Question about Arrow No. ET100 Electric Heavy Duty Nail Gun
Stopped working won't do anything tried new nails looked for jambs nothing seems wrong check new power site
Samsung dryer without power
What is the model number??
Jun 27, 2013 | Samsung Dryers
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
My new porter cable RN175B nail gun won't discharge a nail
If the trigger is set to single fire, you will need to place the gun against the work then pull trigger as you have done. Try setting the trigger to bump fire and try again. If hear a thump inside the gun, remove the head and check that the head valve in not stuck from lack of lubrication. Easy test, remove the nails, remove trigger pin, remove trigger and manually push trigger firing valve. If the gun fires then suspect faulty trigger or safety arm not lifting enought to activate the trigger valve. Good luck
Nov 21, 2012 | Air Tools & Compressors
My Casio Privia PX-330BK Keyboard won't turn on.
Try checking your power cord. Perhaps someone stepped on it and it pulled out. It happened to me once. I thought something was terribly wrong with it. I was pretty embarrassed to find out that I'd just cut off power via cable... check your cords before worrying too much. If nothing seems to be wrong, take it in to the repair shop.
Sep 12, 2012 | Casio Privia Px330 Px-330 88 Key Digital...
My canon pixma mx320 won't feed paper properly it seems to grab one side of paper and feeds it crooked then stops
When the paper does not feed straight, dirty or stickyrollers can cause it to jamb or crinkle, also failure to remove all traces ofpaper from a previous paper jamb will cause further paper jambs.
Check for tiny pieces of at the edges of the rollers, and remove these piecesof paper. The rollers may be dirty or sticky and causes the paper tonot feed straight.
Try cleaning the rollers with methylated spirits.
Jul 26, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Paslode IM250 16 straight finish nailer, Fully charged battery, Green Light on, depress tip to start, fan does not start and unable to drive nails.
have you checked for a nail jamb, I've had this happen before on mine, It will jamb with the Piston part way out, have to release nails, and unsnap end and dig out nail with small screwdriver
Apr 20, 2011 | Garden
I have a 52" Quasar
Could be anythings wrong with it,must hire a tv Tech.to troubleshoot and repair.Because doesn't know the causes and the problems was in storage 5 years ago.Tries check all cales wires plugs in connections are tightly connected and no loose connections wires on those PCB boards,might help make the tv it work again.
Dec 07, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I hit a curb accidently and now the chair is dead
there is a inline fuseable link located on the posative battery cable it can get loose and still look like there is nothing wrong,that was what was wrong on my chair. I was very lucky to find it(i found it by sheer chance, I was leaning against it and noticed the light goin on and off,Holy light display batman!) just my lucky day I guess.so I say Check ALL FUSES!!!even ones hiden under tape or shrink wrap. Hey Good Luck to all and keep the paint up and the rubber down....zoooooom....
J Olaf
Oct 15, 2009 | Pride Mobility Products Jazzy Select 14 XL...
Nailer piston won't retract far enough
the rubber cap just pulls off. maybe a screw driver to pry it first but it does just pop off.
As for oil, Always use what the manufacture recommends. But in the case you can figure that out, use a low viscos oil, maybe a standard 3-1 will do in most cases.
Also WD-40 works well.
May 30, 2009 | Porter Cable 2" Flooring Cleat Nailer...
Arrow No. ET100 Electric Heavy Duty Nail Gun Logo
71 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
