Question about Kyocera FS-3640MFP
Won't print multiple copies - Kyocera FS-3640MFP
Keeps printing copies of what i copied last week and won't copy what i want this week
((make sure you have the printer turned off)) otherwise you it might print another page if you have multiple prints in the queue you will have to open a file that you are about to print click ok a page will open with a display print queue tab you can see all prints right click on the ones you don't need select cancel
it will be in the print queue where you can stop it printing right click to delete what you are printing you might have to uninstall the printer then reinstall to adjust your print settings
or just go into your printers settings to alter/change the settings
hope this helps
Jun 12, 2011 | Computers & Internet
WHY CAN'T THE PRINTER PRINT MORE THAN ONE COPY AT A TIME WHEN I ASK FOR MORE?
I have used a HL-2140 for a long time without any problem printing multiple copies.
What kind of problem are you having printing multiple copies?
Mar 07, 2011 | Brother HL 2140 Laser Printer
Multiple copy print
Try printing a menu map on the machine and if this is printing multiple copies then it is a machine fault, if not it could be a driver issue.
On the other hand if it is multiple copies on one page, follow the solution below.
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Mar 03, 2009 | Xerox Phaser 7300DN Laser Printer
Printing multiple copies
when you open the driver of the printer there is a information how many copies do you want.it shows 1
Dec 18, 2008 | Office Equipment & Supplies
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
Nov 20, 2008 | HP LaserJet 1320 Printer
My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Sep 16, 2008 | HP LaserJet 1320 Printer
Multiple page printing
if it's one original making 20 copies and doing the problem then you have a problem with the
a) Primary
b) Seperation unit
I would change the Sep 1st
Sep 08, 2008 | Canon PC-940 Black and White Copier
Can't print multiple copies
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Aug 29, 2008 | Brother MFC 420CN All-In-One InkJet...
C5280 won,t print
I had a problem with my C5280 installing another copy of itself when I restarted my computer. Check to see that you don't have multiple copies installed and are possibly trying to print to the wrong one.
Aug 28, 2008 | HP Photosmart C5280 Printer
Kyocera FS-3640MFP Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
