Question about Mattel Uno Attack! Card Game
The drive belt for uno attack is broken
Where can I get a new belt?
Can I fix a NB1500 treadmill belt that is bowing in the middle? I've tried adjusting the tighteners on the back and cannot eliminate the bowing in the middle.
No, you need a new belt as it is stretched because that is where it gets pounded all the time. $50 to $100 depending on the quality you choose.
New Balance 1500 Treadmill Walking Belt 20 x 119 - Treadmill Doctor
https://www.treadmilldoctor.com/new-balance-walking-belt-1500
Replacement Walking Belt For The New Balance 1500 Treadmill. Belt size 20" X 119".
New Balance 1500 Treadmill Walking Belt - eBay
www.ebay.com > ... > Fitness Equipment & Gear > Other Fitness Equipment & Gear US$94.99 - ‎In stock
New Balance 1500 Treadmill Walking Belt in Sporting Goods, Fitness, Running & Yoga, Fitness Equipment & Gear, Other Fitness Equipment & Gear ' eBay.
Amazon.com : New Balance Treadmill Running Belt Model 1500 ...
https://www.amazon.com/Balance-Treadmill-Running-Belt-Model/.../B00H4QKAOO Rating: 5 - ‎1 review
This is a 1-ply Residential walking belt, some sellers will try to sell you a 2-ply belt (claiming better quality) for your treadmill, which is not recommended for ...
Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt ...
https://www.amazon.com/Newbalance-Treadmill-Running-Belt-Model/.../B008EYOF... Amazon.com : Treadmill Doctor Newbalance Treadmill Running Belt Model 1500 : Exercise Treadmill Belts : Sports & Outdoors.
NB1500 treadmill belt Google Search
Aug 14, 2017 | Exercise & Fitness
I do have a 1999 grand marquis w/ belt problem the belt does not have enough tension so i did change a new tensioner abd also a new pulley still have the same problem belt is too loos
If the belt worked properly before then it may have stretched and needs to be replaced. If you recently changed the belt and discovered the slipping problem, you have the worng belt on your car.
Jan 14, 2014 | 1992 - 1999 Mercury Grand Marquis Belt...
Replace fan belts
When replacing fan belts, route the new belt through the pulleys so that it uses the exact same path as the old belt. You may need to loosen the belt tensioner a little bit more in order to slip the new belt onto the final pulley.-------------------------------------------------------------------------
New UPA USB Programmer
Apr 20, 2013 | Cars & Trucks
How do I replace the serpentine belt on a 1999 Kia Sephia?
1.8L Engine
  1. Using a belt tension gauge, measure the drive belt tension and compare with the following specifications:
    1. Alternator belt (new): 86-103 lbs. (383-461 N)
    2. Alternator belt (used): 68-86 lbs. (304-383 N)
    3. A/C compressor and power steering pump belt (new): 110-132 lbs (491-589 N)
    4. A/C compressor and power steering pump belt (used): 95-110 lbs. (422-491 N)
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click HERE for zoom)
  2. Using the deflection method, apply moderate pressure (about 22 lbs) halfway between the pulleys, and compare with the following specifications.
    1. Alternator belt (new): 0.31-0.35 in. (8-9mm)
    2. Alternator belt (used): 0.35-0.39 in. (9-10mm)
    3. A/C compressor and power steering pump belt (new): 0.31-0.35 in. (8-9mm)
    4. A/C compressor and power steering pump belt (used): 0.35-0.39 in. (9-10mm)
  3. If the specifications fall outside the ranges given, adjust the belt as follows:
    1. Loosen the alternator mounting bolt and adjusting bolt.
    2. Adjust the alternator to get the specified belt deflection.
    3. Tighten the bolts, then recheck the tension.
      Fig. Adjusting the alternator belt-1.8L engines
Hope helps.
Oct 09, 2011 | 1999 Kia Sephia
How do I replace the serpentine belt?
1.8L Engine
      Fig. Using a tension gauge to measure the alternator belt tension - 1.8L engines (click image for zoom)
Hope helps.
New Serpentine Belt Causes Squeeling. Added gobs of belt dressing, still squeels. Old belt was only half a belt--totally worn out. New belt is therefore tighter and putting more force on pulleys. Do I...
Take off the new belt ... toss it ... get a new belt ... before you put it on ... clean all the pulleys twice ... final cleaning should be alcohol.
Oct 27, 2010 | 2003 Mini Cooper
Retractable seat belt wont close
Is this a NEW seat belt?  Or a junkyard part... Per the Toyota 1988 Repair Manual - the belt is allowed to be pulled out at a tile of 15 degrees or less; and cannot be pulled out at over 45 degrees of tilt.
Your problem is the belt is not retracting.  The manual states to replace the assembly.  It also states: "Whenver installing a new belt assembly, verify proper operation before installation."
If a new part does not have proper operation; have it replaced. If this is a 'used'  new part - get a NEW seat belt.
Apr 07, 2009 | 1988 Toyota Camry
Changing belts
Air conditioning system Drive Belt (INSPECTION) Deflection : Used belt : 6.0~7.0mm (0.24~0.28 in.) New belt : 5.0~5.5mm (0.20~0.22 in.)
6f4a2c5.gif NOTE These items when adjusting belt tension : If there are cracks or any damage evident on the belt, replace it with a new one. "Used belt" means a belt which has been used for five minutes or more. "New belt" means a belt which has been used for less than five minutes.
ADJUSTMENT 1. Loosen the tension mounting bolt(B). 2. Turn the adjusting bolt(C) to obtain the proper belt tension, then retighten the mounting bolt. 3. Recheck the deflection of the drive belt.
Aug 17, 2008 | 2005 Hyundai Elantra
Mattel Uno Attack! Card Game Logo
80 people viewed this question
Top Mattel Toys Experts
thegtw
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
