Question about Emerson Televison & Video
Lc501em3 50 inch emerson LCD tv has no sound or pic, purchased 7 months ago
50 inch LCD emerson tv has no sound or pic, purchased 7 months ago
SOURCE: Remote Code for Emerson LC200EM8 LCD HDTV 20 inch
sony RM-VL600 remote, can be programmed remote to remote...I bought it, it works.
Posted on Apr 27, 2008
SOURCE: No sound on LCD tv
We have the RCA L37WD22 tv. We bought it 4 months ago and much to our dismay, the sound went on the weekend and the screen shrunk. We had to take it in to be fixed. We were told it had shorted out and that the fuse needed to be replaced. We were also told that an upgrade was put into it. We have a one year warranty, but we are going to look into buying an additional warranty too.
Hope this helps.
Posted on Jun 04, 2008
dsacco86
  • 1077 Answers
SOURCE: Emerson LC320EM82 S LCD TV I purchased this TV a
Your not alone with this problem.
I had to fix mine. The warranty is less than impressive.
The trouble is going to be the Power Supply/Backlight Inverter board.
This is the picture of yours:
11e1946.jpg This is board # BA71F0F01042. Replacement boards are hard to come by.
Fixing the board like I did seem to be the only option. If you need info on fixing it, let me know.
Posted on Jun 18, 2009
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
  • 8457 Answers
SOURCE: We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Posted on Jan 15, 2010
Testimonial: "Have tried turning on/off a few times but still doesn't work. thanks anyway"
Emerson 55 inch LCD TV no picture, but backlight and sound works
T'Con board fault. Check and replace it. If you wish to get some details; check the site linked here. Pull up older posts.
Aug 10, 2016 | Emerson Televison & Video
I bought an Emerson 19 inch lcd in walmart this past april or may and 2 months later when you attempt to turn on the tv all you hear is a loud humming sound, no pic just the humming sound when you plug it...
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this will help in solving....
Nov 29, 2010 | Emerson Televison & Video
Emerson LC320EM82 S LCD TV I purchased this TV a year and 3 weeks ago. It suddenly stopped powering on. When I turn it on the screen comes on for half a second with 3-4 inch white lines across middle of...
Jun 18, 2009 | Emerson LC320EM8 32 in. LCD TV
Remote control code for 32 inch lcd EMERSON TV
Feb 18, 2009 | Emerson Televison & Video
It's the 26 inch version but have problem with picture
Hi Paul,
It looks like your TV might have a main board failure if the screen stays white without video. Since your TV is less then a year, I would suggest to contact the manufacturers to get fix under warranty. Most electronics devices carry one year warranty.
Good Luck.
Dec 19, 2008 | Olevia LT32HVE 32 in. LCD Television
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Emerson 32 inch lcd
i have your answer!!!!!!!!!!!!!!!!
use the PRODUCT WARRANTY call emerson and have it sent back, then your like oh wow it works like new( and it will be a new one) yay thank you so much guy on the net for telling me about the PRODUCT WARRANTY
Oct 21, 2008 | Emerson EWL3706 37 in. LCD Television
Won't turn on
one of the inverter transformers has gone bad replace the bad one and the set will work fine ,there are 6 transformers in the 32".
Oct 02, 2008 | Emerson EWL3706 37 in. LCD Television
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
41 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
