Question about Coast PX25 208 Lumen LED Flashlight
I installed new batteries. Now the light stays on dimmly with the switch on.
System not turning on. DIMM1 & DIMM2 lights are blinking. What can I do to get my system working?
Switch it off at the mains and try removing one dimm and test, then, if nothing has changed, remove that dimm and replace the one you removed first and test that one.
If nothing changes excange the dimms places and try them in the other slot(s).
If this procedure produces no joy obtain a known working dimm and , removing the other 2 try it in all dimm slots.
Sorry, I should have said, before going through all this remove the motherboard battery and switch off all peripherals attached to your PC at the mains outlet. Leave it of for a good five minutes then replace battery and attempt the above procedure.
I would approach the motherboard manufacturer for support if the memory testing produces no joy.
You could attempt to test the modules in another motherboard and run MEMTEST . If they test good there must be a fault on the board or with another component. It is , as you must know a process of eliminating all possibilities.
It might be helpful if you disconnected all cables from the board whilst you are testing, such as sata cables,etc.
Good Luck
May 26, 2015 | XFX MDA72P7509 Desktop Motherboard -...
Batterie and brake light stays on changed new batterie new alternator car ran fine the next day the car would not crank
There is obviously have a drain on the battery. You have a faulty break light pedal switch causing the lights to stay on, or your turn signal switch is bad. your brake lights run through, the turn signal switch too. That could also cause the problem.
Oct 04, 2014 | Cars & Trucks
2002 grand am, installed new battery, parking light stays on when key removed
The lights will stay on with or without the keys on most cars if the switch itself isn't turned off, also make sure all the doors are closed tight, and the sensors on the doors are working correctly.
Sep 21, 2017 | 2002 Pontiac Grand Am
Anyone know why an ASUS PTGD1-LA motherboard will only take memory in slots A1 and A1 or A1 and B1 but not anything in B with both in A filled? Brand new memory.
HI,
The board has specific requirements for memory. Here's the Memory Configurations :
  • You may install 256 MB. 512 MB and 1 GB unbuffered non-ECC DRR DIMMs into the DIMM sockets using the memory configurations in this section.
• Installing DDR DIMM. Other than the recommended configurations may cause memory sizing or system boot failure.
• In dual-channel configurations, install only Identical (the same type and size) DDR DIMM pairs for each channel.
• Always install DIMMs with the same CAS Latency. For optimum compatibility , It Is recommended that you obtain memory modules from the same vendor
• Double-sided x 16 modules are not supported on this motherboard.
• Due to chipset resource allocation, the system may detect less than 4 GB system memory when you installed four 1 GB memory modules.
For dual-channel configuration you may:
install identical DIMMs in all four sockets
• install identical DIMM pair in DIMM_A1 and DlMM_B1 (blue sockets) and identical DIMM pair in DIMM_A2 and DIMM_B2 (black sockets)
• install same size DIMMs in DIMM_A1 and DIMM_B1 (blue sockets) and another same size pair in DIMM_A2 aid DIMM_B2 (black sockets)
Hopefully this will help understand how to install the new memory.
Thanks Mark
Mar 19, 2010 | ASUS PTGD1-LA Motherboard
When turning ignition key - no cranking, not even a click, lights don't dimm (except radio). Chrysler NY 1995 Battery 12.2V.
could have bad starter or neutral safety switch. try starting in neutral see if it starts if so change switch.
Sep 27, 2009 | 1995 Chrysler New Yorker
I have a 1985 Cheverolet pick-up. I have a cluster of under dash guages that I installed about ten years ago. Last week I replaced them with new ones. After doing so, My rea tail lights will not cut...
Sir,
It's probably the brake lights that are staying on, check again, if the brake lights are staying on the brake light switch needs to be replaced. The reason I believe it's the brake lights is that they will turn on even with the key off so make sure which lights are staying on.
Click these links for more info.
Link 1
Link 2
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 10, 2009 | Chevrolet S 10 Cars & Trucks
Hp laserjet 1200 series
Remove the DIMM and reseat it.
If the printer still has an error, replace the DIMM.
Unplug the power, reseat the paper tray, and reattach the power cable.
Oct 20, 2008 | HP LaserJet 1200 Printer
Brother laserjet 5170dn
If you see the service call indication above, follow the steps below:
1 Take out the DIMM (Dual Inline Memory Module) from your printer, if you have a DIMM installed.
2 Turn off the power switch, wait a few seconds, and then turn it back on and try to print again.
If you cannot clear the error and see the same service call indication after turning the printer back on,
call your dealer or a Brother authorized service representative.
When you press the Go and the Job Cancel buttons together, the LEDs will light up with one of the
combinations shown in Table 1. See Table 1: LED indications while pressing Go and Job Cancel on page
3-6 to identify the error.
Something has failed that the printer can't recover from.
Apr 18, 2008 | Brother HL 5170DN Laser Printer
Memory upgrade from 512 to 1,024 problem
Are both of the ram PC2100? Because this mother board only supports PC2100 memory modules.
Mar 30, 2007 | Sony VAIO FRV28 Notebook
Coast PX25 208 Lumen LED Flashlight Logo
126 people viewed this question
Top Coast Camping, Backpacking & Hiking Experts
Andrew Taylor
Andrew Taylor
richie46
ray gallant
Are you a Coast Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
