Question about Car Audio & Video
Gauges work sporadicly
I have a 1989 jeep wrangler. The gauge cluster that has the Temp., voltage, fuel, oil and clock in it. The clock and oil pressure work, but the others work some times and some times they don't. Could this be a grounding problem?
    Scholar:
  • 82 Answers
I would first check the connector at the rear of the gauges, it might just have to be exercised (plug/unplug it a few times) to clean debris, corrosion and dust (be careful as I remember this uses a membrane circuit board).
Posted on May 08, 2009
Fuel gauge sensor
Yes, the sending unit is in the tank. If you unplug the connector at the tank and ground the gauge's sender unit wire to metal, with key on, the dash gauge should jump to full or near full. This verifies the dash gauge is working properly, and the problem is with the sender unit in the tank. If the gauge doesn't move when grounded, then the gauge or wiring from tank to gauge is not correct.
Good luck.
Jan 24, 2012 | 1988 Jeep Wrangler
Hello, I just purchased a used 1989 Jeep Wrangler and the instrument panel doesn't work (speedometer, fuel gauge, etc). Is the remedy something I could do myself? And what would the remedy be?
on the older jeeps the gauge cluster with the fuel gauge, clock and temp cauge is controled ny a riboin cable on the back. when i got mine theis didnt work either, the cable was dirty. its real easy to take them out all you will need is a phillips screw driver and a q tip and some rubbing alchole. clean it up and see if that does it.
Jul 29, 2011 | 1989 Jeep Wrangler
I have a 1964 mustang with a six cyl. all gauges dont work. put in a new oil pressure sending unit, has a new fuel tank with sending unit,new temp. sending unit wires are all hooked up. I need help finding...
There is a voltage regulator on the back of the instrument cluster printed circuit board. Chances are this has burned out if no gauges work. You'll need to remove the instrument cluster to get to it.
Dec 03, 2010 | 1965 Ford Mustang
My gauges don't work my rpm's my gas my oil my battery all died, i still have my radio and lights, my mph and clock still function. please help i'm scared to run out of gas
check all of your fuses and wiring. i had the same prob with my 80 cj7 after checking all the simple things i just went ahead and rewired all the electrical and everything works fine now.
Mar 12, 2010 | 1989 Jeep Wrangler
Gas guage and water temp gauge do not work clock works alt works oil works guages work just not gas and water temp ?????
On the rear of the instrument cluster there should be a resistor. This is how the fuel and temp guages are limited to a certain voltage decreasing the power to them so that they dont burn out. These (voltage limiters) resistors are available seperately from the dealership.
Oct 04, 2009 | 1987 Jeep Wrangler
Gauges do not work....
Probably lost the ground from the instrument cluster. Unfortunately, it's under the dashboard and hard to get to. Possible cracked circuit board.
Aug 12, 2009 | 2002 Mitsubishi Lancer
Instrument cluster on 97 Wrangler
IF YOU REMOVE INSTRUMENT CLUSTER AND UNPLUG IT,PLUG IT BACK IN AND UNPLUG IT AGAIN..DO THIS A FEW TIMES..IT SHOULD CLEAN OFF SLIGHT OXIDATION ON CONNECTOR TERMINALS..HAVE SEEN THIS BEFORE..I ALSO THINK REPAIR CONNECTORS AVAILABLE FROM DEALER
Jun 21, 2009 | 1998 Jeep Wrangler
97 Jeep Wrangler Dash Gauges Arent Operating..everything else ok!
ck the engine to body ground.located back side of engine and srew to firewall.
Jun 01, 2009 | 1997 Jeep Wrangler
Car Audio & Video Logo
85 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
