Question about Lowrance Lcx 112c 10.4" Gps Fish Finder Combo With Df Tm Transducer
Lowrance 112c gps shuts off when cranking main engine?
    New Friend:
  • 65 Answers
If your battery is OK (not dropping below 12v during start up), you can try moving the GPS power connection directly to the battery. This would reduce voltage drops due to other cabling. It's always a good practise to power down electronics before cranking engine but most of us don't.
Posted on Aug 19, 2014
  • 30 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} This is very common when using a single battery system in you boat.
If you more then battery connect the fish finder to the second battery.
Or if the Depth finder is connected through the acc. on the boat. The power is being cut off be fore the starter is engaged. By pass this and connect through a correct size fuse.
Posted on Jun 03, 2009
  • Robert Higgins
    Robert Higgins Jun 10, 2009
    I don't know why this does the funky pretext but
My new Lowrance Hook-5 GPS isn't working, I'm a noob, how do I get this function working?
'isn't working' is such a broad problem. If it is only the GPS, it is covered from Page 49 of the manual and shows you can access Satellite information. Note, it almost certainly won't work in your garage or storage. It need to see the sky as the antennae is internal.
The unit has an installation guide. In my personal opinion, it is better to let a professional boat engineer install it, mainly for the correct fitting of the transducer on the stern. Correct placing makes all the difference to a good set up, unless you intend to fish without the engine running.
All they need is mounting, power through a fuse direct to the battery, and the transducer fitting. Then you put the boat in the water and switch it on.
Installation Guide
http://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-5-SERIES_IG-MT_988-11024-001_w.pdf
Manual
https://www.lowrance.com/Root/Operator%20Manual/Lowrance/HOOK-SERIES_OM_EN_988-11004-002_w.pdf
Full Specs
HOOK 5 Fishfinder and Chartplotter
Apr 24, 2017 | Lowrance GPS
Lowrance lcx-111c hd, single beam transducer
Hey Tingo,
I have two 113's,, the problem sounds like the transducer is going bad,, Try this.. unplug all your connections,, replug them and see if it helps...
Don't get me started on $$$ updates....
May 15, 2017 | Lowrance Lcx 112c 10.4" Screen Color Gps...
My lowrance 520c GPS stopped working. When I turn it on it shows the last lake I was AT. And the trail marker does not work
I have a 525... Several things and go step by step... First, make sure your getting 12v of power to your "puck"... On the Lowrance site there is a step by step guide for testing. Just because your getting power to the main unit does not mean your getting power to your the gps module. There are three different power sources on these units. Main power, sonar and gps! If your getting 12v coming out of the data port then check power to the cords, and to the T... If all that is correct the its likely your gps module. You can order a new one directly from Lowrance customer support for 50% off the normal price as a replacement. They will likely upgrade you to the 4000 series. Comes with all wiring, T connector but not the resistor cap. Best time to call Lowrance is 8:15 am central time when the phones are turned on!
Mar 04, 2010 | Boating
I have a lowrance LMS 332C GPS. After 5 years I
The LGC-2000 is bad would be the most likely cause, but if this started right after you changed the cables, Try connecting the NMEA 2000 network to a different power source than the main power. If you still have the original cables, and you didn't have the problem before, try using those again to make sure there isn't anything wrong with any of the new cables.
But most likely, the LGC-2000 is toast and you will want to contact Lowrance support to see about getting it repaired/replaced.
Jul 04, 2009 | Lowrance LMS-332C GPS Receiver
Need a manual for my lowrance lcx marine gps combo
You're in luck! Visit => http://www.lowrance.com/en/Downloads/Manuals/
There are 3 manuals (pdfs). The first is the manual, the next two are addendums.
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX-15MT_0133-49.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-70_add_031402.pdf
http://www.lowrance.com/upload/Lowrance/Documents/Manuals/LCX15_0133-71_add_032802.pdf
Please leave feedback. Thanks in advance.
Jan 03, 2009 | Lowrance LCX-15MT GPS Receiver
Need manual to download
Jan 03, 2009 | Lowrance GPS
Gps
upgrade it firmware usnig the download support are in the main page of ur product u will find it there!!
Sep 10, 2008 | Lowrance GlobalMap 3300C GPS Receiver
X107CDF that comes on by itself and won't shut off (drains battery)
LOWRANCE HAD A FAULTY BATCH OF KEY PADS
SEND IT BACK TO MANIFACTURER
Aug 17, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Speed & track display
I have a 3500C and am facing the same problem. The position is acquired but the speed displays 0.00mph. Did you find anything about how to fix this problem?
Apr 21, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Lowrance Lcx 112c 10.4" Gps Fish Finder Combo With Df Tm Transducer Logo
269 people viewed this question
Top Lowrance Boating Experts
Phil Walker
Phil Walker
Jerry Greenberg
Jerry Greenberg
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
