Question about DeLonghi Coffee Makers & Espresso Machines
Milk spout keeps coming off when frothing with my delonghi espresso coffee machine
Noggin
  • 944 Answers
SOURCE: spout for frothing milk pops out
You can get the user manual on this link if you need it; http://www.gaggiaparos.co.uk/ Check page 6 of the download, page 12 of the manual - the spout should just pull off and push back on. If it wont, then either something needs cleaning more, something is stuck in the tube or more likely the part of the nozzle that comes off, something is broken, or you need to use a little bit more force. If it appears broken, (check in particular for a fine crack that is only visible when the nozzle is stretched i.e. when in place. This type of plastic often will close a crack enough to be near invisible when not under tension.) then you could try gluing it although i doubt if this would work. You could just put a stainless steel hose clamp around it, tighten up just enough to make the nozzle spout stay on (bit of a pain, but may work). You can contact gaggia for a replacement - in the USA; Importika 596 Fishers Station Dr. 14564, Victor, NY Mr. Salzman Ph. 585.742.5178 Fax 585.924.1499 web site: www.importika.com e-mail: sales@importika.com Hope this helps - if you can post back a photo or two close up of the problem area, i may have more ideas :)
Posted on Jul 05, 2007
SOURCE: Saeco Talea Giro no steam or water from spout
I have the same problem as well, talked to a repair shop and it's definitely a "send in" or warranty repair. I was told it's an o-ring issue. I have no water coming out of the steam wand and it goes into the dispense tray instead.
Posted on Aug 12, 2009
SOURCE: Delonghi Magnifica Coffee Maker the milk is not
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Posted on Oct 08, 2009
SOURCE: I have a Delonghi Magnifica
I purchased a unit second hand for my wife's birthday today. It's only 4 months old, got it home, tested it, same problem... No froth!
I've read all the posts here and all were very helpful troubleshooting guides however they did not solve the issue.
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definately the first thing to check however if this is not the reason then consider the following.
The larger of the white tubes that has the red and black oring inserts deep into its port on the tap. Why? It pushes steam past the milk pipe directly into the chrome frothing tube which causes a vacuum essentially drawing milk up it's hose creating the froth. What you can't see without further investigation is that on the underside of the tube centered between the red and black orings is a small hole. This hole is responsible for drawing the milk upwards. If this is blocked, and it probably is then no milk and no froth. Use a really small screwdriver to carefully clean the white tube both from the front and the little hole underneath.
So in conclusion. Any air leak between the red and black orings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism. Hope this helps.
Posted on Jan 10, 2010
diodeic
  • 1622 Answers
SOURCE: Delonghi ESAM3500 with not froth milk. Water will
Understanding how the frothing mechanism functions is half the battle in figuring out the solution. It's a simple vacuum type system. No doubt you've read about checking the orings. This is definitely the first thing to check however if this is not the reason then consider the following.
So in conclusion. Any air leak between the red and black rings will prevent the vacuum required to draw milk up the tube and alternatively any blockage of the milk channel will also obviously prevent the flow into the frothing mechanism.
Hope this helps.
Posted on Sep 23, 2011
I have a Delonghi PrimaDonna ESAM 6600. Just recently it stopped frothing milk. To explain fully, I have outlined the sequence of the fault below and resolution steps that I have already tried.
That sounds like the spout is blocked, when the pump goes quiet it is because it has built up pressure and the solenoid is barely moving. Have a probe up the nozzle and see what happens.
Jun 29, 2015 | DeLonghi Coffee Makers & Espresso Machines
Milk does not come out of the milk spout
Do you have any errors is the spout clean try runing some hot water to open block channel see inside for seloniod
Jun 26, 2014 | DeLonghi Magnifica Coffee Makers &...
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi magnifica promblems with water and milk
Frothing jug
For milk frothing issues, soak the milk jug cover in hot water and rinse several times. If it has a froth control that can be removed by sliding in the direction of travel towards the edge whilst jiggling it gently up and down. Clean off the little o-ring with a toothpick, be gentle. The control should easily slide and click back in place when done.
Froth still no good? Examine the milk coupling to ensure the o-rings are in the right spot and are pliable and undamaged. There should be an o-ring (usually green) on the top spigot, a (black) o-ring at the front of the bottom spigot and a (red) oring at the rear. The groove halfway along the spigot should be clear. Now with the toothpick and a hot moist cloth clean all the crud from the milk coupling, especially inside the smaller spigot. Check the tiny hole at the back of the larger spigot is not blocked.
Check the flow from the hot water spout is good. If not, there are internal issues, try descaling. If it is, test the frothing jug, if it is still weak either the jug cover or the milk coupling needs to be replaced. Get them to try a known good test jug at your local coffee service center to find out which, most will be happy to do this at the counter.
Jan 19, 2012 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a Delonghi Prima Donna. Blows lots of stem but wont froth milk. The 3 orings have been replaced and the fittings cleaned, but still no frothing. I pulled the lid apart and it seems ok. Any...
Where is it blowing steam from? If it is coming from the milk spout then it most likely that the milk jug is blocked somewhere. If it is coming from where the jug connects to the machine (coupling) then you might need to change the complete coupling (assuming you used the correct orings). The biggest cause of frothing problems with these machines is lack of cleaning of the milk jug. Soak the top in quality milk cleaner for at least an hour and rinse thoroughly. Also run cleaner through it regularly using the milk only function.
Nov 19, 2010 | DeLonghi Prima Donna Avante ESAM6700...
There is no milk coming out of the frothing part of the Delonghi Coffee Maker, it just makes a noise and steam comes out.
If no milk comes out of frother, check the o-ring on the upper "plug" where the milk jar connects to the machine. There are two connectors; only the bottom one corresponds to the steam output while the upper one is a plug. Mine had a worn out o-ring on the plug, and this keeps the machine from frothing milk.
May 17, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
Delonghi Magnifica 3500 not frothing
use cold low fat milk and keep the milk container in the frig.
Make certain that when washing water come out of both holes.
Jul 09, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Apr 11, 2009 | Saeco Talea Giro Espresso Machine
Coffee Makers & Espresso Machines Logo
29 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
