Question about Irons
Phillips 7400 iron tripping fuse box
Switch on trips fuse box
  • 1527 Answers
SOURCE: 2 yr old Tefal Pro Express Steam generator Iron Trips Fuses
hello does all the electric go off in your home if so theres a bad earth on the iron or the iron element is shorting out also make sure theres no water getting into the iron good luck
shaun
Posted on Mar 20, 2009
aguywithfeet
  • 20 Answers
SOURCE: Iron causing electrical fuse to trip
I would almost definitely say yes. Have a friend or family member bring their iron over and try it. I can think of no other reason why it would trip a breaker. Let me know what happens.
Posted on Apr 02, 2009
  • 125 Answers
SOURCE: Steam iron trips the main fuse
It could be your iron drawing too much current but it sounds more likely that you have a weak circuit breaker on that circuit. You might try the iron on a different house circuit to confirm if its actually the iron or the house breaker giving you problems.
Posted on Sep 07, 2009
podita
  • 324 Answers
SOURCE: why does my iron keep setting the trip switch off.
This is a circuit issue, the irons element is Bad, if you can replace the element otherwise get a new iron
Posted on Mar 10, 2010
Testimonial: " this was very helpful indeed"
heatman101
  • 43501 Answers
SOURCE: tefal turbo ro 400 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
When turned on iron trips the main fuse box
Probably a shorted heating element
Dec 29, 2017 | Irons
My Iron keeps tripping the fuse in main power box what is causing this it doesn't happen with any other appliances?
Tripping the breaker or fuse as you call it is caused by excessive current draw. These are safety devices that are meant to protect from electrical overloads and fires. More than likely your iron has a failing heating element and should be replaced. If it is a steam iron it is also possible that it has developed an internal water leak causing a short. Continued use is unwise and a potential safety hazard.
Feb 19, 2015 | Irons
Iron not working no power nolights
check the circuit breaker in the main fuse box in case a breaker has tripped.
check the fuse in the power plug, if it is no good replace it.
Try the iron in another socket /outlet in case the one you are using is faulty.
Jan 23, 2013 | Black & Decker D6000 Iron
Iron works for a little then electricity trips. why would this happen
You have a faulty and possibly a dangerous appliance. It could be a faulty/worn electrical cord. i suggest you get it checked out or throw it out and buy a new iron.
Dec 12, 2012 | Irons
My tefal iron tripps out fuse whenever i turn it on
check the wires that lead from wall socket to your iron it might have opened and twisted which could have created short curcuit
Aug 30, 2012 | Tefal Irons
I have a Bosch b52l iron, when i turn on the steam button, it cuts off the power, what could it be
It could be the iron itself (it may have a short circuit in it) and the circuit breaker trips when the steam switch is turned on.
Option 1)
Another option is that the entire circuit that that circuit breaker is controlling is overloaded. What other outlets / applicances / lights are disabled when that circuit breaker trips? You may have to iron only when those other applicances on that circuit are not being used.
Option 2a) Your outlet may be damaged and causing your circuit breaker to trip when the high current STEAM setting is set.
- OR -
Option 2b) the circuit breaker is damaged and is tripping too easily. Only replace with a similarly sized circuit breaker (15 amp lis likely but is says right on the breaker).
Try the solutions in that order.
-Mark
Please rate me..
May 07, 2011 | Bosch Irons
Sep 07, 2009 | Philips HI-296 Iron
shaun
Mar 20, 2009 | Tefal UltraGlide plus 1656 Iron
General electric light 'n' easy iron tripping safety switch
it is shorting out and tripping the breaker either from moisture or problem insulation
the cost to repair is more than a new iron so junk it and be safe
Jul 12, 2017 | Irons
Jan 26, 2009 | Tefal UltraGlide plus 1656 Iron
Irons Logo
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
