Poor pictre quality
Our picture quality is poor. images are fuzzy. Do we need new bulbs? Can we still buy them? Ivan
    Problem Solver:
  • 7 Answers
This set has 3 CRT's (picture tubes)
Remove the back bottom cover
Clean the CRT's with windex and a soft cloth.
(Find the Screen/Focus block)----Remove front grill cover and panel which covers the Screen/focus block.
Cover 2 crt's and adjust the focus control for remaining crt---(using the convergence pattern in the menu for the set)
adjust for the best focus.
cover that crt and move on to the next crt using the same procedure.
After setting the focus on all 3 tube's you will have the best focus possible for this set. If picture is still bad, you have bad crt's and the set is junk.
Cost to replace the CRT's is enormous!
Craig
Posted on May 08, 2009
Poor picture quality
Why do most security cameras shoot poor quality pictures ...
https://www.quora.com/Why-do-most-security-cameras-shoot-por-q... QuoraA good surveillance camera must have compact size, acceptable frame rate, ... Digital Cameras: How is the picture quality of the Samsung Galaxy S4 Zoom?
Why is DSLR cameras video quality so poor compared to ...
https://www.quora.com/Why-is-DSLR-cameras-video-quality QuoraWhy is DSLR cameras video quality so poor compared to still images at same resolution ... How does a digital camera work when taking a photo whose (image) ...
DigiTools: Communication, Information, and Technology Skills
https://books.google.com/books?isbn=0538741295
Jan 03, 2016 | Cameras
Poor picture
its a mainboard issue .It can be fixed easily by replacing the mainboard or the hard way by fixing the excact one (the second option requires advanced electronics and expertise
Jun 18, 2014 | LG RZ32LZ55 32 in. HD-Ready LCD Television
I just bought a new lamp 3 months ago, and the screen is now very dark. With the brightness all the way up the picture is dark.
Your most likely fault is bulb failure. The only way to confirm a weak bulb situation is to replace with a known "good" bulb. Maybe your replacement bulb is not the correct one, or has a problem, like damage from shipping or poor quality to start with. We hear from many users that buy el cheapo bulbs from Internet shopping carts and have failure within 30-90 days. Many shopping carts churn out inferior copies, surplus or rejected products ranging from TV parts to doll clothes and costume jewelry.
Premature lamp failure can also occur with rough use such as:
  • Turning off TV and starting again while still hot.
  • TV turned on while Lightning strikes or other power line "bumps" occur.
  • Collisions with vacuum cleaners or balls bounced against TVs while operating.
  • Over-heating caused by poor ventilation or direct sunlight.
You may also have optical engine failure if images on the Sony Optical Engine Fault Gallery appear with the dim picture.
easyab@hotmail.com
Feb 11, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
The picture quality is very poor. Picture is fuzzy.
Did you turn the ring on the camera itself? The camera does not automaticaly adjusts itself. You must turn the lens to focus manualy.
If nothing works and you just bought this camera, call microsoft and they will help you more.
Mar 05, 2010 | Microsoft LifeCam VX-3000 Web Camera
Poor picture quality, the picture is blurred and
You have problem with convergence. Have you tried adjusting in the users menu. This is a common problem in this type of TV, usually two convergence amp need to be replaced and sometimes sets of resistors are also to be changed.
Mar 02, 2010 | Sony KP-43T70 43" Rear Projection...
Poor print quality of images on envelopes
clean the print head 3 times,then realign the head .these are done by printer utility software given with the printer.
Even not ok.
Then Replace the New Catridge.(manufactured from within 3 of 4 months).because the ink will be dried with in 6 month.So Buy Carefully with Mfd Date.
Thank you
Feb 13, 2010 | HP LaserJet 4650 Color Printer
Xerox Documate 152 - Scan quality is now V.BAD!
I would go to Xerox.com and look up their knowledge base. Here is a copy of data from their site related to this problem:
Symptom: Scanned images have poor image quality, are fuzzy, unclear, or hard to read.
Cause: There are several things that can lead to poor image quality including the scan settings, dirt on the scanner, and driver problems. Solution: Note: If you scan as a PDF file and your scans look fuzzy when viewed in PaperPort, try right clicking on the file and selecting "Open" to open them in Adobe Reader. If they display fine in Adobe Reader then there is nothing wrong with the scans, it is simply that they are not being displayed well in PaperPort.
The following solutions can help resolve poor scan quality.
Solution 1 - Adjust the scan settings
Try increasing the resolution of your scan. 300 dpi to 400 dpi should be clear for most images
  • If you are scanning in Black and White, try Grayscale or Color. Some images will not display correctly in Black and White
  • You can also try adjusting the brightness and contrast
  • Note: For information on adjusting your scan settings, refer to the user guide for your scanner
Solution 2 - Clean and Calibrate the scanner
Note: Calibration only applies to sheetfed scanners.
Use the link below for instructions on cleaning and calibrating (if applicable) your scanner:
Solution 3 - Reinstall the scanner driver Select a link below for instructions on reinstalling your scanner driver:
Jul 08, 2009 | Xerox DocuMate 152 Pass-Through Scanner
Video quality is poor
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Feb 04, 2009 | Veo Velocity Connect Webcam
Poor quality images outdoors
try setting your camera's auto balance into Automatic or Outdoor. So the camera could adjust the light or diable flash.
Nov 27, 2007 | Canon PowerShot A430 Digital Camera
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
