Question about Garden
I have a honda mtd pro 11a-588q795 push mower and it will not start. I cahnged the spark plug, emptied out the gas, new oil ( was empty and could not locate a plug to empty it), new air filter ( lost the cover for it though) checked spark plug wires, checked gas line( gas does flow through to carb when i checked). help me please. thanks. Darryl
  • otsandilands May 10, 2009
    Thanks You it works!
  • 246 Answers
Hello:
>>The Following is a Simple Way to make Sure the Engine is Getting Gas from the Carburetor to Run.
>>Pour a Small Amount of Gas (approximately 1oz) into the Carburetor Throat and Try to Start the Engine.
>>If the Engine Starts and Quits, then Check the Carburetor Solenoid.
>>If the Carburetor Solenoid is Good or has been Removed and the Engine will Start and Quit when the Gas is Poured into the Carburetor Throat, then Soak and Clean the Carburetor.
If the Carburetor is the Cause, then
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I Suggest you Make Sure the Gas is Free Flowing to the Carburetor Inlet Port (if the Model does Not have a Fuel Pump). If the Gas is Free Flowing to the Inlet Port, then
>>**Remove, Disassemble and Soak the Carburetor Overnight in Carburetor Cleaner (I Use Gunk).
>>The Primer Bulb is Held in Place with a Locking Collar at the Base of the Primer Bulb. Use a Small Flat Screw Driver and Carefully Pry the Lock Ring Up in Small Amounts All Around the Lock Ring until the Lock Ring and Primer Bulb can be Removed from the Carburetor Body. Usually a New Primer Bulb is Required when you have to Soak the Carburetor. The Rubber is Usually Rotted to Much for the Primer to be Reused.
>>Your Primer Bulb May Differ Slightly, but Removal is Usually Almost the Same Except for the Primer Bulbs that are Bolted to the Carburetor. These are Simply Unbolted and Changed with the new Primer Bulb.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>You Only have to Remove the Bowl (if Applicable), Float Pin (if Applicable), Float (if Applicable), Needle Valve and Needle Valve Seat if Applicable. This is a Flat O-Ring Located in the Inlet Port the Float Needle Rests in. Use a Strong Wire with a Slight Bend to Remove the Old Seat. Sometimes a Small Pocket Screw Driver can be Use Also.
>>The New Seat will have a Slightly Beveled Side and a Flat Side. The Flat Side goes Towards the Carburetor Body when Inserted into the Inlet Port. Spray the Seat with Spray Lubricant to make Installation Easier. The End of a Drill Bit that is Slightly Small than the Seat can be Use as an Insertion Tool.
>>Wear Gloves or Use a Rag when Handling the Sharpened End of the Drill Bit. Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. Even the O-Ring Around the Bowl can be Reused if it is Not Broken. The Only Parts you May Need to Replace is the Float Needle Valve (and Seat if Applicable).
>>The Float Needle Usually is Not Replaced Unless it is Not Operating Properly (the gas flow not shutting off and the carburetor is Flooding). Do Not Remove the Main Nozzle. This is a Pressed Fit and Removal is Not Required for Cleaning. Soaking and Blowing the Carburetor Out After Soaking will Clean the Nozzle.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers. There are Several Location for the Air Mixture Screws. The Idle Air Mixture Screws are Usually Located at the Top of the Carburetor Bowl and the Top of the Carburetor Body.****
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine. The Main Jet Air Mixture Screw is Located in the Bottom of the Carburetor Bowl or Beside the Idle Air Screw on the Side of the Carburetor Body.
>>Some of the Older Model Carburetors have the Main Jet Mixture Screw Straight in from the Top of the Carburetor Body (this is Rare anymore). If you have Cleaned the Carburetor (Disassembled and Soaked Overnight in Carburetor Cleaner (I Use Gunk). Then Blow Out the Passages with Compressed Air and Install a New Kit if Required. Now Setting the Air Mixture Screws:
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If This Carburetor has a Single Air Adjustment (Except Tank Mounted 9200 and 100900 Engine Model Carburetors), Use the Section Above that Pertains to Full Throttle RPM Air Mixture Screw and then Adjust the Screw if Required to Eliminate Any Hesitation when Throttling from Idle to Full Throttle.
>>For the 9200 Model Tank Mounted Carburetor Adjust the Air Mixture Screw Full In, then Reverse 1 1/2 Turns. Set the Throttle Lever to Full Throttle and Start the Engine.
>>Now Carefully Use 1 Finger and Open the Throttle Plate and Over Rev the Engine Slightly. If the Engine Over Revs and Does Not Struggle to Over Rev, then the Carburetor is Set. If the Engine Struggles to Over Rev, then Turn the Adjustment Screw In 1/4 Turn and Repeat the Over Rev Test.
>>If you Adjust to 1/2 Turns In and the Engine Still Struggles to Over Rev, then Return the Adjustment Screw to 1 1/2 Turns Out from Snug and Turn the Screw Out 1/4 Turn. Do the Over Rev Test. Continue this Process Until you have the Engine Over Revving without Struggle.
>>By Adjusting the Carburetor on this Style Carburetor Until the Engine Over Revs without Struggle, you have Adjusted the Air Mixture to the Best Possible Setting.
>>This file was Intended to Give you the Basic Carburetor Cleaning Instructions and May Not Reflect Your Carburetor Components.
