Question about Samsung Digimax S600 Digital Camera
Samsung s630 I've been trying to find an answer to this question. My camera stopped working. I put in new batteries and when I press the power button the green light goes on for lil bit beeps 3 times and turns off What can I do?
  • 3 Answers
Re: samsung s630
Hi all!
i got the same problem... but in my case samsung service cost was almost the same as the cost for a new camera!! :(
so i had nothing to lose and i did try to fix it by myself.....
i opened the camera,got really deep and found that what was causing that problem was a small hair stuck into the spur gears that open the lens.... it had some dust too... i cleaned it and works perfect....
id you dare to do it you really have to be very careful or youll really break your camera, i can post some photographs about how to do it and what screws to remove...
See ya!
Posted on Feb 03, 2008
Re: samsung s630
Put ur camera in the freezer for at least 2 hours and put in a fresh pair of batteries thats what i did to mine, and guess wot? it works
Posted on Jan 15, 2008
Re: samsung s630
Hi Everyone, I fixed my problem by sending the camera to a designated camera repair shop. They fixed my camera without erasing the pictures4.gif that I had saved on there. What savy_7 says is true, however if your problem is a lens problem no type of batteries will make the camera work. Go through the online repair process (go to the library or internet1.gif cafe if you have to), if you are within your warrenty period then the repair is free you just have to pay for postage one way. Hope this helps. God Bless. Have a Marvelous New Year with lots of pictures. the camera is a good camera when it works. Don't call customer service GO ONLINE THAT'S HOW IT WORKS. You will not get a return phone call.
Posted on Dec 17, 2007
Re: samsung s630
17 Dec 2007
I called Samsungs 800 number. Never got a live person on the other end. I got a recording requesting me to leave a message
I left a message but have not heard from Samsung yet. I hope they will return my call.............someday in my life time
Re: samsung s630
I was having the same problem with my Samsunbg s630 - my daughter researched and discovered that one needs to use 2500mAH or higher rechargeable batteries to make the camera work properly (I bought the 2650 mAH rechargeables). We immediately bought this type of battery and now my camera is working just fine! Hope all of you have the same good fortune when you try this batterty,
Posted on Dec 15, 2007
  • 2,985 Answers
Re: samsung s630
Main board fault return to seller or maker
Posted on Oct 17, 2007
0 characters
3 Points
My samsung s630 camera takes great pictures, but my flash will not work on any setting i choose please help
Dear Sir,
1.Please put your camera in manual mode or program mode after this select the flash option and then select fill in mode.
2.After this press the shutter button and hold it this will energize the flash and help to take the photo.
3.If these steps do not work then you will have to change the batteries.
Regards, Chandrachur
Nov 02, 2010 | Samsung Digimax S630 Digital Camera
S630 screen not working
i knoww cus i had took pictures on firday at dha skatinq rink with my freinds dhen saturday my camera wasnt workinq so then i decided to buy some new batteries, i bouqht some new batteries on monday & quess what it wouldnt stay on,! like it came on for like 5 sec dhen it shut off , i f**kinq hate dhat camera. !
Aug 07, 2009 | Samsung S630 Digital Camera
Samsung S630 camera says "low battery" then shuts off
This camera needs rechargeable batteries usually lasts about a week with much use. I thought what a waste of batteries then tried these rechargable and the situation hasn't occured . it is probably because it is small digtal camera which uses alot of power.
Dec 31, 2008 | Samsung Digimax S630 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
S630 lens out and wont turn on
Cameras belonging to the S Series really do have a battery type option that needs to be set up first for proper power connection.
Recommended batteries are just:
- Alkaline (Non-rechargeable)
- Nickel-metal Hydride (Rechargeable)
Just the proper battery type by:
- Pressing MENU/OK button
- Scroll to the right until you are in SETUP 2
- Keep on scrolling down and look for battery type
- Press the right button to pick up on 2 options
like Alkaline and Ni-MH
- Press MENU/OK for changes to be saved
- Keep pressing MENU/OK to get out of the MENU
Once, it's done, camera needs to be turned off for a few seconds
so that settings made will be refreshed with the camera.
As you turn camera on, you're now ready to take many pictures.
ALKALINE (Non-rechargeable) batteries when set to the correct battery type will really take a maximum of 100 pictures.
For the Rechargeable batteries (Ni-MH), when those are fully charged, and the battery type is set to Ni-MH, it will be taking more than a hundred of course.
I hope this help you a lot.
Jan 11, 2008 | Samsung Digimax S630 Digital Camera
Samsung S630 junk
the beeping is the battery being dead but the black screen with random stuff sounds like the LCD panel is busted. i work at a repair shop and have the same problem with my samsung s630 major problem...lcd panel is not available anylonger for that model.
Dec 25, 2007 | Samsung Digimax S630 Digital Camera
Samsung S630 date gets reset while changing the batteries
It is really NORMAL that the date will be reset to the Manufacturer's date whenever you are changing batteries.
For you not to keep on changing the date and time of your camera, use Rechargeable batteries for a longer battery life span but make sure that you will be setting the battery type of your camera for the Rechargeable ones.
To set the correct battery type.
- Press on MENU button
- Press on the right button until you see SETUP 2
- Scroll down until you see BATTERY TYPE
- Select ALKALINE if you're using NON-RECHARGEABLE
- Select Ni-MH if you're using RECHARGEABLE
- Press on OK/MENU button for changes to be saved
Turn off camera after the settings
have been changed to refresh the camera.
Dec 23, 2007 | Samsung Digimax S630 Digital Camera
Problem in s630 digital camera
There is a Battery Type setting in the Menu of your camera.
Do the following:
- Press Menu/ Ok button
- Go to Set- Up 2
- Select Battery Type
Under Battery Type there are two options:
- Alkaline- if you are using non- rechargeable batteries
- NiMH- if you are using rechargeable batteries
Nov 19, 2007 | Samsung Digimax S630 Digital Camera
Samsung Digimax S600 Digital Camera Logo
134 people viewed this question
Top Samsung Digital Cameras Experts
Are you a Samsung Digital Camera Expert? Answer questions, earn points and help others
