Question about Beam Industries 2775 Serenity Plus Central System Vacuum
Beam sp800 shuts off resets temorarily - Beam Industries 2775 Serenity Plus Central System Vacuum
I have a Beam Rugmaster Plus power head Model BM1 393 Type AB and the connection were the metal pipe meets the plastic swivel broke close to the unit. It appears like a manufacture defect in that is broke...
This is most likely repairable. Lots of the Beam parts are available. I would recommend checking out any local vacuum shop or searching online for a central vacuum store that sells beam products.
Sep 29, 2009 | Beam Industries 750 Classic Bagless...
Carbon buildup on plug to hose causing burn
Sounds like there could be a short in the hose. Try another hose and see if that's the problem. It's too soon to have to replace the unit. Try having the hose checked out, it could be the root of your problem
Sep 03, 2009 | Beam Industries 2900 Serenity Plus Central...
I have to reset my Beam Central vac quite often!!!
Check to see if there is a clog in the system. Something is causing stress on your motor causing it to switch off. Or it could be the motor itself failing.
First check for a clog, if you can't find anything wrong, call Beam for assistance
Aug 21, 2009 | Vacuums
Beam Central Vacuum shuts down periodically. The bag is not full.
check for a clog and also see if a Beam authorized mechanic to take a look at it as it could be motor or relay board issue
Aug 16, 2009 | Vacuums
Beam central vac
Don't know the exact model, but it sounds like the low voltage relay is stuck. This will be inside the unit, probably mounted on a replaceable board. You may be able to temporarily free it with a quick tap on the top of the relay if you locate it. But I would suggest replacing it to avoid further problems. mdvacuum.com would probably have the part you need. Good Luck!!
Aug 27, 2008 | Beam Industries 2775 Serenity Plus Central...
Beam Central Vac Breaker Pops
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=797869
Generic problem for all Vacuums
Posted by tinateggart1 on Jul 17, 2008
The breaker on our beam model 167 central vac popped while in use. Every time I try and restart it, it immediately pops again. What's the problem? Circuit board? Motor? Overheating?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Chances are it is the relay switch on the inside of the Beam Central Vac, if it was a motor, it would not turn on @ all. If it was a circuit board, it may or may not be turned on, but if it will turn on and then pop your circuit breaker than it probably is the relay switch. Please, check with your local Beam vacuum cleaner dealer in your area or contact the Beam website or cust serv @ the phone number listed below. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.beamvac.com/usa/ Owner Support
Customer Service 1-800-369-2326 Phone #
Email: beam.dir-support@beamvac.com
Technical Support: beam.tech-info@beasmvac.com
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 17, 2008 | Vacuums
Cannot shut vacuum on hose
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Nov 21, 2007 | Beam Industries 2775 Serenity Plus Central...
BEAM Serenity Plus 2900 has shutdown
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. OK, there is a reset button on the unit but i think it could be that your vacuum could be clogged in the vacuum lines and that you should check all the inlets/outlets in your house with your vacuum hose - or get a vacuum cuff and go to each individual outlets and check the suction by feel - if the outlet is clogged you may have to call someone to unclogg it or by going to each oultlet the system may unclog it self -- or you can use a plumbers snake and be careful because the lines in a central vacuum are thinner than the walls in a plumbing situation or have it professionally unclogged by a priofessional. When you are using another vacuum to unclog the unit make sure the central vac is runing and to try to pull the clog apart from both directions. Below is a link to the factory for Beam and if you need a owners manuel for the Central Vac
Sep 30, 2007 | Beam Industries 2900 Serenity Plus Central...
Beam Industries 2775 Serenity Plus Central System Vacuum Logo
14 people viewed this question
Top Beam Industries Vacuums Experts
Thatvacguy.com
Jerry Kramer
Jerry Kramer
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
