Question about Digix Blu-Ray DVD Player
How do I reset my dvd player - Digix Blu-Ray DVD Player
Flashed my XV-NP1 with wrong firmware. now player wants original firmware CD. I need original firmware ISO!!!
  • Check the DVD player to ensure that you do not have a DVD disc inserted into the device. Press the "Eject" button and lift out any DVD present in the device.
  • Turn off your JVC DVD player.
  • Unplug the device from the power source.
  • Examine the front or rear of your DVD player and note the model number.
  • Reset your particular device using the "DVD Reset Procedures" documentation provided by JVC (see Resources). Cross-reference your particular device's model number with the instructions provided within the reset procedure documentation
  • Read more: How to Reset a JVC DVD Player ' eHow.com http://www.ehow.com/how_6940950_reset-jvc-dvd-player.html#ixzz16g5rec91
    Nov 29, 2010 | JVC XV-NP1SL DVD Player
    Tip
    Pioneer DVD-400V DVD Player Interlace Reset
    Pioneer DVD-400V Interlace Reset
    To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and loosing picture, follow these steps:
    1. Switch everything off.
    2. Reconnect using the supplied video cable (standard RCA Red White & Yellow).
    3. Switch the player to standby.
    4. Press and hold the Standy/ON button while pressing the |<< button.
    This resets your player to default video output, allowing you to reconfigure your HDMI settings to 1080i, and then reconnect your HDMI cable.
    I hope that helps.
    _____________________________________
    Pioneer DVD-400V Manual Download
    Pioneer DVD-400V HDMI Reset
    on Jun 06, 2010 | Televison & Video
    Tip
    Pioneer DVD-400V DVD Player HDMI Reset
    Model: Pioneer DVD-400V
    To switch your Pioneer DV-400V DVD player back to an interlaced video mode after selecting a progressive scan mode and losing picture, follow these steps:
    2. Switch the player to standby.
    3. Press and hold the Standy/ON button while pressing the |<< button.
    This resets your Pioneer DVD-400V player HDMI output format to 480p.
    I hope that helps.
    Player won't open. how do we reset?
    my dvd player is stand on the red light when i insert the dvd the dvd will hand after few seconds what is the problem please solved my problem
    Jan 04, 2010 | Philips DVP642 DVD Player
    How to reset cyberhome ch-dvd 300 password
    press and hold the stop button on the front panel on ur dvd player ur player will be resetting
    Nov 30, 2009 | Cyberhome CH-DVD 300 DVD Player
    Tip
    Pioneer DVD-400V HDMI Reset Model: Pioneer DVD-400V To switch your Pioneer...
    I hope that helps.
    on Jun 06, 2010 | Pioneer DV-400V DVD Player
    Re set passwords 3256
    sir
    when enter Mp3 player to DVD player, DVD want password. kindly infrom reset password
    For
    Pabitra kr. Das.
    Jun 22, 2009 | Philips DVD625 DVD Player
    Reset Cyberhome CH-DVD 300
    Dear friend,
    Press and hold STOP button on front panel of the player more than 5 sec. The player reset after 5 sec.
    Mar 09, 2009 | Cyberhome CH-DVD 300 DVD Player
    DVD stopped working and cannot do setup.
    You probably need to reset your DVD/VCR/Combo. Go to www.samsung.com. Go to <Support>. In the search box, type in the model of your DVD/VCR/Combo. Or type in, >how to reset DVD/VCR/Combo<. Each model has different reset method and there are hundreds of models!
    853. How To Reset Your Samsung DVD Player STEP 1
    STEP 1. DVD Reset List
    Samsung DVD players have a built-in reset procedure that resets the DVD player to the factory defaults. You can use the reset procedure to reset settings that don’t work with your TV or to resolve issues such as unit lock up. To run the reset procedure, you press one or more buttons on the front of the DVD player and hold them for at least fifteen seconds. The buttons your press depend on the model you have.
    Important: For the reset procedure to work, you must press the buttons on the front of the player, not on the remote control for the player.
    Below is a list of all Samsung DVD players and the buttons to press to run the reset procedure.
    DVD511 - Stop / Play
    DVD611 - Stop / Play
    DVD709 - Stop / Play....
    Many, many other models follow but cannot be listed here because of this site's text limitations.
    Jun 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
    DVD player
    try to reset it to factory settings.
    Jan 11, 2008 | Cyberhome CH-DVD 300 DVD Player
    Digix Blu-Ray DVD Player Logo
    32 people viewed this question
    Top Digix Computers & Internet Experts
    David Payne
    David Payne
    Are you a Digix Computer and Internet Expert? Answer questions, earn points and help others