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
>>You can View a Breakdown/IPL of the Mower/Engine at this Site Addy, http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP&lang=EN&TF=Mainframe&LoginID=hywd&loginpwd=hywd&Partner=HYWD and Select the Catalog American Honda.
>>You can View a Breakdown/IPL of this Unit at this Site Addy, http://www.smallenginepartswarehouse.com/parts.asp and Select the Shop Online Parts Look Up. Then Select the Model Tab. Then Select the OEM (MTD) and Enter the Model Numbers (). Then Double Click on the Model in the Results Area. Now you can Select the Section of the Unit you Wish to View.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
John
Posted on May 10, 2009
  • John C Bridgers Sr May 11, 2009
    Hello:
    You are Welcome.
    >>Till Next Time. May All Your Mechanical Problems be SMALL ONES and as Always, May the All Mighty Bless You and Yours. Be Safe and Happy.
    Best Wishes and Good Luck
    Respectfully
    jbridger (John)
2 Suggested Answers
  • 168 Answers
SOURCE: the machine do not start
Did you check the engine for spark? If so, you either had spark or you didn't. If you did have spark then you may have a valve adjustment problem being that it has a Honda motor on it that bleeds of your compression hence, no start. If you didn't get any spark on the plug, then check out the unit to see if it has a dead man system built in it and i'm guessing it does. If this unit has this system then in all likely hood it also has a cable that runs down the handle towards the motor. If this cable has an adjustment on it, that may be where your problem lies. If it doesn't then it does have a braking system on it. That could be anything from a flywheel brake band to a clip that gets nicked by a ground when the dead man system is let go. You might want to have a look at a shut down wire and make sure it's not grounded anywhere and you may have to remove the pull cord casing to find that out.
Hope this helps and good luck.
Wayne
Posted on Oct 03, 2009
MTD lawn mower won't stay running.
Did you empty the carb bowl and clean out any old fuel & contaminants? This is the most effective way to determine fuel issues. It also gives you the opportunity to remove all old fuel from the fuel lines, filter, & drain the tank bone dry. You may have already introduced water from your previous efforts so take out the plug & pull the cord a few times to dry out the cylinder. Next start the first time with starter fluid since you may still have contaminants in the primer system. In the future use only non-ethanol fuel, a marine grade stabilizer such as "Sea Foam" and replace all fuel every spring. Fuel begins to varnish and break down after 1 month unless stabilizer is used. Ethanol gas absorb water from the surrounding air in about 2 months & only gets worse.
Sep 06, 2015 | Mtd Garden
MTD Push Mower Starts and Stops Running
Sounds like you have debris in the carb bowl,blocking the main jet and or some water still in the fuel system .did you gap the new plug at .030" ?
Oct 05, 2014 | Mtd Garden
Lawn mower stopping by itself
CHECK THE FUEL FOR CONTAMINATES OR OLD GAS
EMPTY COMPLETELY OUT AND PUT IN NEW GAS!
ALSO CHANGE SPARK PLUG!
IF YOUR LOW ON OIL, IT MIGHT AUTOMATICALLY SHUT OFF ALSO!!
Jun 15, 2014 | Mtd Yard - Man 160cc, 21" Self - Propelled...
I have a Yardman 22" push mower Model 11A-084E029 B&S 158 cc engine I bought new. It starts and rungs great the first time I use it. When I go to use it again in a couple of weeks it will not stay...
still your gas could be not good for a small engine like a push mower. check your local content of ethanol in you area. ethanol is very,very,very bad for small engines. ethanol(alcohol) over time creates moisture in the gas and moisture(water) dont burn. I say check you local gas station or go buy gas other place. look around for special gas like for fleet. empty all gas and remove carb. bowl and fill with new gas.
Aug 14, 2010 | Mtd 22" Yard Machine Push Mower
How do you drain the oil and gas out of this mower mtd 22' 4hp and how do you change the spark plug? do you need any special tools/thank you soooo much natalie
Drain plug for the oil should be under the deck next to the blade shaft. Usually a plug with a square head on the bottom of the motor. Loosen the fill plug and then remove the drain plug. Any time you go under there make sure you disconnect the spark plug wire so no spark can jump.
Gas is another thing. No fuel line as carb is part of the tank, so only way to empty is to .....
1) tilt the mower over and pour out the gas. Good time to change the oil and do it before you add the new oil.
2) unbolt the tank from the motor and remove tank carb and all a single unit. Then turn it over and dump the fuel. there are only 2 bolts holding it on so after you remover the air filter you can see them easily. Just remember how the throttle linkage hooks on.
May 21, 2010 | Mtd 22" Yard Machine Push Mower
Lawn mower won't start
Did you set the plug gap to specs?
Check fuel line filter.
Empty gas a replace with fresh fuel.
Apr 06, 2010 | Mtd 22" Yard Machine Push Mower
The machine do not start
Wayne
Oct 03, 2009 | Garden
GOT GASOLINE IN OIL TANK OF MY LAWN MOWER BY ACCIDENT. sTARTED THE MOWER ONCE .IT STARTED BUT GAVE A GREY SMOKE AND DIED.I HAVE A MACHINE YARD MOWER FROM MTD.IT IS 22'' SIDE DISCHARGER.PLEASE...
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Jul 15, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
2,422 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
