Question about Jensen JMP12 Consumer Microphone
I have jensen microphone,pluged in, I don't hear anything when i say something.
I can hear phone but they can't hear me
check the connection of the microphone and if this good if I replace the microphone is integrated in the stereo has to replace the stereo
May 06, 2015 | Jensen VX7020 6 2 Inch MultiMedia...
No sound from my mxl v67 condenser mic
These things use Phantom Power, from your mixer. If it HAS it.
If not, now you know, get an external supply ($$!).
Peace-
Jul 27, 2014 | Marshall MXL V67i Microphone
AKG 120 on Mac, I don't get feedback on headphones or internal spekears . Recorded voice , I can see is there but can't hear anything....
Sounds like you have a computer sound issue. If the waveform is shown, and the amplitude is sufficient then it should playback audio. Not familiar with Mac but check mute settings, sound card volume, input/output config., audio routing, etc.
Feb 18, 2013 | AKG Perception 120 Microphone
I can here the recipiant - they can hear me and we can both see the videos?? Any ideas?
Can you hear anything. iTunes, other sounds? Have you tried different people. There are 2 things I thought of for this problem. 1, the other person is the same person all the time and they have muted their microphone. 2, you cannot hear anything on your system which could be mute, or a driver problem or a problem that can sometimes occur with the headphone jack port. For #1, have the other person try to record something or go to System Preferences and select sound, and make sure the microphone shows gain when they talk, and make sure the microphone is turned up (see picture for this one.) #2 You can try to unmute in the same system preferences, you can also check to make sure your sound system is working in the same preferences. If it is a headphone jack issue, I would plug in and out head phones into the jack until you can hear something (make sure you can hear through the headphones before this, if the headphones give no sound then don't do this.) Other than those items it would have to be a call apple issue. jp_2010_0.jpg
Jun 13, 2011 | Apple Customized 15" MacBook Pro Laptop...
When i turn on the midland 100m cb, I don't hear anything. The antenna is connected. Even when I key the mike, the needle doesn't move.
What about the Microphone you are using---Is it the right one for this model? If its not a Mic problem then its a burnt transistor in your board. Keep trying something with the Mic. May have to get it serviced at a repair shop. Sorry,can't help much.
May 07, 2011 | Midland Radio Communications
Why it do not work
try pluging it in a radio casset recorder or something els to test the mic itself, verify the microphone settings in Windows (volume, input type, etc...)
Cheers!
Jan 05, 2011 | Logitech Labtech Verse 524 Microphone
Microphone not working. I can hear people, but they can't hear me
Hi!
The plugs that they come with are substandard for regular removal.
(pluging in and out) the cable has no adequate strain relief causing the thin
cables inside to break. you will notice that it will crackle and temporarily come on
as you move the cable around near the plug end or where it joins the microphone.
Some times when people are engaged in conversation they play with the wire inadvertantly!!
i hope this has solved your problem.
take care.
Nov 13, 2008 | Logitech (980240-0403) Microphone
One works but the other doesnt
in most samsung phones there is an option setting right key by the screen that will route the call through the phone or the other divice i think you may have to switch it in a call first though
May 08, 2008 | Jensen WBT210 Consumer Microphone
Jensen VM9312 Bypass Code
trust me that works i just installed this deck in my truck today. And no you dont have to do anything with the ebrake wire at all just cut it off. Make sure you hear the beep sound when you hit 543210 you should hear it each time.
Apr 16, 2008 | Jensen's VM9312 Car DVD Player
Jensen JMP12 Consumer Microphone Logo
221 people viewed this question
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
