Question about Broderbund 3D Home Architect Deluxe 6 (383204) for PC
Convert pl1 files to dwg
I would like to be able to flip my drawing (not reverse) and cannot do it in 3DHAD3
Autocad changes lost
The most effective solution is .dwg recovery tool when other methods don't work
The place where you may read various thing about Autocad
Here you may read more about article below
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
AutoCAD Recovery tool How to repair corrupt AutoCAD drawings and fix its errors Error Drawing file is not valid when opening file in AutoCAD
Aug 28, 2017 | Computers & Internet
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
How to view damaged dwg file of autocad?
Try using a different version of AutoCAD to open the drawing, such as AutoCAD 2013 vs. AutoCAD 2015 or plain AutoCAD vs. AutoCAD Architecture, etc. Try different computers if available. or try DWG Viewer Tool on website:http://www.ask.com/answers/722146801/how-to-view-corrupted-autocad-drawing?qsrc=14106
May 29, 2015 | Autodesk AutoCAD Electrical 2013
.dwg file corrupt?
Different solutions you may find out here:-
http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/dwg/444-%E2%80%8Berror-cannot-open-file-open-cad-drawing-dwg-format - a lot of different opinions might be your saving.
BAK files are very important, explanation below:
Consider what AutoCAD does during a QSAVE (assuming "create BAK" is enabled)
1. It writes the contents of the editor to a temp file.
2. It renames the current drawing from .DWG to .BAK
3. It renames the temp file to the correct file name with a .DWG extension.
I don't see how you have had problems with BAK files since it's simply a copy of your last save. In fact, if you QSAVE twice in a row, then your BAK = the DWG.
OR
Third party software DWG Viewer Tool
But demo version for free:- http://www.dwg.viewertool.com/
Nov 06, 2014 | Autodesk AutoCAD Computers & Internet
True view corrupt file: I can load a drawing directly from an Email attachment but when I save the file and then try to open the same drawing from that saved file I get a 'Drawing file is not...
Given trouble can resolve with the help of dwg recovery. It work with big autocad files corrupted and deleted after power failures, viruses, malicious software. The software has modern user-friendly, agreeable interface.
Sep 26, 2011 | Autodesk DWG TrueView
What software do I need to convert word, jpg and other files to PDF format?
The easiest way I've found is to use CutePDF. It installs itself as a virtual printer, only when you "print" to it, you get a PDF document output. Download it for free here http://www.cutepdf.com/products/cutepdf/writer.asp
Feb 04, 2011 | HP Computers & Internet
Autocad 2004 and win vista
Apparently, autocad is not compatible with vista.. Might as well, go back to wndows xp.. Please see the required specs to run autocad 2004
Mar 22, 2010 | Autodesk AutoCAD 2004 for PC
How do you lock a dwg file so it cannot be edited?
A COUPLE OF SUGGESTION
Now you can protect your works with this DWGLock software, the entities in the send out drawings can NOT be copied nor changed. However, recipients can open up the drawing, add lines and markups. Only the drawing owner allows extracting the drawing, if they need to, enclosing the added part with the native drawing. This is ideal solution for the collaboration needs and contractors.
It is a stand-alone application, no AutoCAD required; Supports AutoCAD R2.9 thru 2009 drawings. about $330.
CADLock, Inc. continues to create innovative solutions that enable you to maintain control of your intellectual property and share it with those who need it. We invite you to download and evaluate CADVault® for AutoCAD® to find out how digital rights management can work for you. THIS MAYBE PRICY also
Acme CAD Converter Acme CAD Converter is a dwg/dxf/dwf format conversion software for batch and vector files. It can conveniently convert DXF,DWF and DWG files into BMP, GIF,JPEG, DXF, DWG, SVG , PDF, HPGL etc., and also enable the conversion between DXF and DWG file versions (R2.5-R2005).
Apr 01, 2009 | Autodesk Map 3D 2006
Convert CAD (DWG) to Visio Drawings
You can import graphics files of different formats to start a new Visio drawing by using the Open command on the File menu.
The following graphics file formats are supported:
  • AutoCAD Drawing File Format (.dwg, .dxf)
  • Compressed Enhanced Metafile (.emz)
  • Enhanced Metafile (.emf)
  • Graphics Interchange Format (.gif)
  • JPEG File Interchange Format (.jpg)
  • Portable Network Graphics (.png)
  • Scalable Vector Graphics Drawing (.svg, .svgz)
  • Tag Image File Format (.tif, .tiff)
  • Windows Bitmap (.bmp, .dib)
  • Windows Metafile (.wmf)
Note File formats may vary slightly between language versions. You may not get exactly the same results if you import files created in different language versions.
  1. On the File menu, click Open.
  2. In the Files of type box, click the file format of the file you want to import.
If you don't see the file format listed, Visio doesn't have a file filter for that format. Try saving the document in a format Visio can open.
Dec 28, 2007 | Computers & Internet
Broderbund 3D Home Architect Deluxe 6 (383204) for PC Logo
Top Broderbund Computers & Internet Experts
Martin Murray
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
