Loading sirius I have a 2013 Kia Soul and my sirius radio is stuck on "Loading Sirius". I've taken it to the dealer twice and spoke to Sirius 3 times. Still not working. Any suggestions?
SOURCE: Sirius radio repair
chrisckb1973@yahoo.net
Posted on Jan 27, 2008
SOURCE: Sirius Satellite Radio
Go into the menu and reset to factory default
Posted on Sep 25, 2008
SOURCE: sirius radio reset on dodge ram 2008
I have the same problem. When Sirius sent me a new "update" signal, I lost more channels. They don't have any idea. Did you figure out how to reset?
Posted on Jul 06, 2009
SOURCE: white square on sirius stiletto 2
I ran the stiletto device recovery program and it works again. You can find it on the Sirius website by searching for "stiletto device recovery". However, it does delete all of the content that you have saved on the stiletto.
Posted on Jul 31, 2009
SOURCE: Satellite radio (REF) not connecting with Sirius.
how do i use factory satalite antenna on a dodge ram 1500 2006 for after market radio
Posted on Feb 28, 2010
Sirius radio problems
I would do the following, hoping one of them works.
1) DISCONNECT the power to the radio and SiriusXM unit to "clear" it. Then reconnect and ask Sirius to resend signat.
2) Ask Sirius to UNSUBCRIBE that radio so it is deactivated. Then, have them reactivate and resend programing signal.
3) Be sure your car is outside under clear sky when Sirius sends the program signal.
4) It is possible the antenna cable to your unit is loose at the connections and/or damaged. A weaker signal may get your stations, but may prevent the additional Navigational signals. Have the antenna checked thoroughly and tested. If car is still under warranty, this should be a covered diagnostic/repair.
5) Finally, be sure the correct Radio Serial Number is being activated. If your radio works, that is one service. But maybe they are putting a wrong number by some chance into the system to fix this one? For example, you have TWO radios in TWO cars. Are they sending the turn on signal to the WRONG radio? Not as farfetched as you might think.
Jun 19, 2014 | Delphi Roady XT XM Radio Receiver
I have a Kia Sorento 2013 and my radio turns on but no sound Wuts my radio code?
I just think that you have it set to SIRIUS and have no Sirius subscription. Just press the radio button on the dashboard to go to classic AM/FM mode.
Aug 08, 2013 | Cars & Trucks
My sirius is stuck on down loading, it still says 0 persent down loading .
Unfortunately some models of the Starmate Replay will not receive the latest updates. I have seen this with XTR8, which is essentially the same radio. If it is one of these outdated receivers, it will not receive the update, and there is not much you can do. You used to be able to let them sit for about 24 hours and it would eventually take. That does not appear to be the case anymore. This isn't the case with ALL of the ST2s if you wanted to hunt down a replacement. www.tss-radio.com can help
May 27, 2012 | Sirius Starmate ST2 Satellite Radio...
Xm radio stuck on loading its in a 2007 sonato
I have Sirius and I have noticed this problem a few times. What worked for me is unplugging the unit. I have a toyota and I installed the Sirius modules behind the glove box. All I do is unplug the units from the power source and the feed to the radio, then let it sit for a few minutes, plug it back in, worked every time for me.
Hope this helps.
Jun 11, 2011 | XM Radio (XMP6000)
I bought a new kia with sirius installed already. I live in FL and I park my car in a garage overnight and when I go out to work at 7:30am my sirius does not work. I will drive 15 minutes to workand it is...
I'm having same problem with XM radio in new 2011 Nissan Frontier. If the temp is above 32F in morning it acquires signal within a minute. If below, stays "loading" all the way to work (30 minutes) Come out later when warmer and functions normally. Could be antenna connection or cold throws tuner frequency off slightly. Interested in suggestions as Dealer will probably need guidance.
Nov 30, 2010 | Sirius Satellite Radio Receiver
Reactivated Sirius Radio today. Display shows P1, p2.p3, etc with flashing channel 184. Unit will not work. Tried soft reset with Sirius, still no luck. Sirius said to go to the dealer and have them do a...
Disconnect negative wire from vehicle battery; wait minimum of 1-hour, then reconnect.
Turn on satellite radio, call Sirius tech support to have them resend activation signal. Stay on line with them since it may take them 2 - 3 tries.
Aug 27, 2010 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Persistent occurance of "Sirius Seek List"
http://www.sirius.com/pdf/manuals/ST2-User-Guide.pdf
See page 24 on [or search for alert]. It's taken me a while to find this as I HAD the same problem
Mar 13, 2009 | Sirius Satellite Radio Sirius Starmate ST1...
Did you ever get your starmate to work?
same here...
happened today...these all seem to have expiration dates
it came to life twice but now , it's possible fubar
shame to throw away,as i have the home kit .. non compatible , or buy another?
Jul 16, 2008 | Sirius Satellite Radio Sirius Starmate ST1...
243 people viewed this question
 Grubhead
Grubhead
