Question about Dishwashers
Omega dishwasher My dishwasher will not commence. The dishwasher comes up with e1 and two symbols one reflects a tap and the orther a snowflake, what is wrong and how do I fix it
3 Suggested Answers
pappapumpdaf
  • 635 Answers
SOURCE: red tap symbol lights up but no water comes in to
I hate to point out obvious things, but did you crank your line tap all the way out clockwise? And if you are using a line tap, are you sure the piercing needle conpletely punched through the hose?
Try removing the water line from your dishwasher and opening the valve to verify water flow.
Posted on Mar 11, 2010
  • 3247 Answers
SOURCE: Snowflake symbol light is on
It might be showing that the rinse aid level is low. Top it up and see if the snow flake light turns off.
Posted on Apr 23, 2014
E1 error code on omega dishwasher
E1 error on LG Dishwasher - YouTube
? 2:40
www.youtube.com/watch?v=2qcwAyHI9ik
Aug 24, 2012 - Uploaded by 62spindrift My fix for E1 error on LF Dishwasher. ... Maytag Maxima steam Washer has F8 & E1 error code - Pressure sensor & no water detected ...
Aug 28, 2015 | Dishwashers
What does the snowflake mean
Cold Rinse? The plates come out ready to use rather than being hot.
Aug 13, 2015 | LG Dishwashers
Apr 20, 2014 | Dishwashers
If I want to cool the house what symbol is it? the sun or a snowflake?? thanks
Cool symbol is * and sun symbol refers heat and snowflake refers dry mode. Happy?
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
No water is coming into the dishwasher. What should I do?
I will have to assume the dishwasher turns on when you press the start button.
Very hard to provide solution without knowing the make and model of the dishwashwer.
Possible causes of water not coming when dishwasher program has commenced are-
1. water tap is not turned on.
2. the water inlet solenoid in dishwasher is faulty
3. the float switch at base of dishwasher (depending on model) is triggered and thinks the dishwasher is already full of water.
Happy to provide a specific solution if i know the details. Please post a comment.
Jun 13, 2010 | Dishwashers
Red tap symbol lights up but no water comes in to dishwasher
Mar 11, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Kenwood KDW12ST3A
E1 indicated long filling time. Perhaps the inlet filter has clogged. Check the inlet pipe and tap(faucet in usa).
Apr 16, 2009 | Kenmore 15762 Dishwasher
E 1 error
90% of the time you get an E1 error code is because the drain hose is not properly installed between the LG dishwasher and the drain. The hose should connect to an Air Gap valve (almost free at any hardware store) but in a pinch, raise the drain hose near the drain and attach the hose to the bottom of the counter top under the sink. Is should rise almost 30 inches between the dishwasher and the drain or the water WILL siphon out of the dishwasher as soon as the wash or rinse cycle begins (and take 5 minutes before the water gets low enough the cause the E1 error.
Good Luck!
Nov 21, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LG LD-A2T2 Dishwasher returns Error code E1
EI is an error to do with your drain. Check your drain hook up. You should have a loop out side the unit, it should be a minimum 40in in height, or put in a air break. What I believe is happening is your unit is siphoning out. Fix this and you will be able to stop washing the dishes by hand.
Sgt 48
Jun 18, 2008 | LG Dishwashers
Dishwashers Logo
54 people viewed this question
Top Dishwashers Experts
Owen Barnes
