Question about Samsung LN55B650 55 in. LCD HDTV
Capacitor ln55b650 will not start
Samsung tv made loud noise and will not power up
Sounds like capacitor exploded. Check power supply area. Flat panel tv's use cheap capacitors. Most likely this capacitor is in the power supply area. The top will be popped, they're made to pop when they go bad. Have professional fix it.
Feb 14, 2014 | Samsung Televison & Video
My Samsung LN55B650 has problems with the picture. The pixels will flicker in and out. It is not a constant problem, but when it heats up it gets worse. I have video of the problem as well. manufactured in...
it is the screen driver on the back of the screen over heating it will fail and need to be replaced. you can get them on line or bay from around 15-65 pound. make sure you get the same number as the board off your tv even the (ver) number. hope this helps you.
Oct 01, 2013 | Samsung LN55B650 55 in. LCD HDTV
I have a Samsung 55 in LCD tv that keeps powering on & off. I checked the caps & they look good and have the higher voltage rating of 25 volts not 12 volts. Any idea what the issue could be?
The capacitors can fail and show no outward signs. You need a special meter to check them. Without a schematic and voltage test points it would be hit and miss trying to find the bad part without the right test equipment.
Nov 14, 2012 | Samsung LN55B650 55 in. LCD HDTV
Whats wrong with my Samsung 55" LN55B650 LN55B650T1F tv?
These are not meant to be repaired, just boards replaced.
Follow if you are able the AC voltage into the set and then when it changes to DC follow that---confirm all voltages are present, a total dead set usually means something open not too far from the power cord.
Aug 31, 2012 | Samsung LN55B650 55 in. LCD HDTV
I have a Samsung 52 LCD TV about 2-1/2 years old. Start clicking about 10-12 times then it turns on. today I turn it on and it just keeps clicking and will not turn on? any Ideas.
The power supply board it is dying and most likely causes by weak and dying capacitors parts bulges up or puffing up leaking.The power supply board,that the board where the power a/c cord plug into it.U have all the tools,understanding basic electronic also can do basic soldering work?Yes check the power supply board carefully replaced all dying to be dead capacitors parts or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jan 25, 2011 | Samsung LN55B650 55 in. LCD HDTV
I have a Samsung LN55B650, and cannot use the remote to change channels, hav eto use cable remote. I change to TV mode, and program in channels, but that option is not available once I switch to HDMI2,...
OK the cable box remote is the only one that can change channels in this case. because you are using the tuner in the cable box not the TV.
all you need the TV remote for is to turn the TV on and off and turn the sound up and down. if you used the cable input on the TV then the tv remote would be used to change the channels.
Dec 25, 2010 | Samsung LN55B650 55 in. LCD HDTV
Wont turn on. it is plugged in properly and remote has new batteries and lights up. Programmed to operate TV. No red pilot light illuminates on the TV.
If the front panel does not even light up, then you do not enevn has the standby 5vdc working at all. Power supply module will be the first place to look.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Oct 02, 2010 | Samsung LN55B650 55 in. LCD HDTV
Why does my Samsung Ln55b650 give me a no signal when I switch to my ps3. Doesn't do it all the time.
It's just HDMI compatibility. Not a major concern, there's nothing wrong with the TV or PS3, they just don't play nicely together. You may want to contact Samsung regarding a firmware update for your TV. You may also find it on Samsung's website with instructions. They are very easy to perform. If this does not resolve the problem, the only solution you have remaining is to use the component cable connections from your TV to PS3.
Mar 15, 2010 | Samsung LN55B650 55 in. LCD HDTV
I just bought a 55 inch Samsung LN55B650. There is a ghostly lines going up the picture when veiwing. What is that?
probably weak signal
how many things do you have hooked up if you have a lot then hook the cable or what ever it is to a separate thing don't go through anything
Aug 16, 2009 | Samsung LN55B650 55 in. LCD HDTV
Samsung LN55B650 55 in. LCD HDTV Logo
15 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
