Question about Empire DV-35 Heater
The pilot does not stand
When I let off on the pilot, it goes out
Magic Chef Chateau stove pilot goes out when two burners are used!
The pilot flame may not be set high enough to cope with the demand of two burners.
Dec 19, 2013 | Ovens
Tip
I have a standing pilot that wont stay lit.
If you have a standing pilot that wont stay lit and you have to keep relighting it, it can only be a couple of things that will do this.<br /> 1. Try tighting the thermocouple at the gas valve. (this is a thin copper line that goes from the gas valve and goes to the pilot light.)<br /> 2. Make sure that the tip of the thermocouple is in the pilot light flame.<br /> 3. Make sure that the thermocouple is clean.<br /> <br /> if you have done these and it still doesnt stay lit, buy a new thermocouple.
on Mar 14, 2011 | Heating & Cooling
Gas fireplace
replace pilot assembly and pilot generator
Sep 05, 2013 | Pool & Spa
Hello, i lite the pillot and and start up fire so its working and some time during the day the pillot goes out?
Mar 21, 2011 | Heating & Cooling
I have a natural gas poolheater- Raypak Versa 305. The pilot lights but when I release the button after waiting1 min. the flame goes out. This happens over and over so what should be done?
You, or someone should check the flame sensor. If , as it looks, you have a standing pilot (one that stays on), the flame sensor has to be aware of the pilot or all will go out. Good luck...Lee
Jun 10, 2010 | Raypak BURNER TRAY ASSEMBLY
Pilot light on heater goes on and off when it is heating
If it is electronic ignition this is normal. If it is a standing pilot then you have a problem with the gas valve. With electronic ignition this will light the pilot on a call for heat.
Dec 14, 2009 | Procom ML300HGA Heater
Pilot light goes out when burners kick on burnham
Get a toothbrush and clean the **** off the pilot, could be partially blocked. Change the safety thermocouple. Check the plenum for cracks. A cracked heat exchanger can cause this.
Nov 07, 2009 | Goodman GMS90703BXA Heater
Cozy heater 35000 btu pilot light goes out every 4 days
The thermocouple needs to get red hot. If the pilot flame is too low or too high or if it is not pointed on the thermocouple well, it won't stay hot enough. If the pilot flame is too low, a draft caused by opening a door could blow it out. If correcting this doesn't fix it, it could be a bad thermocouple or control. The factory assembly on these heaters is not the best.
Feb 02, 2009 | Cozy Enclosed Front Console Heater 70,000...
Heater runs for appox 2-4 minutes and then shuts down..
what kind of furnace do you have? Is it electronic or standing pilot? If you have electronic then it could be flame sensor if you have standing pilot and the pilot goes out and you have to relight then it is probably the thermocouple what is going through an 1/2 flex pipe explain this a little more. Have you checked filter.
Jan 21, 2009 | Procom ML300EBC Heater
Empire DV-35 Heater Logo
71 people viewed this question
Top Empire Heating & Cooling Experts
Paul Carew
vance jones
Dan Webster
Dan Webster
Are you an Empire Heating and Cooling Expert? Answer questions, earn points and help others
