Question about HP Color LaserJet 8550dn Printer
Labels only jam when printing from file
HP Lasejet 8550 I am trying to print a label and the label gets jammed on the transfer drum every time, but it will print fine with no problem on the same label media when printing the configuration page. To sum it up, I try to print from my computer on the label media it jams, print from the same file on regular paper, prints fine. But will print configuration page on the same label media that jams when printing from a file.
  • bigtexbanner May 08, 2009
    These are high dollar thermal labels, $125.00 for 250 of them, had you read the post the printer will print on the label media when printing the configuration page from the printer. The media only jams when printing from file.
    Thanks Master Rod(for what I have no idea)
    I can print the labels just fine now from another tray. Something must be wrong with tray 1, I have printed these same labels before with no problem, and as I said tray 1 will print on the label media if I print a configuration page, but not from a file. Master Rod, if you plan on being a good service tech, the first thing you must master is fully understanding the problem and not jumping to conclusions. Where you got the idea I was using cheap inkjet labels baffles me, and your smart #@s reply was unnecessary. I don't know about being a master, but you are definitely a ROD!
    Problem Solver:
  • 7 Answers
I cannnnoooooottt believe what I am reading! If you are going to use labels on a laserjet, you need to get thermal labels! The other cheap labels are made for inkjets, matric, or daisywheel printers. The laserjets have heat rollers that will melt plastic. It will melt the gum on the non thermal labels and get them everywhere!!
Master Rod
Posted on May 08, 2009
  • Rod Donovan
    Rod Donovan May 11, 2009
    Hmmm $125 for 250 labels?! You got jipped! Try a different type label from another manufacturer. Please do not pay over $10 -$20 for them. Ceteras paribas (all things being equal) if you can print a configuration page with your labels, there is no reason that you should not be able to print from a file. I hope it is text that you are printing on the labels. If you cover 3/4 of each label with graphics or just a black background, it is possible that the attraction from the drum to toner may dislodge the label. I find it hard to believe that the labels are getting stuck to the drum instead of the fixing (heating) unit that melts the toner to the paper.
    Master Rod
When printing labels (Avery 5160) the labels start being shredded half way through and then the printer jams.
Have you setted up in the printer driver to print on label? the printer will automatically adjust the internal parts for printing on a higher density paper!
If you done it gently remove the Duplexer unit from the behind of the printer and chech for pieces of paper or everything could cause the paper jam!
Hope you found it useful, for futher questions i'm here :)
Dec 07, 2015 | HP Officejet Pro 8610 Inkjet Multifunction...
How do I align the HP Laserjet 1020 to print straight? Its printing crooked every time. No two sheets are in the same position
Most likely to be a page feed problem, look online to clean page feeder rubber rollers.
Try here for the pdf manual which covers problem with jams and skewing
http://www.hp.com/ctg/Manual/c00264334.pdf
Mar 05, 2015 | HP LaserJet 1020 Printer
Own three CP3525dn's (purchased new). Two have recently begun jamming [fuser wrap] when printing labels. If it doesn't jam then the paper usually "dog ears" coming out. New fuser did not...
Over time, printing labels builds up a light residue of the adhesive (due to heat pressing) used on the labels in the paper path. A thorough cleaning of all paper path parts with alcohol prep pads, or Glass Plus and quality paper towels, will reduce this gum build up.
You should regularly print standard paper jobs on a laser printer that will be printing labels. Rule of thumb is 4:1 - four sheets of regular paper print for each sheet of labels printed. This helps keep the adhesive cleaned out of the paper path.
Patience and a lot of scrubbing should do the trick, though you may have to install a printer maintenance kit early given the issues noted. Printing labels cuts maintenance kit duration in half, at a minimum.
Jul 06, 2011 | HP CP3525DN Color LaserJet Printer
I am trying to print a label through the document feeder and keep receiving error messages on my Brother MFC9320CW AllInOne Printer .."Open the Top cover and pull out all 4 drum units completely and...
Try putting more than one sheet of labels in the paper tray. Even if you're printing one label, it helps the printer grab the paper without that error somehow. If you're already using more than one sheet, I don't know. Good luck either way!!! :)
Jan 18, 2011 | Office Equipment & Supplies
Problem printing labels
These labels are supposed to be for laser or inkjet . A inkjet basically sprays the ink to print. A laser deposits plastic powder and then uses heat to melt it or fuse it to the paper. To get a good inkjet print you need a softwaer paper, to get a good laser print you want a harder paper and a glue that can handle the heat. I had a quick look at customer complaints on that product and you are not alone. Either the printing is coming off (inkjet) or the label is coming off inside the printer.
One of the other problems with labels in lasers can also be how the paper is printed. The paper can be rolled around a few rollers and drums. This action can be pretty close to how you peel the labels off of the backer sheet. Add a bit of heat to make the glue loosen up a bit and you get your problem.
Setting to thicker paper should have helped but the best thing you could do is print it flat. Most laser printers have a back tray that is usually closed. When opened the tray lets the paper come out without having to go around rollers. If your model doesn't do that about the only thing I could suggest is to try to print the labels on a cold printer. So that would mean one page or so at a time with a wait for it to cool down. You could also try a differant brand or another avery type but you may end up with a label collection if they prove to have the same problem with your printer.
Apr 19, 2010 | Brother DCP-7020 All-In-One Laser Printer
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
My HP LaserJet 2430dtn Paper jam
Try this, make a print from the by-pass tray, does it go OK or jam??
If it jams then there is a problem with the paper feed from the tray.
If it jams then
1-check the drum and see if there is an image on it( you can put a mark on the edge to see if it's rotating, thus eliminating the drum unit)
2-same for the reg roller
3-check for labels ar foreign objects
Oct 08, 2008 | HP LaserJet 2430dtn Printer
Blue color smears on every page
If you're still getting smudges, there must still be a label or part of a label either on one of the image drums or the transfer belt, i've found in the past it somethings gets stuck inside the unit on the cleaning blade. What i suggest is you run a print and open the front door at the paper travels along the transfer belt, look at all the image drums and see if you can see the smudge on one of them, if so the problem is caused by that cartridge if not it's in the transfer belt somewhere. You may need to try stopping the printer a few times and if the problem is in one of the cartridges, you will mst likely have to replace it, as with the transfer belt if you think that's causing the problem it's easier to remove it and rotate the belt manually.
Please note the image drums and the transfer belt are all light sensative
Sep 02, 2008 | HP Color LaserJet 2600n Printer
Consistantly Intermittent Connection Problems
If you've tried installing the latest drivers and the problem persists it sounds like you have a lemon. The printers have a 2 yr warranty, so I would contact the retailer you purchased from and replace the printer. If your labels are jamming. Try the compatible File Labels available at LabelValue.com. They have both the Dymo 30327 and Dymo 30277 labels in a compatible version.
Feb 29, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
HP Color LaserJet 8550dn Printer Logo
230 people viewed this question
Seeker5211
Seeker5211
