Screen has curves
60" rear projection philpis. Quailty is poor and the left side of the screen is messed up. It has a wave in it. It is almost like if a line should be strait, in the bottom left side it will have a curve.
    Problem Solver:
  • 7 Answers
Bad convergence IC's and possibly yoke return resistors located right by the convergence IC's
Craig
Posted on May 08, 2009
Poor picture quality. Picture also tends to curve
The curving is caused by bad digital convergencr chips (2) located on large signal board. They need replaced along with blown pico fuses and the convergence resistors. Chips are huge compared to a regular IC. 2" x 1.5" and they will be bolted on fairly large heatsinks. Cloudy picture is most likely the coolant needs replaced in the picture tubes. This needs to be done approximately every 5 years.
May 01, 2010 | Philips Magnavox 9P6034C 60" Rear...
Projection HDTV Pansonic 47" Curving blue and green colors on top and bottom of screen.
You will need to replace your two convergence I.C.s.They are two large IC mounted on a large aluminum heat sink.Replace both,look for any burned resistors near them,replace those if needed,and readjust your convergence. Good Luck
Let me know if you need any further help
Mar 29, 2008 | Panasonic PT-47WX42 47" Rear Projection...
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Red & Green outlines but only on left/center portion of screen.
Its a convergence problem. You may want to check the site www.tvrepairkits.com. Every thing they said every description was right on. The best money I ever spent and the confidence you get from doing it yourself, Its a great feeling of achievement not to forget the live messenger support is instantaneous, friendly and informative if you need to fix your tv go to tvrepairkits.com I fixed a philips 60 inch tv in 45 minutes, The convergecne chips were bad thanks a million. You guys saved me 250.00 bucks. I'll be recommending you to everyone I know!
Aug 18, 2009 | Sony KP-46WT500 46" Rear Projection...
The top rite and leaft of my screen coners are out
Wave would indicate your loosing high voltage and the tv is nearing the end. You can tweak hv, but its a short lived solution. Good luck
Jul 09, 2009 | Philips 60PP9202 60" Rear Projection...
Projection on the screen is too large so the pic is cut off
using the right or left arrows should change your screen sizes 16.9 4.3 and so on
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
60" Projection Screen Phillips Magnavox won't turn on
Check the site www.TvRepairKits.com - they put together a kit to fix this problem.
Nov 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
60PP9352 philip hdtv
Classic symptom - Your convergence chips are toast.You can
get a repair kit with photo instructions from www.TvRepairKits.com.
Sep 30, 2008 | Philips 60PP9352 60" Rear Projection...
Red and green fuzzy waves across the screen
my screen just became distorted (red picturer to the upper right & green picture to the bottem left ? can you help me ? wuzuphippie55@yahoo
Sep 08, 2008 | Philips Magnavox 9P6034C 60" Rear...
Help
You need to have the convergence IC's replaced. A repair like this should run you about 300 bucks or so. In most places.
Apr 27, 2008 | Sony KP-46WT500 46" Rear Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
