Question about Python Vehicle Parts & Accessories
Python 4211P wiring - Python Vehicle Parts & Accessories
Trying to disable a python 504 d system 70 from old corvette
did you remove the wiring yet? best I can suggest without knowing year of corvette is to trace unit wiring to car wiring and disconnect...then reconnect stock wiring...
Jun 25, 2016 | Python Vehicle Parts & Accessories
Where to tie in the H2/21 wire turbo timer mode on a python 594
First you need to tell us what car you connecting the alarm to. But google the car and where the wire locations are for alarm hook up.
Apr 13, 2014 | Responder 594 HD SST with Remote Start
Python car starter
Can you remove the python box without removing the wiring? That'd be a pretty definitive way of determining if the relays inside the python box are bad. On another note, this sounds like an ignition switch issue, the python box could just be coincidental.
Sorry, not much help... but see if you can eliminate the python box. That's the diagnostic process with electrical is to remove possible causes and record the results. Next, you might consider unplugging the wire harness from the ignition switch... or remove the wire harness that leads up the steering column.
Oct 16, 2013 | Vehicle Parts & Accessories
I got a 95 chrysler seabring and it wont start, I took it to chysler and they cant find the problem, someone said it could be the python car starter, how can I get it off or over ride it
under the dash there is a black/red wire, this is your starter wire, there might be a starter kill relay line line with this wire, unplug the relay and run a jumper wire from pin 30 to pin 87, this will bypass the relay
Feb 22, 2010 | 1401 Remote Start/Keyless Entry System
Python 990 isnt locking or unlocking my doors .
Its going to be either the wires going to the locks or the programming in the alarm. The only way to tell is to get the wiring tested. A plug could have just pulled out also. Do many variances for one straight answer.
Jun 04, 2009 | DEI Python 990 2-Way Security...
Vehicle Parts & Accessories Logo
Top Python Vehicle Parts & Accessories Experts
rjivaro
Kevin Daniels
Are you a Python Vehicle Part and Accessory Expert? Answer questions, earn points and help others
