What wire size do I run for a 3 1/2 ton AC unit?
What wire size do I need to run for a 3 1/2 ton AC unit?
  • 1 more comment
  • Dennis Boxerman May 11, 2010
    Code calls for wire size based on amperage of the unit and how far away from the incoming power source. You will not get an answer untill you supply that info. Don't forget that there needs to be a disconnect within a certain footage of the unit. You need to supply where you are located as some codes differ slightly.
    Hope this helps.
  • Jeff Meyer May 11, 2010
    It would be really helpful to know the make and model of your A/C unit. Is this a new unit or approximately how many years old is it?
    Some have the option of wiring in 220 volt from the breaker box to the condenser, which is always preferred if it can be provided. In the long run, providing 220 sill save you money on energy costs and the motor will run cooler.
  • Samuel Charles Spriggs May 11, 2010
    Which part of the A/C circuit are you asking about? There are different size wires/cables for different legs.
  • 116 Answers
It depends on the distance from main power source # 8 if more than 40 feet look at starting amps then google a wire sizing voltage droop chart
Posted on May 09, 2009
Wire size for a 2 ton gas pack
In door shod be #12 and out door shod be #10 if it is not that far from the box
Aug 23, 2012 | Rheem Packaged Gas And Electric Unit 13...
What wire size do I need to run for a 1.5 ton AC unit in 220 volt?
It will be good to have a 3sqmm wire for the power line but if the line is going to be longer then increase the size to the next level.
This is because the AC on start up draws about 10 amps intially. the present models have bettter star ratings are consume lesser but a good conductor will not drop the line voltage.
Sep 20, 2010 | Heating & Cooling
Can I mix brands/tons when installing AC unit to existing coils?
First off - the 'rule of thumb' is 600' per ton of Air Conditioning. In other words your old unit is a 2 ton unit. So - 2 tons x 600' = 1200'. As you can see if you install the 2.5 ton unit - you will be installing a AC that 'could' cool a 1500 sq ft house (2.5 x 600' =1500 sq ft.). Slightly more than what you need; and the 3.5 ton unit is 'way to big,' (3.5 x 600' = 2100 sq ft.).
Note: fyi - many in the AC business will sometimes refer to tonnage in btu's, i.e. 1 ton = 12000 btu - hence a '2 ton unit' can also be referred to as a 24000 btu unit and vice versa.
So... from the above - you can easily see that "2 tons" of Air conditioning is what is required to cool the 'average' home of 1100 sq ft. "roughly speaking."
Note: it is always best to have a professional 'size' your cooling/heating needs.
One of your questions was could you 'mix tonnage?'
The answer is 'usually you don't mix the tonnage of your outside/inside units.' However, professionals sometimes do (mix the tonnage) in certain situations, and installing a 2.5 ton outside unit with an existing 2 ton inside unit is often done, however, there are some 'tech issues' here and - I would "again" recommend that you call a Service Tech to help you with the sizing/mixing of your cooling/heating needs.
hope this has helped
Jun 20, 2010 | Carrier 38CKC036 Air Conditioner
How to identify the btu of rooftop AC unit
ANY # DIVISABLE BY 12. MODEL HAS  12-24-30-36-40-48-54-60 12 1 TON 24 2 TON 30 2 1/2 36  3 TON 36.00 BTU 40 3 1/2 48 4 TON 48.00 BTU 54  4 1/2 60 5 TON   60.000 BTU
Apr 21, 2010 | Dometic Rooftop RV Air Conditioner
Compressor size
Square footage is how you determine what size of an AC you need, say two bedroom house with 1500 square feet would require a 3 ton unit but I would go to a 4 or 5 ton depending on brand and what you may do in the future, Like adding a bedroom or bathroom and how many people will be living in the house, a heat pump normally last longer the bigger it is and is more efficient than a smaller size. Just think like this, a 3 ton will run 30 minutes to an hour longer to cool the same space as a 5 ton so if the five ton does it 30 minutes faster it will not run as long. And when it has to pull down the temperature again it will do it much faster. So less run time means faster heat or cooling and less energy is used. I have found that the bigger units are made better and last longer as a general rule. And to understand the 3-ton and 5 ton let me say that it means how long it takes 3 tons of ice to bring the temperature down 10 degrees, the old BTU’s British thermal units. However the bigger the unit the more well built it is normally and the less maintenance required. 5 tons of ice would get it cooler faster. But one thing to keep in mind a heat pump is only good for 20 degrees temperature range, for instance if the high range is 80 then the low side would be 60 in order for it to be efficient so if you have it set in the house at 72 degrees on the high side and low side would be 52 degrees. But the larger the unit the less time it would take it to recover from the heat differential.
Jul 22, 2009 | Ruud UAKA042 Air Conditioner
How to tell the size of my ac unit?\
thats a 5 ton ac unit
10AJA6001AH
basically 1 ton = 12,000 BTU
so 24 is 2
30 is 2 and a half
etc
Jun 21, 2009 | Weather King Heating & Cooling
Could I use wire size 14 for 1 1/2 ton air window
No sir,14 gauge,three conductor will carry only up to 15 amps,which is usually wired for lighting circuits.Look on the electrical requirement plate on the unit,usually located under the front panel cover.It will tell you how many amps are drawn when unit is operating.Using a three conductor cable;wire accordingly:#14--15amps----#12--20amps---#10--30amps----#8--50amps.These are the wire sizes and the current(amps)they will carry.Be safe! Gregg
Jun 11, 2009 | Heating & Cooling
Check the info plate on the unit,it will give you the electrical requirements for the unit while operating.Here are the wire sizes for different amperages.(copper conductors).#14--15Amps-----#12--20Amps-----#10--30Amps-----#8--50Amps.These are three conductor cables.Be safe! Gregg
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
1,476 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
