Question about Black & Decker Camping, Backpacking & Hiking
Blades 323437-00 Profesional cuting mashine
How to check mower deck bearings on a craftsman 24hp with 42" cute
grab blades with glove on and pull sideways back and forth if you fill them move they are bad replace them
Sep 08, 2014 | Garden
Tractor will not move in any gear. pully is going. cuting blade droped off.
Check to see if the drive belt has slipped or is broken.
If really helpful, please rate as such.
Jul 13, 2011 | Craftsman Garden
Breville foodprocessor Wizz Professional FP16B Is a replacement metal s shaped chopping blade available Paraparaumu Beach New Zealand
is there anyone know where to find a blade chopper for breville wizz profesional fp16b model.
May 17, 2011 | Food Processors
Can anyone help please ive just got hold of a black and decker DN339 band saw and want to cut max 50mm soft wood with the grain using the fence to slide against, only the blade is tilting towards the fence...
That is usually an indication that the blade is blunt and one side has lost its edge more than the other. The blade will wander towards the sharper side. You will have to replace the blade. For soft wood you need about 4-6 tpi. and a cutting speed of about 1000 - 1500 ft/min.
Mar 28, 2011 | Saws
My Craftsman riding mower runs fine but when I try to cut thick or tall grass the blades slow down and stop cuting, I replaced the belt thinking the belt was worn only to find I still have the same...
well yep it is,,,look at the deck first to check its not tight to turn look for sezed up bearings,,,then check that the drive belt/s are tight and not flopy and slipping also it would be a good time to check the cutting blades they need to be sharp and not blunt or they strain the belts and start them slipping too also the engine wont like the extra load put on it
Jul 28, 2010 | Craftsman Garden
Is there a switch ? to stop the mower from cuting
all riding mowers have a separate lever to engage the cutting blades,this is to allow you to travel some distances before actually cutting any grass
Oct 27, 2009 | Briggs & Stratton Garden
My washing mashin shows F35; First shows sud
Check the drain line for kinks or obstructions first. Then check the pump. Remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check for anything clogging the pump and inspect the pump impeller for broken/missing blades and ensure that the impeller spins freely. If any blades are broken/missing or if you cannot get the impeller to spin freely, the pump is defective. Hopefully, it is just a clogged drain line or pump. Hope this helped and best wishes.
Aug 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Deck is leveled, blades are fine,spindle not bent it still cuts
there was a problem with the lighter gauge decks [thinner steel], and the deck would actually bend inward on the left side. this would tilt the mandrel inward making the blade cut at a slight angle to the right blade - there is tool to straighten the deck [the left mandrel housing usually breaks, though] - some shops have this tool, others have never heard of such a thing - most sears l&g field techs have this tool in their trucks - i have the tool in my shop, but i have had luck with turning the deck over and whapping it a couple of times on the inside edge of the left mandrel until the blades line up
Aug 26, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Camping, Backpacking & Hiking Logo
59 people viewed this question
Top Black & Decker Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Black & Decker Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
