Question about Cameras
Television wont switch on - Cameras
Lights flashing tv wont switch on
remove the rear panel and the lit area with clean dry cloth
Aug 28, 2014 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Turned tv off now wont turn back on
sounds like the on/off sensor and or switch went out. from what i hear this seems to be a common problem with the flat screens
Feb 26, 2010 | Philips 60PP9202 60" Rear Projection...
Tv wont switch on by manual on/off button, button wont stay in
The switch is damaged internally, will need replacing with a new one so some soldering is required, they are normally 250V between 2 -10A Rating.
Nov 05, 2009 | Goodmans W280NS Television
T.v on standby, red light flashing 3 times, wont switch on
Shutdown with a 3x blink pattern occurs if the 12v from the power supply (GF1 or GF2 depending on model) is lost at CN6153/pin 6 to the AU Board Q1224 to Sub Micro IC1205. The suspects, in order of likelihood, are (1) Power supply and (2) the AU board.
Aug 11, 2009 | Sony BRAVIA KDL-40V3000 Television
TV WONT WORK
have you check the switch,? cuz sometimes the switch doesn't work.
Jan 14, 2008 | RCA F27442 27" TV
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
