Question about Cameras
Convert pixels to inches - Cameras
MAX SIZE OF MY PICTURE 25 MB IN INCHES
...???? 25MB does not relate to inches... its all relative to "pixel count" size...so it depends on what "size" the default format is... a 25MB picture in 400 x 600 pixels (EXAMPLE= 40 inches by 60 inches) will be GIANT.. while a 25MB picture in 4000 X 6000 pixels (4 inches by 6 inches) will be 10x smaller - SIGNIFICANTLY smaller in inches
Aug 07, 2017 | Max Computers & Internet
Tip
Convert and Play MTS Files to Droid X with 854 x 480 Pixels Resolution How to...
How to Play MTS files on Motorola Droid X? Droid X offers a 4.3-inch screen, a dual-flash eight-megapixel camera, an HD camcorder for 720p capture. And this great MOTOROLA Droid X can only play videos in MP4 with 854 x 480 pixels resolution, and music in MP3, AAC, WMA, WAV, etc format. So is there any way to put MTS files on Droid X for playing? Yes. Aunsoft MTS to Droid X Converter is the recommended tool for you to convert and play MTS files on Motorola Droid X with 854 x 480 Pixels Resolution. Follow the steps below to convert MTS to Droid X for watching AVCHD MTS videos.
Step 1. Load MTS to Aunsoft MTS/M2TS to Droid X Converter.
Download MTS to Droid X Converter and click the Add button to load the .mts files on hard drive.
Step 2. Choose Motorola Droid X MP4 output.
Click the Format option and choose Android > Motorola Droid X H.264 Video (*.mp4) (recommended) for output.
Tip: The default resolution of output format H.264 MP4 is 480*320, if you don't like it, please click "Settings" to set the size (pixel) to 800*480 or 854*480, or you can custom the resolution if you wish to.
Step 3. Join MTS videos for Droid X. (optional)
Tick the checkbox for Merge into one file next to the Settings button, and the MTS joiner will merge the video clips according to the ranking order on the file list.
Step 4. Convert MTS to Motorola Droid X MP4.
Click the convert button under the preview window and the conversion from .mts to mp4 for Motorola Droid X starts right away.
After the conversion is finished, connect Droid X to computer and transfer the video to Droid X. Hope you enjoy the steps above for converting MTS to Droid X.
Tips:
1. If you are using Mac computer, you can use the Mac version of Mac MTS to Droid X converter.
2. If you want to know the way to transfer files to Droid X. Please read: Transfer or Copy Movies and Musics to Motorola Droid X.
on Aug 04, 2010 | Cell Phones
What's a quick way to convert pixels to inches?
pixels / DPI = inches
DPI is Dots Per Inch
Mar 13, 2017 | Computers & Internet
Why possible is 300 dpi printing images and text matter
What is DPI PPI and Why Do They Matter
To some extent, we're all photographers these days. With a camera on every phone and digital SLRs coming down in price, we've all got a trove of photos waiting to be shared. When it comes time to share online, print, or email our favorite images, many are unsure about how to set the image's resolution...
If you've found yourself in this spot, don't worry - dots per inch (shortened to DPI from here on out) is a concept that even confounds some professional graphic artists. Here's a primer DPI so you can stop worrying about technology and start sharing your photos.
Getting started
Digital photos are comprised of pixels, much like the individual boxes on a sheet of graph paper. DPI tells you how small those pixels will be when the image is printed. For example, "300 dots per inch" means that 300 pixels fit across each inch. If your photo is 600 pixels tall by 900 pixels wide, for example, it would come out at 2" x 3" inches if you were to print at 300 DPI. Keep in mind that most digital photos are several thousand pixels in either direction, but for the sake of simplicity, we'll use the more manageable 600 x 900 pixels.
Separating pixels from presentation
It's important to separate DPI from the raw pixel dimensions, and this is where even the pros slip up. DPI is not an indication of image quality or clarity. When you print that 600 x 900 pixel image at 300DPI, it'll likely look pretty sharp, because every inch is densely packed with pixels.
