Ricoh MPC2551 SC400 error code reset - Office Equipment & Supplies
5 Suggested Answers
SOURCE: Error code sc 552 on Ricoh CL7100
To clear any code on a Ricoh / Savin copier that will no reset by turning the power off / on you need to first enter the service program mode. This is a safety feature installed when repeated resets of some codes could cause damage to the machine or possible fire hazard. Most of the time these codes deal with the fusing unit. The fusing units operate at around 180 degrees celcius. Thats pretty near the point where paper catches fire so you see the need for safety there. Anyway, you can sometimes get a false fuser code if the room is cold in the morning when you first power up the copier and the machine takes longer than normal to reach operating temp. Another reason can be that maybe you didn't push the fuser back in good enough after clearing a jam and the electrical contacts did not make good contact. In these instances you can clear the code and go back to copying. Should the code come back after doing one of these resets then it means there is a bigger problem with your fuser and you need to call for a service visit to have the problem fixed.
Here is the reset for it:
1. Press the Clear Modes (yellow on most machines)
2. Press the numbers 1,0,7
3. Press and hold the Clear / Stop (red on most machines)
after a few seconds on machines with an LCD display screen you should see the screen change to display "SP mode" with a few selections. On older or smaller machines without an LDC display screen you should see a flashing "0" on the panel. This lets the machine know its ok to reset the code. Do not make any selections in this mode. SP mode if for making electrical adjustments to the copier and taking the machine out of spec can cause a lot of problems for you. Once you enter the SP mode you just need to turn the machine off / on. (make sure you do so with the main switch that you have to rock back and forth and not the button that just gets pressed to shut down the machine, the main rocker switch is often located on the front door or on the left side of the machine, sometimes covered by a swinging cover you have to lift first)
If you do not hit the keys in the right order, the machine will not go into SP mode. You can just start over with step one untill you get into SP mode.
After doing this and the code resets but then comes back again or gives you another code, you'll have to place that service call. If not then happy copying to you.
Posted on Jan 14, 2009
  • 32 Answers
SOURCE: Savin C6045(Ricoh C3260) popping SC400 and SC496
either the id sensor is dirty or defective, or the music sensor is defective.
Posted on Apr 02, 2009
  • 161 Answers
SOURCE: Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Posted on Jan 16, 2010
SOURCE: me marca error sc400 una
hola tengo una maquina ricoh aficio mp c2030y me marca error sc400 Que es y como solucionarlo
gracias!!
Posted on Jun 27, 2011
What is the error code sc400 in ricoh c2030 printer copiers
Ricoh Aficio MPC2030 Code: 400
Description
ID sensor adjustment error
When the Vsg error counter reaches "3", the machine detects "SC400". The Vsg error counter counts "1" when the Vsg detected by ID sensor is more than the value (default: 4.5V) specified with SP3324-005 or less than the value (default: 3.5V) specified with SP3324-006.
Causes
• Dirty or defective ID sensor • Defective ID sensor shutter
http://www.printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20MPC2030&code=400
Sep 11, 2016 | Ricoh Office Equipment & Supplies
How do I fix the error code SC400?
I don't know what is your printer model, but I am sure, that this mashine needs cleaning. The main problem should be that the ID sensors of image transfer belt are dirty. You need technical skills to do that.
Apr 08, 2015 | Ricoh Aficio Office Equipment & Supplies
I have an error code SC400 of Ricoh machine
That code is main motor lock open and see if there nothing blocking the motor like piece of paper
Apr 07, 2015 | Ricoh Office Equipment & Supplies
Spc 220n has a sc400 code
Process Control Error
This SC is issued if the process control adjustment fails 5 times consecutively after AIO
replacement.
• Defective contact at the terminal between the machine and AIO.
• Dirty TM sensor
1. Check the contact of the terminal and re-install the AIO.
2. Clean the TM sensor.
Apr 09, 2013 | Ricoh Aficio SP C220N Laser Printer
Me marca error sc400 una ricoh c2030
gracias!!
Jun 13, 2011 | Ricoh Office Equipment & Supplies
With a printer/copier Ricoh spc221sf, giving code sc400
sc400 is a process control error. Did you just replace the all-in-one toner cartridge? If so, take it back out and try again -- it might not have been in all the way. If the error still occurs, check the contacts between the toner cartridge and the machine -- they may have gotten bent or dirty.
Mar 08, 2010 | Ricoh Aficio SPC210SF All-In-One Laser...
Need help with a ricoh color 6513 with code c400
I assume that should be "SC400"... This is an error which can be reset by turning the MAIN power switch off for a few seconds and then on. The code will be cleared, provided the problem does not happen again.
SC400 - Image transfer belt bias error
Detected Conditions:
- Timing -
While the image transfer belt bias is ON
- Condition -
The feedback voltage is 4.8V or higher, or PWM value is 50% or higher for 500ms continuously.
Possible Causes:
• Poor connections
• Defective high voltage supply board (T1/PCC/BR)
• Defective I/O control board
• Defective main control board
• Worn Transfer Belt
Troubleshooting Procedure:
1. Make sure the high voltage cable and trigger lines are properly connected to the high voltage supply board, I/O control board, and main control board.
2. Replace the high voltage supply board (T1/PCC/BR).
3. Replace the I/O control board.
4. Replace the main control board.
[Signal Check]
• Feedback signal: CN209-9, TP264, or CN211-A4 on I/O control board / CN302-A6 or TP106 on main control board.
• PWM: CN209-10 or TP272 on the I/O control board.
Dec 16, 2009 | Ricoh 6513 Copier
1,115 people viewed this question
k24674
