Question about Samsung RW52DASS Wine Cooler
Samsung wine cooler d1 code error
Brand new and not working switched on and coming up with d1 error code,i live in Thailand so if i take it back to the shop it will be away for weeks,so if its an easy reset ill do myself,please assist asap.Evry time i switch on its still lthe same,obviously samsung do not supply us with the error condos as they want their own engineer,t one paid to come out to do a simple fix
  • 31 Answers
My experience with Samsung service is extremely poor. Make them replace it. I would demand a refund from the vendor/store where you bought it and get another one, but different brand.
Posted on Nov 27, 2013
3 Suggested Answers
ZJLimited
  • 17970 Answers
SOURCE: I have a Samsung Milleseme
Check this info form Samsung Wine Cooler User Manual...
Hope helps; keep us updated.
Posted on Aug 04, 2011
  • 195 Answers
SOURCE: samsung twin cooler one+1 moor cooler
HI SUZANNE .food for thought.hope it helps.some of these refrigerator s do show lines when the temp is high,but if it happened only after turning it off and on the i sugest u read the manual and follow the initial setting procedures ok.?hope it helps
Posted on Jun 18, 2012
E1 error code LFWC38F6LS
Good Morning Chris,
I see that you are receiving an E1 error code on your wine cooler, model# LFWC38F6LS, even though your wine cooler is still working. This could possibly be a false error code, caused by a miscommunication between the different control boards inside your appliance. I suggest resetting it by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes. If when you bring power back to your wine cooler, you are still receiving the E1 error code, I suggest contacting either the manufacturer or your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Mar 18, 2014 | Frigidaire 38-Bottle Two-Temperature Zone...
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 | Furniture
Received apparent error message "E3" for upper
E3 is a fan error. This is usually caused by poor connection to the fan. Remove all connectors and reinstall assuring tight connection. This should remedy it unless the fan is bad, which is very rare!
Jan 12, 2011 | Magic Chef MCWC44DZ Wine Cooler
Hello, I have BW40 wine cooler. On the display is blinking error message "E2". I have tried to switch off and switch on, but it doesn't helped. Thanks for you support in advance. br, Zoltan
There are 2 sensors in this wine cooler. Malfunction of each leads to E1 or E2 fault codes. One is easily accessible inside the fridge (small white torpedo sensor with pair of wires attached). The second but identical sensor is buried within the foam on the rear of the cooler. Unplug from mains, take of the electrics from back of cooler, take off sheet metal back and the sensor will be deep in the foam and can be replaced easily after digging out some foam. When replaced make sure the sensor is in the same place it stops the cooler icing up. Use gap-fill foam to keep insulation good. Dr_Nicholas
Sep 28, 2010 | Baumatic BWE40 Wine Cooler
AVANTI WCR683DZD WINE CHILLER - E4 ERROR CODE
I have the same E4 problem. You can order the PCB from Avanti at Miami Florida or your regional Avanti service rep.
Jun 04, 2009 | Avanti WCR683DZD Stainless Steel Wine...
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Oct 01, 2008 | Cuisinart CWC-1200 Wine Cooler
Marvel Cooler/Fridge Light Not Working
It sounds like the bulb is not getting power. There is a door switch that turns it off when the door closes...this may be stuck. There is usually an optional (depending on age) ON/OFF switch that overrides the light to be on full time. If the light will also not turn on with that switch then there must be a disconnected or broken wire either going to the light switches or going to the light socket from the switches. I hope this helps.
Aug 30, 2008 | Marvel (6SBARBSG) Wine Cooler
E7 Code
Dera grezni
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Sounds like we need to try to reset the system!
Huuum At your service!
Lets try this,
With an error code.
This can reset the system if it is electronic!
Unplug the appliance and wait a 5 minutes then restart it.
If you can't reach the plug, use the breaker to cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works! Waiting for your reply!
Please remember to leave a rating when you are done!
Thank You huuum
Aug 20, 2008 | Danby DWC283BLS Wine Cooler
Danby Wine Cooler
If you are getting the E4 error code, try replacing the defrost sensor. The part might take forever to get to you, but we replaced the sensor on the wine cooler and it's working.
Jul 13, 2008 | Danby DWC513BLS Wine Cooler
Samsung RW52DASS Wine Cooler Logo
130 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
