A/c wont cool despite 2/3 cans refrigerant
A/c wont cool despite 2 or 3 cans refrigerant
  • 3 more comments
  • jjttmd May 08, 2009
    no. i put regrigerant with leak stop
    How will I know when compressor kicks in? Does it make clicking sound like you mentioned? i'll have to go check it out.
    Its a nissan xterra 2002 as far as car but type of a/c is that under hood?
    will let you know.
    I will listen but I dont recall compressor sound
    when I added refrig it was gauge said full and cold air ....but w/in 2 hrs hot air
  • jjttmd May 09, 2009
    No prob.
    But Re car a/c no compressor kicked in or is that only in home a/c. How much do u think it will cost to get this likely leak fixed
    Jane
  • Miguel Tulipat
    Miguel Tulipat May 11, 2010
    have you checked the system for leaks?
  • 423 Answers
A failed compressor can cause this problem, including having a leak that can not be patched with leak stop.
After you turn on the A/C unit, does the compressor "kick in" within a minute of turning the unit on? Do you hear any "clicking" sounds? If yes, post back here and we can take the next step.
Posted on May 08, 2009
  • Jeff Meyer May 08, 2009
    It would be really helpful to know the make and model of your A/C unit.
    When the A/C unit fires up, there are two things that make noise. One is the sound of the fan running. The sound of rushing air. The second sound is the compressor, which has a much deeper, humming sound. On many A/C units. the fan comes on first then in far less than a minute, the compressor "kicks in" When that happens and you are listening for it, it is obvious.
    If all you hear is rushing air, suspect the compressor failure.
  • Jeff Meyer May 09, 2009
    Be gentle with me. I mis-understood your query and assumed you were working with a home A/C unit. So all my input so far was household A/C focused.
    OK, working with auto A/C is different. To determine where the (obvious) leak is you would need special glasses and light source and some ultraviolet dye to put into the system. But realize that releasing these gases before the system is fully repaired has large fines. Recommend that a professional get involved.
Whirlpool Refridgerator less than 2 years old Making loud buzzing noise this eve so I turned the cooling dial down to off. It stopped the buzzing, but now that I have powered it back to level 3 it will...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Whirlpool Refrigerators
The temperature in the fridge is increasing rapidly despite the setting being on the lowest temperature. The motor on the fridge is running, but there is no change.
Your coils might be full of dust. The coils can be under or behind the fridge. You will need to clean them off so they can cool the refrigerant. You can use a dusting wand.
Jan 08, 2011 | Frigidaire FRS26H5AS Side by Side...
Works fine than shuts off completely after 2 or 3 weeks
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
bb
Sep 26, 2010 | Maytag MSD2756G Side by Side Refrigerator
The unit cools and freezes good for 3 to 4 weeks then it dosent cool. unplugf it for a day or two and it woorks good again for another 2 to 3 weeks.
The defrost may be sticking...this can be an intermittent problem and hard to pin down...
heatman101
Sep 22, 2010 | Kenmore 53542 / 53544 Side by Side...
Whirlpool Fridge and Freezer quit cooling properly at the same time.
You likely have a defrost system problem.....call a service company to look at it.
May 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator stopped freezing & cooling
can you hear compressor working
Apr 05, 2009 | Refrigerators
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Heating & Cooling Logo
54 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
