Dayton schematic 3uf60d - Heating & Cooling
Hi I've been looking for a thermal coupler unit for my Dayton gas garage heater. Could not find it so I came to this site. Just need a bit of advice plz on how to replace part and part # Thankyou.
See if you can find the specifications or schematics for your heater, it will tell the info about your thermocoupler. I have, learned that most are the same. Personally, I would use one from a water heater.
Sep 18, 2016 | Dayton Heating & Cooling
I have a dayton electric pallet model 2leb8..the fan got tore off and i can't figure out the wiring of it.where they go..the schematic shows one wire coming out of the fan into a switch but un
hi there
i found some electrical schematics at the site below, pages 16, 17, 19 and 20.
if not exactly what you need, there should be enough information to help figure it out.
good luck! (:
http://www.grainger.com/ec/pdf/Dayton-Electric-Pallet-Truck-2LEB8-OIPM.pdf
Oct 26, 2014 | Cars & Trucks
Need wiring schematic for dayton 3 E 241
GO ON THE INTERNET AND DOWNLOAD A MANUAL.
Dec 27, 2012 | Dayton (3E379) Heater
My Dayton 3E382D heater will not light because the plenum is missing. Where can I buy a plenum and where can I view a schematic for this unit?
For a schematic go to Dayton Furnaces on the internet and type in your model # and you should be able to download a parts diagram. The plenum you can buy at your local hardware store.
Oct 15, 2010 | Dayton Gas Furnace Heater
Low rpm on blower motor
The 1350 RPM Speed is for 50HZ. The motor will only run at 1525 on 60 HZ.
Nov 30, 2009 | Dayton Shaded Pole Blower 480CFM. 2 Speed,...
How to wire a dayton off delay timer relay for 1 min. solenoid ac
found a reference to the relay class I was in need of information on here:http://www.hauntedattraction.com/38/currentissue_workshops.shtml describing a particular circuit r&d that I could equate to my dilemma... took a little mapping out of the schematic as I read, but wasn't too difficult to correlate. It pays to persevere in your googling methods ;-)
Apr 17, 2009 | Amperite Dayton Solid State Timer On Delay...
DAYTON 9K602F HOIST WIRING
false alarm-schematic in cover of unit
Apr 09, 2009 | Dayton Electric Hoist Heater
Dayton G73 wire hook up with 10/3 NM-B wire
Red wire is not needed. Be certain 208 volts is read across black and white. Cap off the red.
Jul 04, 2008 | Dayton Electric Heater
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
