Question about Bryant Preferred Series 3 Stage Heat/ 2 Stage Cool 7 Day Programmable Thermidistat Control
Thermostat beeping, low battery - Bryant Preferred Series 3 Stage Heat/ 2 Stage Cool 7 Day Programmable Thermidistat Control
Concern is about a wall thermostat
Change the battery. Most programmable thermostats have a backup battery so when power is lost the program isn't.
Nov 26, 2016 | Refrigerators
Low battery mess changed it and still continues to beep how do i fix
Power your system down first. Plug in the battery, the panel should beep, then plug in the AC power. If the panel doesn't beep you might have a bad battery. If the panel powers up after the battery then AC power reset your time and the beeping should stop.
May 16, 2014 | GE Security Simon 3 Wireless Home Security...
Home Thermostat reads low batt
I have ran into this problem before. I have actually had low batteries I thought were good too ha! I have had to actually reset the stat to get the low battery to stop flashing. There are multiple ways to reset the thermostats, depending on model, but removing the batteries and waiting has worked, along with actually having a reset button somewhere on the stat. Hope this helps!
Nov 30, 2013 | Honeywell Programmable Thermostat Heater
We have a White-Rodgers 90 series thermostat that started beeping last night. We have had it for about 4 years. Does it have a battery? I couldn't find anything about that in the manual.
Susan, the "90" series of thermostats covers a couple of different thermostats made by White-Rodgers. Here's how to find your model number. With that info, I can check the manual specific to your thermostat.
In the mean time, check the display for the word BATTERY or BAT. (Flashing) on the display. Battery flashing or blinking on the digital display indicates low batteries. If the batteries have recently been changed and the thermostat continues to indicate low batteries, use a pencil eraser to polish each of the battery contacts inside the back of the thermostat. Do not bend them up and down when polishing or you might break them. When complete, they should all be as shiny as a mirror. This will assure proper battery back-up, allow the backlight to work correctly and remove the flashing battery symbol from the screen. Battery (Solid) on Display The battery symbol (not blinking) indicates a loss of power (24 volts) from the heating and cooling equipment to the thermostat. Normally the heating and cooling do not operate when the battery indicator is on. If the battery indicator is on, check the fuses or breakers, make sure the furnace is switched on, and verify the blower compartment door is closed properly. The battery display is designed to indicate the thermostat is running on batteries, so replacing batteries has no effect on the indicator. See No Heat/No Cool for more information. Note: Some heat only systems (zoned systems) disconnect power from the thermostat during a normal heating cycle and display the battery symbol. Millivolt heating systems always indicate battery because they do not supply 24 volts to the thermostat.
A beep often is provided as audible feedback when keys are depressed on many thermostats. You should check to make sure that no key is stuck in the "in" position or is otherwise activated.
Jan 10, 2011 | White Rodgers Water Heaters
Thermoset is set to off but keeps beeping constantly...anyway to disconnect to stop the beeping? Batteries were recently replaced..no battery indicator light is showing. I want to take a hammer!!
Can you provide me the model number of the unit? The model number starts with 1FXX-XXX. So that i can verify if that thermostat is capable of creating a beeping sound.
Jul 12, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Motorola gp-68 low battery beeps comes on too soon
I'm not sure that you can manually reset the low voltage threshold on your radio. Most of Motorola radio use programming software to turn on/off low battery beep and many other features. Everything is done by software.
radcom907
Mar 10, 2009 | Radio Communications
Bryant Preferred Series 3 Stage Heat/ 2 Stage Cool 7 Day Programmable Thermidistat Control Logo
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
