and you can place a mark on the timer and the housing to check after about fifteen minutes to see if the position on the defrost timer has changed. The deforst timer on newer digital models can be built into the circuit board and is not a seperate timer mechanism.
Here are some images that should be similar to your situation to help assist you, and let me know if you require any further assistance.
Sep 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a bottom freezer refrigerator and the freezer works but the fridge does not,,condensation forms on bottom of fridge. What is going on?
Check in the inside rear of the refrigerator cabinet for vents.When you hear the compressor running, wet your fingers and hold them in frontof the vent to check for air flow.
If it seems there is none, then the fan that is supposed to distribute the coldair from the freezer is no longer running.
If this is true, go to the Sears parts department and enter makeand model number to see if they have a line drawing illustration of your unit.
This will allow you to see if this fan is accessible enough for youto DIY or if you need a pro.
Sears partsdepartment
Good luck-
Jun 19, 2010 | GE Profile PDS22MHR Bottom Freezer...
My GE side by side refrigerator isn't working right. The freezer works great, but I can't get any coldness on the refrigerator side. Even at the highest cold setting.
Check your air door at the top left rear of your refrigerator side. If no air is flowing try opening it by hand while you are there. Also check the freezer for a fan sound to be sure your fan isnt stuck or dead.
Mar 14, 2010 | GE GSL22JFPBS Side by Side Refrigerator
GE GSS20IEPHWW side-by-side refrigerator stopped cooling
First off, when the fans are both running, the compressor should also be running. Sometimes, because they run quietly, it is difficult to tell if they are running. Touch the compressor to feel for heat and / or vibration to confirm running. (if the compressor gets too hot, the overload will stop it until the compressor cools down. That could happen with too low or too high voltage, even with the cooling fan running) You did not say how long you let the unit defrost. To properly defrost it, you should empty out the freezer side, remove the shelves, and take the metal cover off the back inside wall of the freezer. Then, use a hair dryer to melt all the frost off. If the coils were blocked with frost, you probably have a burnt out defrost heater (located at the bottom of the cooling coils) when replacing the defrost heater, use part number WR51X10101 and follow directions, as it may have a different configuration than the original heater. A frost blocked evaporator (coils inside the freezer) will stop normal air circulation inside the refrigerator. Cold air will then be able to flow backward, into the bottom of the refrigerator side through the normal return air duct located at the bottom of the refrig / freezer divider. This cold air can freeze the water line or water reservoir located there. There for, solving your defrost issue most likely will also solve your water line freeze issue.
Nov 21, 2009 | Refrigerators
Refrigerator not cool freezer working
Rick,
This is the generic answer. Use the hair dryer (below) and reset the defrost (look for instructions from Sea Breeze)
Most of these units work with the freezer providing all of the cooling and a thermostat in the refrigerator section controlling a fan in the freezer (where the fan directs cold air from the freezer section to the refrigerator section via a duct in the back).
Look at the rear area of the refirgerator and locate a vent. This vent receives cold air from the freezer to the refirgerator. If you feel cold air coming out of this vent, then there may be no problem, just wait a few hours and recheck the refrigerator temperature.
Look at the rear area of the freezer and locate a vent. This vent provides cold air from the freezer to the refirgerator. Shine a bright light into this vent. You should see fan blades (possibly black plastic). If there is ice on the blades, then you have a defrost problem, and look to other posts on this site for how to manually defrost (or reset the automatic defrost). If the fan blades are rotating, then there is probably a blockage in the duct. Direct a hair dryer (warm setting) through the rear freezer vent and check to see if there is very warm air flowing out of the refrigerator vent (which indicates that the duct is not blocked). While using the hair dryer, you may be able to see the fan blades rotating.
If you do not feel warm air flowing out of the refrigerator vent, then run the hair dryer for a few minutes. (this was my problem, I saw no moisture drip from the vent, which led me to believe that it was more of a dry ice buildup, or that the ice was evaporated (desublimed to be technical).
If there is air flow and no ice buildup on the fan, then reset the automatic defrost. If this is not your solution, either the thermostat or the fan motor is the problem.
KWJ
Jun 22, 2009 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Maytag MSD2655HEB cold in bottom, no air flow
No air flow at all means Fan is not working. Also check damper between freezer and fridge.
Oct 11, 2017 | GE (GTS16BBS) Top Freezer Refrigerator
GE SIde By Side - No cold air on the freezer side.
Do you hear fan running in freezer? Should be on when you hear that external fan. If not, you may need an evaporator fan motor. Also check board in back for burned resistor. May need to replace both.
If that fan IS running, remove lower rear wall of freezer and inspect the defrost heater. It's at bottom of coils. It has a wire leading to both sides. Remove with 2 screws and check for continuity. If open replace defrost heater. This is a common failure on these.
Nov 18, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
354 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
