Question about Hasbro Nerf Super Soaker Thunderstorm Blaster
Does not shoot
The battery Cartrage is rusted
Mower died and will not start
Check the spark plug for spark. They can go bad without warning. If no spark try another one in there, ,also try the plug in another engine to see if it sparks there. If it does, check for rust on the flywheel where the magnet passes the coil for rust. Also check the edges of the coil for rust where the magnet passes it when it spins. If it's an old mower with a condenser in the ignition system, the condenser could be bad as well.
Aug 13, 2014 | Garden
Can not get the color to work in my lexmark x1240 printer to work? we tried to refill the old cartrage first but it leaked after a couple uses than we bought a new cartrage but it won't work.
Make sure that you are using genuine Lexmark cartridges and not refilled, re-manufactured or clone cartridges from the 3rd parties. Lexmark products work best with original supplies. If you are using genuine cartridges yet the problem persists, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 01, 2011 | Lexmark X1240 All-In-One InkJet Printer
Inserted new ink cartrage, but printer saying remove tape from the ink cartrage. I've done that but it still say error. Also the not printing correct. I've had the ink cartrage for a while could that be...
Clean the contacts of both the cartridge and the print head with some alcohol. Reinsert the cartridge.
Power off the printer and wait 1 minute. Power if back on and then make it go thru calibration cycle if it
has one.
Mar 23, 2011 | Office Equipment & Supplies
I installed new epson ink cartrage, but printer has red x and tells me to change ink again.? Can i just change only the bkack ink?
Yes you should be able to just change the black ink cartrage, A lot of printer wont allow other third party cartrages, is it a genuine epson ink cartridge? if so try cleaning the contacts on the cartrage.
Apr 25, 2010 | Epson NX415 All-In-One Printer
I have installed a new ink cartrage but the
Restart the computer. Turn off the printer. Turn the printer back on after the computer is fully started.
Mar 29, 2010 | Brother MFC-210C All-In-One Printer
K7100 black cartrage error (unrecognized)
push and hold the reset button for several minutes until it works again
May 27, 2009 | HP OfficeJet K7100 Photo inkJet Printer
Color ink cartridge says empty i just filled it
When you put in a "new" cartrage the printer sens an electrical charge to the cartrage to set it up properly. So I would treat this as a new cartrage, rather than a refilled one. Go to the printer menu and re install the ink cartrage in question, it should recognise it and start the function as a new one, good luck
Mar 24, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Color cartrage
hi
if you have a spare cartridge try with it..if it works fine..then its a defective colour cartridge...try cleaning the cartridge with a damp paper towel..if that does not fix the issue..contact tech support...your cartridge would be replaced if in warranty
goodluck
Jan 25, 2009 | Lexmark X75 All-In-One InkJet Printer
Hasbro Nerf Super Soaker Thunderstorm Blaster Logo
Top Hasbro Toys Experts
thegtw
Antony
William McDowell
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
