Question about U-Line Wine Captain (2015WC) Wine Cooler
Door seal on a uline 29bwc needs replacing - U-Line Wine Captain (2015WC) Wine Cooler
3 Suggested Answers
  • 286 Answers
SOURCE: Uline Icemaker has dammaged gasket door
no, you will need to replace the gasket. U-line gasket is easy to install. You can visit their website and under customer service you will see parts locator. The gasket just pulls out of the track and the new one pushes back in the track. www.u-line.com
Posted on Jun 01, 2009
kel1guy2002
  • 3740 Answers
SOURCE: No instructions for installing new seal on door
Service and parts manual is here.
http://stroboflash.com/searayproject/Docs/U%20LINE%20Service%20Manual.pdf
The procedure is as stated in solution 1 by expert Ironfist. The older units had a metal plate with screws that you had to loosed the screws in the retaining plate by peeling the gasket in the opposite direction without tearing it to loosen or tighten the screws on the retaining plate. Then you just lifted the gasket off. When you go to reinstall as previusly stated by the other expert... start in the top center and work to the corners. Make the coners fit before moving down either side to the bottom corners. Again make the lower corners fit and finally install the gasket across the bottom. Once installed rub the gasket mounting area smooth with one finger or thumb.
You have humbled and hornored me with your request. If there is something that your really having difficulty with once you start this gasket change just repsond here and I will get back to you ASAP but, we will complete the task!
Thanks again,
Kelly
Posted on Jun 28, 2011
Need to replace circuit board, how do i?
take screws out pull old board out put new one in
May 24, 2014 | ULINE U-Line 2175BEVCS-00 2000 Series 24"...
No instructions for installing new seal on door (Uline 75WC Wine cooler
Thanks again,
Kelly
Jun 28, 2011 | U-Line Uline Origins Series...
Uline icemaker on boat needs service..
first do a good cleaning as the manual describe.
check water supply and if still the problem, check power to cutter grid
should be 9 volts all the time
Oct 02, 2009 | U-Line Uline Origins Series...
Describe your uline wine cooler Problem ULINE WC2015: Light comes on but unit won't run. Cleaned as discussed in owners manual. Need help!
OK if you have a 20 series and you have a light and no fan or compressor then you need a thermostat. This will have 2 wires to it and if you bypass the thermostat the unit should run. If it does then replace the thermostat
Jul 18, 2009 | U-Line Wine Captain (2015WC) Wine Cooler
DOES NOT GET COLD AANY MORE, BUT COMPRESSOR RUNS
is the condenser clean? Is the fan running? If so and the condenser is not getting hot then you need a service tech to look at the sealed system
Jun 25, 2009 | U-Line Uline Origins Series...
Uline beverage fridge loose door handle.
Hi
You are right. The only way to repair this is by replacing the complete door assembly. If under a year it should be covered.
Jun 06, 2009 | Refrigerators
The door to my under the counter uline frig/icemaker doesnt shut good..It wont stay on the bottom hinge..
The hole on the bottom of the door might be cracked. What model is it? you might need a bushing for the door.
Mar 30, 2009 | U-Line Uline Origins Series...
Mar 18, 2009 | U-Line Uline Origins Series...
Uline 2075WCS not cooling
Hi!! I'm a uline authorize servicer and yes the repair man is right. you have a leak in the evaporator..remember make sure to call uline ans see if you have warranty on your seal system of the wine cooler..good luck..
Jan 03, 2009 | U-Line 15WC Wine Cooler
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
27 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
