Question about RCA 27V520T 27" TV
Have a three week old TV
 Serial #  RCAHD44LPW62YX1
 Model # F344C600E
Just started that noise. Seems to be getting louder.
Book states it is in its lamp cool down cycle when you hear this, but this is running all the time the TV is on now. It is annoying to say the least.
  • olfogieo Oct 11, 2007
    Noooo... I wouldn't attempt to fix it myself.
    But how expensive is it to have that  repaired if that is whats wrong with it.????
    Will check .
    And thanks for your time
    ps... this is a 44" tv.
  • olfogieo Oct 13, 2007
    For some reason or another... the noise has completely stopped. We will continue to keep a close ear to it. Thanks alot for your help.
  • 1,139 Answers
Hello olfogieo,
This sounds like the IHVT (flyback) is arching and or going bad or the horizontal frequency is changing. you may have to remove the back of the TV and tell me if you see any arching from the flyback.  I would not suggest that you attempt to repair this since the high voltages section have voltages that can kill.
Posted on Oct 11, 2007
  • Henry McKelvey
    Henry McKelvey Oct 12, 2007
    As I said in my post it sounds like a problem in the high voltage section. Is it expensive to fix? that depends if the IHVT is bad and the set costs about $200.00 get a new set because the troubles you will have are not worth it. If the set is $1000.00 to $2000 then by all means replace the part.
    I hope this helps.
How do I open the3 fuse box under the hood of my 02 dodge neon,it keeps humming
PDF]Owners Manual - Dodge DodgeThe interior lights will come on when you open any door, ... There is a door lock switch on each front door trim panel ...... the hood release lever located under the left side of the ...... and neon signs. ...... NOTE: Using the "3" range while operating the vehicleunder ...... The fuse access panel is behind the end cover at the left.
were is the fuel pump reset button for a 2001 dodge neon? > Questions > Dodge > Neon
CarGurusJul 26, 2011 - were would i find the reset button on my dodge neon i need help badly is there ... I would check the fuse under the hood and relay. ... Fluid, spray into your intake with engine off and throttle open .... 2002 Dodge Neon For Sale.
what causes the humming noise thats coming from my fuse box in our ...
Feb 4, 2011 - I am in a Alpha Ideal 34 ft rv. The fuse box on wall started humming a noice lastnight. Coming right from in the area of the switches. What could ... Buzzing noise coming from fuse box/lights flickering?
Aug 25, 2013
Breaker/Fuse box noise please help?
Sep 11, 2011
Why is my home's fuse box making a loud constant buzzing noise ...
Jan 3, 2011
My house fusebox has a buzz sound?
Jul 14, 2009
More results from
Feb 05, 2016 | Jeep 02 - 05 Chrysler Sebring, Dodge Neon,...
Lg tv humming noise when tv is on
The humming noise is most likely coming from the power supply.
If the unit is worth the repair cost ( Over $100.00 ) you should have it repaired.
If not, deal with the noise until it goes out.
May 12, 2014 | Televison & Video
Probably the condenser fan motor is going out they will often make noise for a long time before anyone notices. Get it looked at soon. overheating the compressor on that old of a fridge could spell trouble.
Sep 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung tx-p2734 TV Issues: Wavy lines on SIDE of tube...
For the buzzing noise try tipping tv jently forward and jently placing back.
May 07, 2009 | Samsung TXP2734 27" TV
Toshiba 36zp18q buzzing noise.
Humming sounds come from the power supply and buzzing sounds come from other circuitry. Most likely a capacitor somewhere.
Feb 18, 2009 | Toshiba 36A40 36" TV
Frigidaire FRS26R4A Vibrating Noise
Finally called a service technician. He said the compressor was bad and needs replacing. Fortunately, I'm in the 2nd - 5th year of my limited warranty so parts and labor are covered. He also said that the FRS26R4A is "junk" and it helps to support his family.
Jan 09, 2009 | Frigidaire FRS26R4A Side by Side...
My whirlpool aide by side fridge icemaker is making buzzing or humming noise
Welcome to fixya.
I'm Huuum and happy to assist you,
You said, your ice maker is making a buzzing or humming noise ice maker isn't making much ice. . fridge is about 2 1/2 years old.
This sounds like a clogged water line or a electrical short !
I would get service rather than take a chance on electrical fire.
Or burn up the circuit in the ice maker.
Thank you for giving us the opportunity to advise you.
Please remember to leave a rating before you leave us
Please remember to leave a rating before you go!
Thank you
Sep 29, 2008 | Whirlpool GC5SHEXNS Side by Side...
Buzzing noise coming from timer control area
Is your water on ??if yes than you may have a bad timer.
May 04, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Humming noise coming from Jennaire built in
is the unit touching another apliance or unit touching it as the contact can produce sound as it vibrates on something else if it is not touching something else then the unit probably isnt level it should havfeet on the bottom that turn round to allow you to get the unit level you will need a spirit level to do this and put it running side to side and get it level then do it front to back and get it level on getting it level the noise should stop if the noise dont stop then it is probably just a noisy motor there is nothing you can do about this as they sometimes are noisy but if noise stops when you open door then the unit is probably not level and opening the door balacnes the weight distribution and levels the unit and therfore stops the sound i would try balancing the unit first or make sure it is not touching anything else hope this solves oyur problem good luck...........................
Nov 17, 2007 | Jenn-Air JUC2450ARS Compact Refrigerator
Televison & Video Logo
51 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
