Question about Sharp AR-507 Copier
I have a Sharp AR-507. Error F2-00. How to fix?
I have a Sharp AR-507. I just filled the toner hopper with new toner and got an error message F2-00. I understand this is error means "toner control sensor open", but how can this be fixed by a user instead of a tech?
  • casey509 May 11, 2009
    The manual does not indicate the presence of a developer unit or at least refer to anything called a "developer unit". Please clarify the response with a way to repair, not replace parts.
It could also be the sponge roller in the toner hopper. The old ones started to deteriorate after a while so sharp modified them.
Posted on Jun 17, 2009
    Problem Solver:
  • 7 Answers
Resetting the toner cartridge by removing it from the unit and putting it back on.just twist the green knobs/lvers..pull the cartidge a little and push it back untl it locks.restart the unit.
Posted on Jun 10, 2009
    President:
  • Sharp Master
  • 990 Answers
Hello sir; The error code you display it's means toner senser defected need to replace, it located at developer unit.
Posted on May 09, 2009
    Habit-Forming:
  • 41 Answers
Hello
you need change the toner chip
Posted on Mar 27, 2012
100% sure: toner roller (sponge) goes bad when new toner is installed because of the weight of the new toner, after replacing the toner roller new developer is needed cause the defective toner roller let excess toner thru ans got overtoned, no way to clean. This is NOT a job for a beginer, better know what you are doing.
Posted on May 31, 2011
Sharp ar 5625 error f2-02 ?
Dear
The failure of toner supply may cause this code. this may be due to the exhaust of toner or CRUM life end. From hardware point of view the hopper (toner feeding ) assembly and its sensor to be checked.
Thanks.
Feb 03, 2015 | Sharp Office Equipment & Supplies
I refiled ink in my AR-507 coppier and it showed error code F2-37. how do i resolve it?
You have to change the developer and to purchase a new branded toner then you have to change it and some more steps are there feel free to rate this articile I can give you the step by step instruction
Apr 30, 2011 | Sharp AR-507 Copier
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
Display reads E-7 03 error code
E7/03 is a lsu error. The LSU is the “printer head” of the printer. But instead of emitting ink, the LSU emits a laser beam, directing it at the drum of the toner cartridge. If replacing the lsu does not fix it it may be the mcu pwb, but most likely the LSU.
May 11, 2010 | Sharp AR-507 Copier
I want to connect my ar-507 gray digital copier to pc UBS port
Did you use a pcl driver? What was the error message?
Nov 19, 2009 | Sharp AR-507 Copier
Sharp Ar-507
An F2 code depending on the secondary code is related to the toner or drum.
F2 00 Toner control sensor open 22 LCC 24v power abnormality
02 Toner motor connector unconnected 50 Non supported option connection (Desk Unit)
31 Process control trouble (Drum surface reflection) 51 Non supported option connection (LCC Unit)
32 Process control trouble (Drum Mark) U7 00 RIC communication trouble
37 Drum marking sensor gain adjustment error U9 00 Operation control communication trouble (ICU)
39 Process thermistor breakdown
Jan 02, 2008 | Sharp AR-507 Copier
Sharp AR-507 Copier Logo
992 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
