Question about Garden
Statesman 5.5 Hp Rear tine tiller swing handle
Thank you for any help. We took apart our Staesman 5.5 rear tine tiller to replace the gear shift. We took it apart and a gear fell down and spacers. If we had a schematic it would help to see how it goes back together. We are both electronic electricains, I have worked with the mechanical engineering depatment drawing prints to scale. So if you know where to get the information or how to even goggle it. Any help would be gratefully appreciated.
Debra Clifton Thanks again
  • 246 Answers
Hello Debra:
Depending on the Units Model Numbers, you May be Able to View a Breakdown at the Following Site Addy.
http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001
If this Unit has a Model Number that is Not a Sear Number, then Send it to me and I can Locate the Correct Site Addy for you.
I have Just Joined this Site as an Expert and Hope to be here for a Few Years.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
Tiller transmission frozen
I would take it apart and inspect the inner parts for damage
Sep 16, 2012 | Sears Craftsman 208cc* Counter Rotating...
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Have a MTD Yard Machine rear tine tiller Model 410 and when I went to use it this year when I put it in gear the tines did not move. I called the MTD tech and he said it sounds like its in the...
It is the shift fork in the transmission. Bad part design and if you plan to take it apart, use sandpaper and really clean the wheel axle and tine axle before you take it apart.
Mar 20, 2011 | Mtd Garden
Where is the model number on my troybilt rear tine tiller?
If it's as old as mine (circa 1976), it's stamped on the casting right below the T-handle that allows the handle bars to pivot (also the gear case fill cap)
Mar 28, 2010 | Troy-Bilt Pony Garden Tiller
Need manual....for 917293401. took it apart and can not put back together
here ya go! go to this page and there is 7 blue links to choose handles,frame,transmissin,ect..each has pictures and part numbers
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=917.293401
  • CRAFTSMAN
  • REAR TINE TILLER
  • Model# 917293401
Browse Subcomponents To make your search easier, we have grouped this model's parts into subcomponents. Please choose a category below to view the related parts and diagrams.
r3_placement('category_page.bottom_modelsearch'); r3_placement('category_page.bottom_modelsearch');
Aug 28, 2009 | Craftsman 8.50 Torque Rating Dual...
Yardman Rear Tine Tiller tines won't turn. Belt and tenson good. Belt will drive rear wheels in forward or reverse but tines will not turn. when I trun tines by hand nothing seems to be turning in the gear...
The problem lies in the shift lever in the gearbox. A poor initial design that was upgraded twice. The shift fork arms have spread enough for pins to come out of the groove they run in when the tiller is shifted to the last position. (Bending back into position would only be a temporary fix as would not be any stronger.) To replace shift lever, the gearbox cover has to be opened. Seperating the cover can be somewhat challenging. When prying cover apart try to not damage the cover gasket. Gearbox grease is very thick, so gasket's real purpose is to keep water and contaminants out. Leave all gearing and chains in place. The shift lever part number is 618-0245B. Or use assembly kit number 753-0869 (contains shift lever 618-0245B, position indicator, and roll pin.) Part will run in the $56-$68 range and can be found through MTD as well as Cub Cadet. Also can get through Sears PartsDirect.
Jul 26, 2009 | Mtd Bronco Rear Tine Tiller
Tiller tines won't turn where put in gear.
The spring goes in first followed by the ball. The ball should not get in the key way because that is filled by the slider pins that go up into the spur gear that drives the tines. Actually the slider pins drive all of the gears by engaging different gears as the gear collar is moved up and down. The detent spring and ball is the mechanism that is supposed to hold the the clutch collar in place. Mine jumps out of gear when tilling any depth except very shallow. I have reinforced the shifting forks and replaced the pins on the end of it. I believe that the pins wear and the arms spread because i have to keep pressure on the shifting rod or it will jump out of gear when tilling. Even with the reinforcing, pressure on the shifting rod will wear out the pins on the shifting arm. This will be my 3rd reassembly and I am leaning toward the detent spring being weak and allowing the shifting collar to move too easily. I may order an new spring and ball and see if that helps. I am getting pretty good at taking it apart.
Mar 18, 2009 | Mtd Bronco Rear Tine Tiller
Stateman Tiller tine not engaging
Sounds like the worm gears are worn to the point they will not engage.
Feb 20, 2009 | Craftsman Rear Mount Tiller
Garden Logo
1,469 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
