Question about GE Refrigerators
Control panel flashes 000 on my GE Monogram ZFSB23DRH SS
aasc
  • 1606 Answers
SOURCE: GE Profile model PFS22MISBWW stopped working, panel problem?
Replace the main control board on the back of the refrig . PT# WR55X10656 . It's behind a panel about 10" x 6" .
Posted on Aug 08, 2009
duane_wong
  • 6826 Answers
SOURCE: noisie fan in the freezer.
I read your entire posts and it looks like you solved your problem by replacing the light switch, and that you don't want to use the new board without the new motor which you have on order.
The high temperature in the refrigerator is from the switch not working, but you fixed this?
Posted on Aug 22, 2010
woodchuck789
  • 4070 Answers
SOURCE: GE monogram 48" side by
Your cold control seems to be bad If it doesn't cut the compressor off as you turn it toward off.
Use your model number HERE to find diagrams and locate your parts.Or post your number back here and I'll look.
Posted on Jan 11, 2011
  • 14 Answers
SOURCE: GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Posted on Mar 22, 2011
imufo2
  • 3773 Answers
SOURCE: Hello, I have a GE
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
The icemaker is 110v
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects thenyou need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking or no water at icemaker or door either one, then the valve at the rear bottom of ref needs replacing
First I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also if it is getting drinking water to the door but not to the icemaker (or vice versa) Then you need to replace
the water valve at the bottom rear of the fridge. It is a double valve and one side is not working
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
If you still have trouble GO HERE:
hhttp://www.applianceaid.com/procedures.htm
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
PLEASE GIVE A TESTIMONIAL AND VOTE FOUR THUMBS UP IF THIS WAS HELPFUL
Posted on Sep 10, 2011
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
Why is my GE Monogram, model zfsb26dnd SS, emitting an odor from the front bottom behind the base grill. The air blowing from underneath produces the smell when the fan is operating. The odor appears
The coil underneath the refrigerator, called the condenser coil, is probably blocked with dirt. This causes undue heat on that coil and the dirt stinks. The condenser coil must be cleaned thoroughly.
Dec 10, 2014 | GE Refrigerators
If your refrigerator is frost-free, check the drainage tray at the bottom, probably behind a removeable grille. You may find the tray is full of all kinds of disgusting stuff collected by drainage during defrost cycles. Remove the tray and clean it thoroughly. Reinstall the clean tray.
Ge zfsb23drh
refer to tech to reprogram control it is usually be hind the toe plate on the left side cheers
Nov 26, 2013 | GE Refrigerators
Our GE Monogram (model #ZFSB27DAG SS) side by side is not keeping the refrigerator side cold. It seems to be working fine on the freezer but not the ref. although the ref. side does work but just barely....
First start by Cleaning Your Condenser. If your condenser is extremely clogged. Clean it and let it run over night. Then check if there is a difference in the morning. If your condenser is clean then disregard. Make sure that you have good air flow into the fresh food(refrigerator) section threw the damper control. Click here to see your damper it is number 426. Another thing to check. Open your freezer and look on the back wall to see if there is defrost frost forming. Sometimes you have to remove the back panel to verify if your coils are clear. If you have a defrost problem starting it will restrict air flow into the refrigerator section. This is the most common problem on your model. If you remove the panel and the coils are frosted and restricting air. You can take a hair dryer and defrost them to get yourself by for a few days. This would either be your defrost termination switch, defrost timer or defrost heater bad. Here is your UNIT. Click Here to contact me.
Apr 04, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
