Question about HP Compaq nx7010 Notebook
Battery stats reset
Why does my tablet only charge 20%?
Have you rooted the device?
If not you might still be able to reset the battery stats - just google boot into recovery and see if there's a way to rest "BATTERY STATS". Fair warning you can also reset/wipe the whole device from there.
Or drain the battery - charge 100% (or at least enough time that it should reach that point) and repeat that cycle 3-5 times and might restore the settings on its own.
Oct 04, 2015 | Tablets & eReaders
How to wire a honeywell rth2300/rth221 to a five wire connection
I am not familiar with this particular thermostat; however, here's some general information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
setOFF manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
May 11, 2014 | Honeywell Programmable Thermostat Heater
How to reset thermostat
from my understanding there are two types: programmable and non-programmable.
Apr 24, 2014 | LG Dryers
Trouble shooting codes
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 12, 2014 | Honeywell Programmable Thermostat Heater
Honeywell TH5110D1006 FocusPRO Non-Programmable Thermostat need a tip or trick to keep someone from changing thermostat maybe disable buttons
Apr 02, 2014 | Heating & Cooling
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
THE UNIT WONT COME ON AI ALL, BUT ON THE THERMOSTAT THERES A BLINKING STAR. WHAT DOES THAT MEAN?
the blinking star means the t-stat is on delay, you can try to cut the power to the t-stat or remove the batteries for about 2min to reset the t-stat connect your power or put your batteries back on t-stat and see if works dont forget the delay on the t-stat make the star to blink
Sep 23, 2009 | Carrier Heating & Cooling
Screen is blank but system will run does it have a
Check the battery. sometimes the stat can get an electrical shock, take the stat off the wall take out the batteries, if applicable, and set the stat down and walk away for at least 5 minutes then put it back, it might reset.
Aug 15, 2009 | Honeywell Programmable Thermostat Heater
NEED TO KNHOW HOW TO RESET MY Honeywell T8601D2019 Premier Thermostat
remove stat from base, remove batteries if applicable, remove "watch" battery from the back of stat, if applicable wait about five minutes reinstall all batteries, should reset
Jul 07, 2009 | Heating & Cooling
Janitrol inside unit
Do you have a digital t-stat?
If so does t-stat have batteries? bad batteries will give you problems.
Check you electrical breakers. Turn them off then back on to reset.
Does the fan come on if you set the t-stat to fan on?
May 19, 2008 | Ruud UBHC Air Conditioner
HP Compaq nx7010 Notebook Logo
16 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
