Question about HP Office Equipment & Supplies
Hp 4100n printer paper jam
In my printer there is paper how to remove it plz help me
  • 413 Answers
Off the printer power, Remove the Print Cartridges and insert them correctly and also close the cover correctly and remove if any paper jam there, instal the software which came with the printer in CD
Posted on May 08, 2009
Make sure nothing is jammed in the printer.
Disconnect and reconnect printer.
Aug 06, 2014 | Xerox Hp4100 4100n
My hp laser jet 4001n has a paper jam and does not burn the tonner
please check fuser roller assembly.there is an problem with heater.
Jan 26, 2014 | HP LaserJet 4100N Parallel/Ethernet...
Cartige area jam in hp laserjet m1522nf
Open the cover and remove the toner cartridge, check to see if there is any paper or bits of paper along the path (check on the back as well).
Dec 30, 2013 | HP LaserJet 3050 All-In-One Printer
When powering up the hp laserjet 4100n printer, it makes loud noise, and also states paper jam error and says to open top cover but there is no jam
Thank you for contacting FixYa with your printer inquiry.
yror2cow4ujehy7na20urcensmog20sjgurjxm4tuhbyg-zg2zbskniapisbqy8nf1kewpzeogdnflqy9ha2khbu5k8s2c19uem0r7dwagust35jfphz810nyjeqc2hldzxft7w1k4xvjdgbtu1g=s90-cRB1-8974-000, 4000/4050/4100/4500/4550 Separation Roller" />
HP Laser Jet 4100 Loud noises and paper jams
This error happens when the Pickup Roller/Clutch wears out. It's quite common and easy to repair. Purchase and install Roller/Clutch Part Number RB1-8974-000CN
Action: Do a Google search on the following link [hp laserjet 4100 + Roller/Clutch problems ] and you will locate numerous vender's of this part number item.
It's easy to install. Just unplug the power cord and disconnect the network cable, then set the printer on its back
and remove tray number two. The roller clutch will be visible. It has a pinch release that allows you to slide it off
the shaft and re-install the new one. It should snap in place. Right the printer then reconnect network cable and power cord and power back up. Function should be restored.
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Mar 28, 2011 | HP LaserJet 4100n Printer
I have use the HP Deskjet D1360 series printer paper jam
Simple and slowly remove the jamm'ed paper. Please be sure to inspect the system in detail (you may need tweezers) for any small pieces of random paper laying around.
After this you should be set please let us know if this issue persists as this would be a sign of other issues.
Thanks
Frank
Live-Tech
1-888-361-8511
May 24, 2010 | Office Equipment & Supplies
I want to print from my HP Laserjet 4100N tray 2 instead of tray 1. How can I do that?
Do a Configuration Page print out from the printers 'Information Menu'
Perform a paper path test from tray 2;
<Information Menu> , <Item> , <paper path test> , <Select> , use <Value> to select <Input Tray =2> , <Select> x 3 times.
Is the print out correct?
Check the paper size setting for Tray 2 matches the size you are trying to print onto.
Check / Adjust setting in the 'Paper Handling' menu.
Make sure Tray 1 has no paper in it when you send the print Job.
Check your Driver settings in Windows
Dec 22, 2009 | HP LaserJet 4100n Printer
HP LASERJET 4100N Accessory interface port
The port that looks like a S-Video port is called the Fast infrared (FIR) port.
The port tah looks lik a serial port is an accessory port for optional paper handling accessories.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 21, 2009 | HP LaserJet 4100n Printer
HP 4100N Printer prints too light.
Hi hooperengrg:
I have worked on hplj4100's for years and have ran in to this plenty of times.You will have to have the laser motor mirrors cleaned.That means removing the top cover and cleaning the toner and paper dust build up that has accumulated on the laser motor mirrors that is preventing the laser light from a 100% unobstructive scan to the photo-conductive drum inside the toner cartridge. I hope that this helps
Paul
Mar 25, 2009 | HP LaserJet 4100n Printer
No paper pickup
Hi damodarbk:
it sounds like you need to replace the paper feed rollers.
pdouglasss
Jan 03, 2009 | HP LaserJet 3050 All-In-One Printer
48 people viewed this question
Seeker5211
Seeker5211