Now imagine printing that same image, with the same number of pixels, at a mere 30 DPI. As each inch would have only 30 pixels across, the density drops immensely and the image prints much larger: 20" by 30". What was once sharp now appears blurry, because each individual pixel is now ten times larger than before. By separating DPI from actual pixel count, we can understand that raising DPI doesn't magically improve a photo. DPI simply takes the same data (the original pixels) and alters how we'll view them.
Pin it It's all about context
Another factor is viewing distance. Just think of the eye chart at your doctor's office. If you're a bit nearsighted, the tiny letters at the bottom are illegible specks, while the letters at the top are easily discerned. In actuality, each tiny letter may be half an inch tall, but the distance makes them seem microscopic. Now consider our 600 by 900 pixel image. When we printed it at 30 DPI, the giant pixels made it look blurry. Were we to look at it across the doctor's office long hallway, however, it may look just as sharp as the 300 DPI print did in our hands. This illustrates how DPI is more about context than quality.
Pin it Pixels Per Inch
You'll notice I've been talking about DPI in relation to printing only. This is because while printers can produce a variety of DPI settings, a computer display's resolution is fixed - its pixel density is part of the physical hardware, and cannot be altered. When talking about displays instead of print, most use the term PPI, or "pixels per inch."
If you intend to put your 600 x 900 pixel image online, switching the resolution to 30, 300, or 3000 PPI is completely arbitrary, because the computer display can't change its density. As modern desktop displays usually have a PPI in the low 100s, the 600 x 900 pixel image will appear around 6" by 9" (mobile displays may be much higher). Of course, your web browser could display the image smaller if need be, but it will do so by averaging and eliminating pixels, not squeezing them to be physically smaller. This is why it's always important to keep your end goal in mind when working with images.
In summary:
• An image is defined by its pixel dimensions - # pixels tall by # pixels wide
• DPI/PPI determines the scale and pixel density at which image will be displayed
• What appears blurry from close up may look fine at a distance, so consider how an image will be seen
• Printers can produce a range of DPIs, while displays have fixed resolution
Whether you're a blogger dealing with an upload limit or are just trying to print a photo to hang on the wall, understanding DPI/PPI can go a long way. I hope these tips help you feel more in control of your images and how you share them with the world!
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
My writing is so small i can't read any thing on my computer because of this i can't read anthing you write back so can someone call me at 901-283-0239
You can increase the size of text by pressing control + or - buttons press control button first. Also there is zoom in the tools section and also you can increase the size of text in the control panel or the web page under tools sections of most browsers. If we new the browser or what you text is small in or even if it was small every where you can change the resolution size of your Windows. Win 7 you can incease text by going to control panel click on display once there go to where it says increase your text size. Not sure what your operating system is either. So assuming it is Win 7 I hope that this assists you. John
Jan 26, 2011 | Computers & Internet
I install window 7 but my benq 15" lcd monitar's screen rosuation not competible. pls guide me how i increase the rosulation thnx
As for your 15" LCD BENQ Monitor, "1024 x 768" pixels is the Maximum Resolution
If you increase your screen higher than the Maximum resolution you get a black screen! because the monitor cannot support the resolution higher than "1024x768" pixels.
How to change your screen resolution Win 7-> Link
FYI
Here are typical resolutions for some popular screen sizes
19-inch screen (standard ratio): 1280 x 1024 pixels
20-inch screen (standard ratio): 1600 x 1200 pixels
22-inch screen (widescreen): 1680 x 1050 pixels
24-inch screen (widescreen): 1900 x 1200 pixels
Hope it helps.
Nov 22, 2010 | Computers & Internet
Pixels per inch
Pixels per inch (PPI) is a measure of the sharpness
Apr 05, 2010 | Dell GX270 P4 256/40/48X/XPP/NONE...
Picture sixe reduced and picture breaks up with converter box
You can change the way the channels can be displayed/viewed by a video setting, consult manual. When pic breaks into pixels and sound goes it's usually a reception problem so you'll have to adjust the antenna facing a direction that makes that channel come in clearly. It helps to experiment with positions and antennas.
Nov 17, 2008 | Insignia Digital-to-Analog Converter for...
Cameras Logo
229 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
