Question about Apple iPod MP3 Player
IPOD shows no file found
I have tuns of song on my IPOD and one day I turned it on and it said no file found. how do I fix it?
  • fixmeplz Apr 23, 2008
    i turn it on and it will show and apple then a file and then shut down
  • Kenneth Scott
    Kenneth Scott Oct 06, 2008
    I have gen 4 iPod (click wheel) - hard drive will not start spinning (hum sound) only a clicking and spin start but stop.  Setup on a G4 iMac but it has ost all the tunes during an upgrade snaffu so no tunes in the iMac.  All my songs are on the defunct iPod so don't want to "reset" it and lose all the tunes.
To reset an iPod with a Click Wheel, including: IPOD shows no file found - ipodnano3.jpg ipodclassic.jpg icon_ipod_5g.gif ipodnano.jpg ipodg4.gif ipodmini.gif
  • iPod nano (3rd generation)
  • iPod classic
  • iPod (5th generation)
  • iPod nano (2nd generation)
  • iPod nano
  • iPod with color display (iPod photo)
  • iPod (Click Wheel)
  • iPod mini
  • iPod mini (2nd generation)
  1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
Posted on Dec 20, 2007
Computer and ipod
The exclamation mark next to a title in iTunes means that iTunes cannot locate the song associated with that title (original file cannot be found). The cause for this is an incorrect setting of iTunes preferences when copying iPod songs.
Before copying your iPod songs, setup your iTunes preferences as follows
  • Open iTunes preferences (in the Edit menu)
  • Select the Advanced tab.
  • Make sure the box next to "Copy files to iTunes Music folder when adding to library" is checked.
  • Click OK.
Then use a program like TouchCopy to copy your iPod music to iTunes. You can download TouchCopy from here
http://www.wideanglesoftware.com/touchcopy/
Mar 13, 2010 | Apple iPod classic MP3 Player
My IDJ2 is not installing everything from my IPOD. I have checked my ipod and everything is on there however the IDJ2 is not showing up all my songs. Every playlist is missing songs and they are not...
it maybe due to protected files. some songs (files) are classified protected.. this very frustrating problem is the birth child of .... you guessed it ...apple. eg i have 2250 files on my ipod but can only play around 1900 on the idj2. i hope this helps
Dec 18, 2009 | Numark iDJ2 - DJ iPOD Mixer Docking...
Syncing iPod with iTunes, infamous (-69) problem
just
This error occurs when iTunes tries to send files to your iPod, but a file (or files) is unusable (something is wrong with it).
To figure out which file (or files) is causing the error, update to the latest version of iTunes and then do this:
  1. Control-click (Mac) or right-click (Windows) on your iPod icon in the iTunes Source pane, then choose Sync Songs from the shortcut menu.
  2. Watchthe display at the top of the iTunes window while your iPod is beingupdated. The name of the problematic file should appear in the displayright before the error appears. Then remove the bad file from the listof songs to be synced to your iPod.
  3. Select the iPod in the iTunes Source pane.
  4. Click the Settings tab.
  5. Selectthe "Only sync checked items" checkbox (please note that this checkboxis only available for an iPod configured to update automatically).
  6. Selectthe appropriate item under Library in the sidebar and find the bad filein the list. (For example, if the file in question was a song you wouldselect Music in the iTunes Source pane. If it were a video you wouldselect Movies or TV Shows in the sidebar.)
  7. Deselect the checkbox next to the file name.
  8. Repeatsteps 1 and 2 to update your iPod. If you have multiple problematicfiles in your iTunes library, you may need to repeat the other steps toremove them too.
To prevent future issues, you should delete the unusable files from your iTunes library, then restore them from a backup or reimport them from a CD.
If you're not able to isolate to any single file or if another iPodworks with the same songs, then disconnect any other devices connectedto USB or FireWire and try again. If the issue continues, then then tryresetting your iPod. If the issue continues, then restore your iPod.
Jul 15, 2009 | Apple iPod MA446LL/A MP3 Player
All my songs got deleted while i was trying to sync
Ur problem can be solve my one way, u have to bring some one else ipod or mp3 player of same model just open it in ur computer u w'll see one file other than mp3 file copy that file and paste it in ur device.
make sure u have to make a back up.
I hope this w'll fix it.
Apr 17, 2009 | Apple iPod nano
Shows no files found
Hi, Try downloading Itunes ( Which is free of cost ) and add song & video to Itunes. Then connect your ipod to computer and configure your ipod to Itunes ... then sync it...
Whenever you connect your ipod to computer it will automatically sync..
If you still need more help on the same let me know
Jan 08, 2009 | Apple iPod nano
My ipods locked and i 4 got the code and cant get on to itunes !!!!
Thanks to everymac.com i found your answer, i was interested in what would happen.
Connect your iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. If you can't unlock iPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to your iPod. If you want to change the primary computer that your iPod is associated with, do this: 1. Restore your iPod. Warning: The restore process cannot be undone. All of your songs and files will be deleted. Always make a backup of your important data. 2. Connect your iPod to the computer that you want to be the primary computer. 3. Open iTunes and synchronize.
Oct 21, 2008 | Apple iPod nano
Format error
what type of mp4 player is it, and what type of files are you trying to upload?
Jan 28, 2008 | Apple iPod MA446LL/A MP3 Player
Sound not audible
Try resetting the ipod and see if that fixes the problem. Use apple's 5 R's which can be found here:
http://docs.info.apple.com/article.html?artnum=303940
Jan 22, 2008 | Apple iPod nano
Loss of songs
It's unlikely you'll be able to get back your songs. However, you can try using poddox (install on your PC and connect the iPod) and see if it finds any of your old songs on the iPod. If that doesn't work, try connecting the iPod to the computer and installing an undelete program such as Free Undelete and restoring files found on drive X, where X is the letter of the drive that your iPod shows up as on windows.
Jan 09, 2008 | Apple iPod MA446LL/A MP3 Player
I use urge to rip songs off a cd and then sync them onto an IPOD. The IPOD (G) drive is showing the files but they won't play what am I missing
Make sure the songs are in the correct format. Make sure the songs are not AAC, WAV, streaming, or some other non-supported format
Mp3 players are more complicated than ever. This player may only accept DRM-encrypted WMA files. I would first check the songs that you have downloaded to make sure they did not have "temporary" licenses with a fixed end date. You can do this by right clicking on an individual song, clicking on properties, and selecting the "license," "digital rights mgmt" or "media usage rights" tab - the wording varies by configuration. It will give you info on the license. If the song says that it has no license, it will not work with this player. One remedy is to use mp3 converter software to convert all of those wma files to Mp3's - I don't know of any free ones, but you can certainly look for free Mp3 Converters. Another remedy on unlicensed songs is to hit the "acquire license" link in the license tab, if one exists.
-Tha Mp3 Doctor
Jan 01, 2008 | RCA TH1101 MP3 Player
Apple iPod MP3 Player Logo
209 people viewed this question
Top Apple Audio Players & Recorders Experts
Parshiv Luthra
Marvin
Marvin
Dapid Candra
Dapid Candra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
